Results 1 to 5 of 5
    May 2013
    Bent Axle or Hub? Need Help
    2013 Giant Trance X2. Was having problems with my rear derailleur and was doing some adjustments tonight. I kept hearing the chain rub against the rear cassette and could not figure out the problem. Took a closer look while up on the stand and pedaling it and noticed the cassette was moving while the tire was spinning. So, hub sitting still while rear tire is spinning and the hub rocks up and down slightly. THis is what is causing the chain to not line up correctly and cause the rubbing. Now, is this a bent hub, bent axle, or perhaps an bearing issue? Have never had to dig into a hub yet, so i am unfamiliar with the issue. Any help would be great. Have not had a chance to hit the LBS. Video is uploading on youtube now to provide a visual.
    Edit: Here is the video. https://www.youtube.com/watch?v=qyiu...e_gdata_player
    Reputation: J.B. Weld's Avatar
    That is the freehub body oscillating because of imperfect machining and it is very common and visible to some degree on almost every hub. It is not usually a problem and I have never seen that particular issue cause any chain rub.
    Reputation: ride the biscuit's Avatar
    to me it seems like that amount of movement could cause the chain to rub or jump gear since the der stays put while the cassette wobbles
    I dont know anything about what hub youre using, but I would first just try and check to make sure that my freehub was propperly mated/sealed to the hub body. Id give things a look-over at that time like check the bearings in the freehub
    mtbpete
    Reputation: changingleaf's Avatar
    I've seen that much movement before. I do not believe that is what is causing your shifting issues.
    El CicloPath!!!!!!!
    Nov 2012
    Is your rear hub Shimano? There is slight play on most that ive seen and it shouldnt affect your shifting. Did you have a crash leading to your der. Issues? It could be a misaligned der hanger. A lot of shifting issues may be from that or improperly adjusted cable tension.
  1. Shimano XT hubs in BWW wheelset - bent axle?
    By bacon11 in forum Wheels and Tires
    Last Post: 09-10-2012, 09:49 PM
  2. Bent axle?
    By naiku in forum Beginner's Corner
    Last Post: 09-09-2012, 06:25 AM
  3. XPOST XTR pedal M980 axle snapped - axle assembly availability?
    By aussie_yeti in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-12-2011, 09:09 AM
  4. Replies: 2
    Last Post: 05-24-2011, 02:10 AM
  5. Bent axle...
    By SpartyBiker in forum Passion
    Last Post: 01-08-2011, 09:52 PM
