Results 1 to 73 of 73
    Aug 2013
    Anyone running the american classic wide lightning yet?
    Would be very interested in a wide lightning review and american classic wheel sets in general.
    Apr 2013
    I'm also interested in Wide Lightning 29er. I don't know if they are available yet.
    Does anyone know if I will be able to order these wheels from my LBS built up with a single speed rear hub and a lefty front hub? I'd be willing to change forks, but I'd really like a ss rear and I'd rather not spend the money on a new fork.
    Reputation: alicmohamad's Avatar
    Jan 2014
    yes i am using AMC wide lightning wheel set. just installed them a month ago and they are really light, stiff and rolls easy. i recommend them if you intend to change you wheel set.
    I worry how these will hold up long term (like, a year from now). The rims are the same weight as a Crest, but much wider, meaning the walls have to be quite thin to keep the weight the same. It's hard to imagine them having great durability. In my experience, when things seem too good to be true, they usually are. YMMV.
    Reputation: Serotta b1kr's Avatar
    Wow, those am classic wide lightening rims are thin. 32mm outer and 29.3 inner width. In comparison, the syntace w35s are 35mm outer and 28.4 inner. I9s have gone wider and even their enduros are thicker at 30.5 outer and 26 inner.
    The Nox Composites look really good at 35 outer and 27.5 inner (they are carbon). You might want to look at those rims (and consider having dgaddis1 build them up for you!)
    Dustin - looks like you have been building wheels with Nox rims, how durable are they? Can they stand up to all-mtn riding?
    fill what's empty, empty what's full, and scratch where it itches.
    Quote Originally Posted by Serotta b1kr View Post
    Those numbers don't mean much, without knowing the shape if the bead hook you can't really know how thick the sidewalls really are. That said, knowing the weight of the WL rims and how much they weigh, it's obvious the walls have to be thin.
    The NOX rims are the bees knees. And yeah, I think they're current 29er rims (which have a 23mm inner width) would be fine for AM use for most folks. Their AM275 650B rims (with an inner width of 27.5mm) are built for anything short of big air free ride. There's an AM 29er rim in the works too, it'll be wider than the XC rim and have thicker sidewalls for even more durability against rim strikes.
    @2whlfun
    I just installed a set on my Rumblefish and WOW the rim sidewalls are thin but what I noticed MORE is the short distance from the bead barb to the amber tape. The rim sidewalls are really low profile. The tires still had a couple reassuring pops when they seated and I see the normal amount of tire sidewall.
    It now makes a little more sense that they recommend lower pressure since there is hardly any rim sidewall to get dinged up. Looking forward to the trails drying out AND for my Wolfstooth gears to arrive to test this all out.
    2017 SPOT Brand MAYHEM (incoming) 2016 Spot rollik557, 2016 SPOT Brand Zephyr Adventure Bike 55c, Heller 27.7+
    Jan 2014
    Looking forward to your reviews on ride quality, performance and durability.
    @2whlfun
    Wow, I got to put 4 hours of technical sandstone canyon and XC riding on these wheels in Pueblo yesterday. Don't have longterm durability findings but these wheels have totally transformed the ride quality of my Rumblefish! The increased stiffness and light weight is dramatic when compared to the 2012 Rhythm Elite's. Picking lines and having the bike stay there is a great feeling and they spin up much quicker.
    I used to go ride this bike and after I would really feel beat up. In one ride this actually went away! I'm not thrilled with the rear hub engagement. In technical terrain when racheting there is a little free play it seems and I don't get the instant acceleration I'm used to and there is a little bit of stan's weeping around ALL the spoke nipples. Will have to keep an eye on these areas.
    I ran 26psi in the front and 30psi out back even though they recommend lower pressure.
    Quote Originally Posted by twowheelfunman View Post
    ...and there is a little bit of stan's weeping around ALL the spoke nipples. Will have to keep an eye on these areas.
    That means the Stan's is getting under the tape, aka the tape isn't sealing the spoke holes off. I'd pull the tires, clean the rims, and put fresh tape in.
    @2whlfun
    Turns out I goofed & put the o ring between the valve nut and rim like the Mavic's that I'm sed to where these AC's want the o ring on the inside.
    I now have about 100 miles on the Wide Lightning wheels. Really loving the lighter weight and increased stiffness over the 2012 Rhythm Elite set that came with my bike. The old ones were 23mm inner diameter and the Wide Lightning's are 29. can't say I really notice the extra 6mm. I ran the front at 25psi and the rear at 28psi this ride and it felt amazing and not squishy at all. Sealant leak problem solved and I'm totally used to the engagement now.
    Happy Camper!
    Jan 2014
    Nice! Thanks for the feedback twowheelfun. Keep the reviews coming. What tire size are you running front and back?
    I can't wait for my wheels to arrive.
    Reputation: jeffreyjhsu's Avatar
    I've had a set for two weeks now. Got 9 rides on them, mostly crappy conditions, (snow dirt mix). Except for today when things finally dried out.
    They roll really well, my tires measure about 1/2 inch wider than they did on my old 21mm inner diameter rims. I notice much better traction on hills and I'm more confident cornering.
    I've been running 20 lbs in the rear and 19 in the front tire.
    Reputation: d365's Avatar
    How much do you guys weigh? I'd be cutting it close to their weight limit, geared up.
    Bueller? Bueller?
    The guy a my bike shop rides them and likes them. He is recommending them for me, and I weigh 195. I like the idea of a wide rim getting more width out of a smaller tire, to save even more weight.
    I weigh about 172.
    Jan 2014
    Just got my wheels! Wooohoooo! I plan to run them tubeless. Is there are specific sealant that is safe for use for these wheels? Or is there a specific sealant that is harmful on these wheels?
    Jan 2014
    So... I installed my wheels today. Will go for a ride tomorrow. Woooohoooo! Will put in some kms then will write my thoughts on the wheels.
    Used GreenSlime sealant. Hope it is ok and will not damage the wheels.
    Jan 2014
    Got a ride in this morning. Ran 30psi front and back. Using Nobby Nic 2.25 front and rear and running them tubeless.
    I used to use same tires mounted on ZTR Arch EX. Ran them with tubes.
    The whole bike feels much lighter with AC. I used to notice the weight of the whole bike (and felt that most came from the wheels) when I lifted the bike before. But with the AC I feel that the bike's weight is more spread out all over the bike and not concentrated on the wheels.
    Ride quality: Although I was running 30psi (I usually run 25psi when on the Arch) today, the ride felt very comfortable and plush while feeling more stable in corners. I will run them at 25psi tomorrow and see if it will get better.
    My front wheel looks more "square" when viewed from my riding position now with the AC. It looked a little more round on the Arch. As for the tire width... I am not sure if it is wider when mounted on the AC. The mechanic said it wheels looks more massive on the AC. I regret I was not able to take pictures when the the wheels were mounted on the Arch. Would have been nice to have pictures to compare with. Oh well.
    I have to agree with twowheelfun about the rear hub engagement. There is a noticeable lag when you put on the power coming from coasting. But I got used to it (learned to ignore it) quickly enough.
    Will ride it more and post more reviews soon.
    Anyone running the american classic wide lightning yet?-20140325_081840.jpgAnyone running the american classic wide lightning yet?-20140325_081855.jpg
    Jan 2014
    Went to a field and practiced some tight figure eights and track stands... The AC hubs have so much lag before it engages. The lag is so big that I had to re-learn the skills and employ different techniques to execute. Am a bit disappointed with the hubs but am willing to learn to like them coz I like the wide wheels a lot.
    More reviews coming.
    Cleavage Of The Tetons
    Does anyone know if the front is convertible for 20mm and 15mm?
    "We LOVE cows! They make trails for us.....
    And then we eat them."
    Jan 2014
    Quote Originally Posted by rideit View Post
    I believe so. I was able to buy a conversation thingy for the rear hub.
    Reputation: thickfog's Avatar
    Oct 2010
    AC hubs are convertible.
    CRAMBA Chairman
    Sim
    Sim is offline
    The hub on the Wide Lightning is convertible from 9mm to 15 mm. The 20mm front hub is a different hub and is not convertible to 9 or 15mm.
    Quote Originally Posted by Sim View Post
    ^This.
    Not all convertible hubs are convertible to all standards.
    @2whlfun
    I weigh 184 all geared up. I'm running a Specialized Butcher 2.4 in front at 28psi. Out back it's a Maxxis Ikon EXO 2.35 at 30psi.
    Still loving the light snappy ride! I did have a rock flip up onto the front rim and it put a pretty good dent in the rim wall but it's still true with no affect to tire seal.
    That's a great indicator as to how thin the walls of that rim are. Check back in a year and let us know how they're holding up!
    A couple of initial reviews here.
    Jun 2010
    Since they only sell complete wheels they are not available for Lefty users.
    Oct 2013
    I've been running the Wide Lightning rims for a couple of months now. I run them with Hans Dampf 2.35s on my Bronson C (27.5). I really like the ride quality. I've put many hundreds of miles on them and they are holding up beautifully. I bought them to ride as a backup to my Enve AMs but I plan on using them as my primary wheels for a while. I've mounted the same tires on both wheelsets and compared the width and the tires mounted on the Wide Lightnings are much wider in comparison.
    Mar 2011
    I would like to share my problems to the forum, regarding AM Classic AM 27.5 wheelset that I ride a few months now. I bought them on the 3d of January 2014 and I found them awesom at first place. Unfortunately very soon rear rim bended 3 or 4 times. I run them tubeless at low pressure 25 PSi on both wheels but I am quite low weight about 68 kg. I use that pressure on my earlier 26 wheelset, a Sun Ringle Charger Pro, 3 years now without problems. Tires are Maxxis HR 2 TR. Same tires on Sun Ringle.
    I send email to AM Classic and I received an answer from their German distributor that I could buy new rims at 125 euros + postage...and run more pressure.
    Anyway I repaired the rim and tried with tubes (not possible tubeless any more) with a Pacenti 2.3 and I had the same problem. 32 PSi now and every 2 rides I have a bended rim...Something is definitely going wrong. Front rim has no problem so far. I know this is not the "Wide Lightning" but is the same configuration.
    I send an email to the company and wait for their answer.
    Oct 2010
    AC customer service is not the best I hear. You may be waiting forever.
    CRAMBA Chairman
    Mar 2011
    Quote Originally Posted by thickfog View Post
    May be....but I will not return as a customer...and not just me..
    @2whlfun
    29 inches just updated their review and they stated that these babies have a carbon ride quality. Happy to hear that as they a huge savings over carbon anything.
    I'd like to read your impressions of the 650 Epi. Are you planning a review as indicated?
    Jan 2014
    Quote Originally Posted by grbadave View Post
    Are you referring to me and my bike grbadave? If you are, I will write a review of how my Epiphany performs with the Wide Lightning as it is a Wide Lightning thread.
    As per my previous post, I ran the wheels with 30psi before when I first got the wheels. Now I run them with 22 psi front and 25 psi rear on wet and muddy days, 25psi front and 28psi rear on dry, fast and rocky trails. And i pump them up to 35psi front and rear when riding on road on the way to the trailhead where I lower the pressure to appropriate levels for the trail. It is raining now where I am and I will experiment with 20 psi front and 22 psi rear tomorrow morning. Will give feedback on how this feels. I have a feeling i can use this for my wet setting and use 22 psi front and 25 psi rear for dry conditions.
    So far, I really love the way my tires grip the trail. Being able to run low pressures is so good! So much traction at these pressures without feeling squirmy. At slower rocky portions, i can feel my tires "hug" the rocks. Crawling up rocks feels so sure footed. During wet and muddy trails, having low pressure inspires so much confidence especially when going over roots. I still ride cautiously though.
    I am careful with hitting edges when running low pressures so I make sure I lift both front and rear wheels when approaching edges. I have not hit the rims on the edges so far.
    The Epiphany performs so well with these wheels coupled with the Fox CTD suspension. I press a button and the ride changes when in Climb, Trail and Decent modes. Now i wish I had Fox DOSS seatpost to complete the package.
    Speaking of dropper posts and Epiphany, I am glad I am using a 1x11 drivetrain so I don't have a front deraileur...As the internal cable routing of the Epiphany XC Carbon for the front deraileur will get in the way of lowering your seatpost. You will need to cut the seatpost so you can lower it for downhills or drops.
    The Epiphany with WideLightning and Nobby Nic weighs in at about a little less than 25 lbs. I think I can get it down to 24 lbs or less by using narrower tires...which is supposedly a benefit of the Wide Lightnings. When my Nics wear out, I will try Rocket Rons.
    (please pardon the off topic comments).
    Thanks. I have am old Truth w/ 26" Am Classic wheels. I love the quiet hubs and would like to know if these new wheels are qiuet. When I ride with a friend w/ Stan's wheels I can't believe how much the ticking drives me nuts!
    Because I may replace the Truth soon, any other info on the Epi would be appreciated. What fork do you use? TALAS used to be the model Ells paired it with, but now it look like it's not offered in the Ells build kits. And how do you think the steep geometry works with this amount of travel plus the bigger wheels?
    Quote Originally Posted by BOSERO View Post
    Jan 2014
    The hubs of the Wide Lightning are very quiet too. My only complaint about the wheels are the big lag before engagement of the hubs.
    I ran 20psi front and 23psi rear yesterday and today. I really love this setting for slower wet and muddy days.
    Re Epiphany. I will PM you my thoughts so as not to hijack this thread.
    Four months into riding on my 29r Wide Lightnings. No problems at all. I weigh 165 and run around 19 front and 20 rear. I am a very smooth rider.
    Ride quality, traction, everything is better and I put on the tires from my old wheelset so I'd be comparing apples to apples.
    I'd recommend these wheels to anyone looking for a performance increase.
    May 2010
    Same thing here - a big big dink in the rear WL rim following a steep climb on trail with loose flint rocks (think about the size of a large coffee mug) running Nics 28-30 psi. Needed a compressor to inflate these 1st time, same tyres go up easy with a track pump on stans rims. That said they ride well and I'm very happy with my current rig setting pb runs all over the place.
    Jan 2014
    So... the hubs on my Wide Lightnings finally gave in and failed on me while in the trails. Luckily the trails were near my home and was picked up by car. I love the rims but was wary about the hubs even from the beginning. I have to admit that my complaint about the hubs was the lag in engagement. But I had no idea about the durability of the hub. Well I suppose this answers my question.
    I am still not sure what is wrong but I am pretty sure its the rachet/pawl system. Will bring bike to LBS later to have it checked out. I hope that something just got loose... but if the rachet/pawl system failed, I will not even claim warranty (set is only a few months old) on it and upgrade the hubs to something more reliable for peace of mind. I bought the wheelset for the rims after all.
    I hope that this does not happen to anyone else out in the middle of no where.
    See the video here
    https://www.youtube.com/watch?v=3GGQ...SiiztkYb9Gfe_A
    Jan 2014
    Update: Brought the wheelset to LBS where I bought set from (local distributor of Am Class). After they checked it, they said that it was the XD Drive for the 1x11 cassette that had the problem and not the hub. Thank God! A spring in the XD Driver was supposedly out of shape. So mechanic bent it back to shape, and assemble it back and declared it good as new. I was hoping he was right. After the service, the hub made more noise when coasting. Before service it was very quiet. I did not mind the noise... all I wanted to do was ride.
    So I went for a ride this morning. I ended up walking home as the hub or XD drive failed again.
    I am not sure what is really the problem... the Hub? The XD Drive? Will go to shop now and have it checked. Will update you guys as soon as possible.
    The XD Driver IS the freehub body. There's no springs on the cassette.
    Jan 2014
    Correct. Please pardon my mistake. I did not understand hubs and freehub bodies before this incident.
    As per LBS... it is the XD driver that is the problem. I don't know if this problem is a factor of the hub. If not, please pardon my earlier post on the hub failing on me. It seems that it is the XD Driver that failed.
    Will update this issue again later when I get feedback from my LBS.
    Quote Originally Posted by dgaddis1 View Post
    Jan 2014
    So... after 3 attempts of the LBS to fix the XD Driver freehub body (walked home 3 times) they finally decided to warranty the XD Driver and replaced it with a brand new one. I was able to ride 30kms trouble free yesterday. I have to admit that those 30kms were trouble free but not worry free. I was worried that whole time as to the durability of the freehub body and whether it will fail on me again. I guess only time will tell...
    As of now, I am enjoying the wheels and enjoying riding them!
    Jan 2014
    Been over a week of trouble free riding of about 40kms/day. Woooohooooo! Love these wheels. Praying free hub body holds up.
    @2whlfun
    Ok, after 6 months on the wheelset the front is still true and running perfect despite the minor sidewall ding caused by a rock flipping over into it.
    The rear has now received 3 small dings and one major ding that also deformed the sidewall toward the outside. All this damage happened while running an Ardent Race EXO 2.2 at 30psi. I ride on the Colorado Front Range mostly. The big ding happened while riding the Backbone Trail North of S Mountain in Salida. Very rocky and had a blast while doing the damage.
    No air loss but have bumped the pressure up to 35psi. While climbing am having a few more spin outs on roots and dust covered rocks.
    I had the same problem with the Bontrager stock rear wheel but it had air loss issues. Not sure where to go from here. The trail 29er in my opinion is a blast to ride but (for me) requires a light rear wheel.
    Upset BOSERO is right - TOO much lag
    You are spot on with your review, the rims are great but the rear hub is driving me crazy. I expected much better. Will have the rear hub replaced sooner than later. The lag is way too much for what we paid for the set of rims.
    Reputation: JamesT-XYZ's Avatar
    Oct 2014
    Looking to buy this wheelset or a wide chinese carbon set soon. Does anyone have MAJOR objections with this wheelset, before I make a decision? The lack of hub engagement points doesn't bother me, FWIW. Thanks!
    Oct 2014
    Also, I didn't see the Wide Lightning 29er rim weight listed on the AC website. Anyone know what it is?
    Reputation: jeffrey j's Avatar
    1569 grams
    Oct 2014
    Re: Anyone running the american classic wide lightning yet?
    Quote Originally Posted by jeffrey j View Post
    1569 grams
    Thanks for the reply, jeffrey j. I know the overall wheelset weight. I'm looking for the rim only weight.
    Ahhhh...I read this on the twentynineinches review the other day:
    "So in conclusion I have no numeric proof that the Wide Lightning wheels are less durable than other, heavier rims simple logic would suggest that a sub-400g cannot be as tough in all regards"
    Based on his comment, maybe he got some info from AM on the actual rim weight??
    The WL rims are about the same as a Crest rim (385g). I got that figure by backing out the hub, spoke, and nipple weights. There's some estimation on spoke weights since I don't know the exact length, but it's clsoe enough.
    Oct 2014
    Thanks for the info, dgaddis1!
    Quote Originally Posted by jeffreyjhsu View Post
    I have nearly a year on these wheels now. The difference in performance still amazes me. More traction everywhere. More control in technical terrain and an overall feeling of increased confidence everywhere. I tell my friends that riding these wheels makes almost as much of a difference as going from 26" wheels to 29". I still weigh around 165 though I'm now running 18 & 19 pounds of tire pressure.
    Nov 2014
    Been eyeing these wheels for a while now... going to pull the trigger this month but before I do wondering if anyone can think of comparable wheels to the Wide Lightnings?
    From what I know it seems they are in a class of their own, factoring width, weight and cost?
    Sounds like the rear hub has horrible engagement, see post #39. Not sure how these wheels sets are in a class of their own....Maybe I'm missing something, but a quality rear hub is a pretty big factor in my book.
    EBenke
    Nov 2014
    Guess it depends on one's needs out of their components. Just speaking from my own experience and what I am looking for.
    I need wide rims that can support high concerning loads. Run lowest pressure possible and wide enough i-width to try this new 29+ (29x 3.0 inch tires) for some winter riding. I come from a DH background and rarely attack technical climbs. I also don't race XC, thus don't really require high # of engagements.
    I have owned and ran the A.C. Race 29er wheel set of my Trance X 29er for 2 seasons. I know what their hubs are like, not amazing but ok. More looking for weight savings and long with wide stiff rim/wheel to improve handling. All the while keeping cost down say under $1000. I have 3 bikes can't afford to make it rain on each of them. Only other option is to go the wide Chinese carbon wheel brands. Which are getting some great reviews but I am also thinking of resale. Worried if/and people are open minded with chines brands (even though 90% of their bike is manufactured in a mass production line somewhere in Asia). Lastly I personally wouldn't buy any set of used carbon wheels but would for alum as damage/abuse is easily visible on alum.
    Nov 2012
    So now that some people have had time to ride these a season, what do you all think of the rims?
    Has anyone replaced their rear hub? If so, what did you replace it with, does the new hub have better engagement and is the noise level of the hub tolerable when coasting? Mine have been hanging in the garage for 2+ months. I either need to replace the rear hub to use them or sell them.
    Nov 2014
    Quote Originally Posted by huffman View Post
    Use your warranty? If it is up why not just replace them with DT 240 hub, works with same j spoke bend
    Quote Originally Posted by DiscoRover View Post
    Not broken. According to the LBS that I bought them from there is nothing wrong with the hub. Purchased them new Sept 2014, rode them several times then put my old wheels back on to compare, old wheels had better engagement so the AC WLs have been hanging in the garage collecting dust ever since. I love everything about the wheels except the rear hub, that's a deal killer for me. I bought new wheels to get quicker engagement now slower. Thanks for the DT240 suggestion, will check that out.
    Nov 2012
    Get the DT 350 from.chain reaction for $105 right now and its only a smidge heavier than the 240
    Nov 2014
    Would they happen to be a 29er set? I am actually looking for a set to try...
  67. #67
    May 2012
    Any updates on these? How are people liking them? Anybody switch from Stans Flow EX? How would you compare stiffness between the two? Etc. etc.
  68. #68
    Feb 2015
    I've been running Wide Lighning 27.5s for about 6 months now on my SC Heckler (and as of two days ago my Ibis HD3!). My riding weight swings between ~140 and 150 depending on Camelbaks and cheeseburgers. I run pressure at 18-19 PSI up front and 21-22 PSI in the back.
    With the Heckler starting at 31lbs, I went on a bit of a weightweenie mission, and these were part of it. Stock WTBs were 2100g. These came in just shy of 1500g, so mission accomplished in that respect. I also resolved not to let the new wheels dictate how or where I ride. If I taco'd one on a bad landing or dented a wall on a rock, it would just have to be lesson learned. In short, I've been seeing if my weight would let me get away with riding XC weight wheels on AM terrain.
    All I can say confidently is so far so good. To be clear, I'm no badass, and some of you would no doubt put these through the ringer better than I have. What they've handled under me are 3.5 foot drops to flat, a good crash off a meter high wooden launch ramp to an off camber landing that put an inch deep bite into my TLD A1, many similar jumps where I managed not to eat shit, and being surrounded by loads of rock of all shapes and sizes. All I have to show for it is a pea-sized scratch through the logo.
    To be honest, I expected most of that. They're rated to 235lbs, so should be plenty strong for a guy my size to do whatever my fairly well developed sense of self preservation would allow. My biggest concern was that what must be quite thin sidewalls wouldn't hold up to side strikes from rock. Again, so far so good. I ride through lots of loose rock and in and around rough boulders that seem just the right height to smash up my wheels. I attribute their survival partly to being tougher than I expected, but mostly to being protected from the vast majority of impacts by the tires. The sidewalls are pretty shallow and there just isn't that much exposure.
    Survivabilty aside, these wheels perform great. They do tend to square off your tire profile a bit, so it may take a minute to get used to the transition to the side knobs if you're used to something rounder. It's nothing dramatic. You can run them at pretty low pressures which obviously helps traction. I feel like cornering traction is noticeably improved. You can trade in the performance gains for weight by using narrower tires. i.e. A 2.2 rides bigger on the Wide Lightnings than it would on a conventional width rim, so you can get the same performance from it that you might with a 2.4 on a narrower rim.
    The big knock on AC wheels has been the relatively slow hub engagement. And, on low speed technical climbs it is certainly present. Industry 9s would be better for that, for sure. That said, I do a lot of those sorts of rocky climbs and adjusted pretty quickly. There's nothing I could clean before that I can't now. Upside is they're really quiet, really light, and based on the road set I've had for a several thousand miles, reliable.
    Anyway, I'm pretty happy with them and have no qualms about recommending them for fairly aggressive riding to people within 20lbs of me. They're plenty stiff and plenty tough for riders in that weight range. I don't have any basis to judge them for heavier riders, so look to other reviews for that.
  69. #69
    Jan 2015
    I'm 6'2" 210 pds and will ride a Yeti SB5C.
    Any experience or comments? Are they strong enough?
  70. #70
    Feb 2015
    Thought I'd post an update on these. They're coming up on two years in October and are still holding up well. I'd guess I've put 3000 or so miles on them. I've picked up three dents in the rear rim, all on one ride. I flatted off a good-sized drop and rode 6 miles out on a particularly rocky trail with 9 PSI in the back. I didn't risk bending them back out as they hold air fine and trued right up. No problems in the couple of months since that happened. No issues whatsoever with the hubs.
    To be honest, I find myself frequently tempted to get a sexier wheelset. The hubs are relatively slow to engage, the graphics are pretty terrible (the new ones are much better), and the banged up rim does give me an excuse. But, they're legitimately stiff, durable, wide, weigh only 1.5kg, and can be had for $700-800 new. What else ticks all of those boxes for anywhere near the price?
  71. #71
    Apr 2013
    Quote Originally Posted by JohnnyVV View Post
    Do you, or does anyone else, know if they made any improvements to the rear hub engagement in the last couple of years? Since it seemed to be a common gripe I wondered if they'd done anything about it.
    Was tempted but that's putting me off a little.
    cheers...
    Al.
  72. #72
    IIRC, AC has a good rep for lacing up a new rim to your hub for a reasonable "crash replacement" cost.
    Whining is not a strategy.
  73. #73
    Feb 2015
    Quote Originally Posted by kosmo View Post
    They quoted a new rim at $125, iirc. Building it up would have cost that plus spokes and labor locally. Not terrible but I ended up getting a set of Ibis carbons instead.
    The Wide Lightnings are still holding up fine and are close to 200g lighter than my new ones. They're now my XC wheelset with a Rocket Ron/Thunder Burt combo that I don't think would play well with the wider Ibis rims.
    @alrsv1
    No, I don't think they've changed the design of the hubs. There's nothing wrong with the design really; they just don't prioritize engagement speed. They're very light, very quiet, and have been reliable with no real maintenance, so they do have other things going for them.
  1. Replies: 5
    Last Post: 03-28-2014, 02:03 PM
  2. American Classic
    By gal in forum Weight Weenies
    Last Post: 09-26-2013, 10:15 PM
  3. Replies: 0
    Last Post: 11-09-2012, 10:38 PM
  4. American Classic SS Hub
    By MRakus in forum Singlespeed
    Last Post: 09-10-2011, 12:45 PM
  5. American classic hub?
    By dirtT in forum Wheels and Tires
    Last Post: 06-16-2011, 04:52 PM
Members who have read this thread: 14
