Results 1 to 52 of 52
    Save Jesus
    Reputation: beanbag's Avatar
    Anybody tried automotive tire bead sealant?
    It's the stuff you see people gopping on the bead of car tires before mounting them. I think it's supposed to start slippery, and dry up rubbery. More viscous than Stan's, and doesn't contain little particles that can cause bead leaks. This is for mounting the tires only, not to use as a sealant for punctures.
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    I've been using and recommending moldbuilder latex, which sounds exactly like what you're describing, for some time now. it has never failed to allow any tubeless set up (stan's rims, regular rims + tape, split-tube, etc.) to seat with a floor pump, first time. I have also not burped any tire on any tubeless set-up since starting to use it (though I had previously only burped a tire once while riding a tire that was WAY too low in trying to finish a race).
    A buddy of mine turned me on to it and it is worth its weight in gold for setting up tubeless.
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
    Quote Originally Posted by meltingfeather
    So the answer is No
    Quote Originally Posted by jeffscott
    So the answer is No
    thanks for pointing out what a 5th grader could have. that's valuable.
    Reputation: Salami's Avatar
    Quote Originally Posted by beanbag
    What exactly are you asking?
    The stuff that you see "gopping on the bead of car tires before mounting them" is a lubricant to help prevent damage to the bead of the tire during mounting and make it easier to seat the beads.
    It serves no purpose as any kind of sealant.
    Is there something else you are referring to?
    Reputation: A1an's Avatar
    meltingfeather...where would I find this latex mold builder locally? Is this something found at a hobby/craft store or is it more of a Home Depot type product? That valve is still giving me problems and I think I may take your advice and see if this fixes the issue.
    Signature
    Reputation: schneidie's Avatar
    Mold builder's latex is definitely a craft store type item. I bought mine at Michael's.
    Got some strange looks buying 2 quarts of that and nothing else from the pretty young lady working the register.
    Build.
    Ride.
    Repeat.
    Save Jesus
    Quote Originally Posted by Salami
    No, I am referring to "bead sealer" or "bead sealant". Search the internet- you will see many products.
    http://www.rematiptop.com/parts.php?sid=13
    Reputation: Gman086's Avatar
    So the answer is No
    Exactly! I have to laugh at all this paint brushing on bead sealants. For crying out loud peeps - soapy water lubes the beads plenty well to mount tubeless no problemo and if Stan's is too expensive for ya then just make some homebrew. What is up with all the UNNECESSARY tomfoolery???
    Have FUN!
    G MAN
    "There's two shuttles, one to the top and one to the hospital" I LOVE this place!!!
    Save Jesus
    This seems interesting.
    How lubricating is it?
    How fast does it dry out and stop lubricating?
    When it dries, is it sticky like rubber cement?
    How well does it clean off?
    RIS
    RIS is offline
    It's just soapy water, dude. And probably a little pond scum growing on top, too.
    It's just to keep the tire machine's lever from catching on a dry rubber bead and ripping it, and to help the bead to slip onto the wheel, and then when you hit it with the air, to help the tire to slip up onto the area where it's supposed to seat without taking so much air pressure that you blow the lip off the wheel with a loud "bang". It also reveals a bead that is not fully seated with little soapy bubbles.
    Save Jesus
    Did you look at my link or do a web search?
    I don't think it's simply a lubricant.
    Quote Originally Posted by Gman086
    Have FUN!
    G MAN
    I went to latex after soapy water didn't cut it. It's not about lubing the bead but about the viscocity of the latex being the extra bit you need to trap enough air to get the tire inflated. I went from some set-ups being big hassles, even with 30 gallons of air at 175 psi and plenty of soapy water, to first time floor pump set-up every time.
    An added benefit is ease of adding sealant and reinflating, because in general the bead stays put when painted with latex rather than popping off and having to be reseated.
    My Stan's rims inflate without soapy water, so is soapy water tomfoolery?
    Using the latex has VASTLY improved my tubeless set-up experience, with all different kinds of tubeless set-ups. All of the threads with people pulling their hair out about not being able to get the tires seated and the 100% success I've had with it tell me it's not exactly uneccessary.
    Quote Originally Posted by A1an
    I also dab it at the base of valves when installing. Like burps, I had only had one previous problem with a valve, but none since, and I don't expect I ever will.
    Definitely hobby/craft store item (Michael's, Hobby Lobby, etc.) It will be in the sculpting section. I had a hell of a time finding it the first time I went to look, even with a picture, the product name, and two store employees trying to help me out. I guess the people that go in there for it know where to find it and don't need help.
    Quote Originally Posted by schneidie
    How about throw in some glitter for your homebrew mix?
    Yeah, I don't see the focus on lubrication, and that's not what I use it for, though I guess it is pretty lubricational. I use it to help trap air during the initial inflation, and to provide a bit of adhesion and positive seal between the rim and bead.
    It starts to dry out in a few minutes. I usually try to work quickly with it.
    It's not tacky like rubber cement... it's latex, so just rubbery.
    Cleaning off is cake. If it's still wet (always is after I've inflated), it rinses off with water. When it's dry is very similar to dried stan's in a wheel... just rubbery with a little adhesion to the surface. The easiest way (and it's pretty easy) to get it off when it's dry is just to rub it while still dry, either just with your hands or with a dry towel.
    mf, have you tried the weather stripping in the tire channel trick? That seems to really improve tubeless success for difficult to mount tires (esp thin walled XC tires which seem to be much more of a problem than FR/DH tires with thicker sidewalls). Would seem to me to be easier than your method considering you only do it once.
    Have FUN!
    G
    Have FUN!
    G
    I haven't.
    Isn't that tomfoolery? Kidding.
    I have heard of it but I didn't want to mess with re-taping and the bead painting is actually super easy and quick, makes a great bead seal, and offers the perceived additional protection of having the bead "glued" to the rim.
    I've also heard of people having issues with the weather stripping compressing after the initial inflation, which makes sense, and not working as well after that. Don't know anything about that, since on my first try I found something that works great for me every time.
    RIS
    RIS is offline
    I've busted and balanced automotive tires for a quarter-century or so. The stuff that you slop onto the bead of the tire right before throwing it on the tire machine is just plain old soapy water.
    Reputation: EstebanRapido's Avatar
    Jun 2010
    I work for a NAPA auto parts. We are talking about two different kinds of automotive tire products. There is ruglyde or beadeze, a lub for mounting tires. Then there is Amerseal, a stans like sealant.
    http://www.amazon.com/BeadEze-Tire-L.../dp/B000J1TY7K
    http://www.amazon.com/American-Seala...sr=1-3-catcorr
    And no, I don't know the differance between stans and maerseal or what people use Amerseal on.
    At the risk of speaking too soon....I think this did the trick on my leaky valve issue! Found it Micheals and got it for $9 thanks to a coupon in the mail. Thanks for the info!
    Signature
    VENI VEDI BIKI
    Reputation: skankingbiker's Avatar
    Do you still use stans or something else in the tire to seal punctures?
    Quote Originally Posted by skankingbiker
    yup, the latex is just to get the initial seating and add the protection of a "glued" bead. i mount one side of the tire, put stans in, mount the other side of the tire, work my way around both sides painting the latex on the beads, then air up with floor pump, first try everytime.
    I tried 'painting' the beads with silicone for the first time a few months ago(and I've setup a ton of tires ghetto) and I have to say it worked AWESOME. What I really like is the fact that with the split tube method I know I have a sealed bead to the split tube which means no burps.
    I put a home-brew latex mix inside (without Slime), used it until it dried and now am using pure Slime without the latex. My results have been very good, the Slime doesn't weep out of the tire because I believe the dried latex has made a air-tight barrier.
    VENI VEDI BIKI
    thanx. i am intruiged by the diffrent gt methods and am considering yours for my new jabber buid. it just seems that GT is kinda hit or miss. I would be using BWW pure rims and a WTb 2.55 wierwolf in front and 2.1 wolverine in back.
    I am hesitant to go this route, as I have read a lot of horror stories about people's GT set-ups blowing up on the trail and being quite messy. On my 26, I am able to run 35 PSI tubed without much problems with flats. It sems most people are running GT around 30 psi. I dont know if the extra 5 lbs is worth the hassle and risk of a blow off.
    Save Jesus
    Today I was at a Napa Auto Parts store and saw this:
    It smells strongly of solvent and dries to a thick, sticky black goo. Definitely nothing like soap water.
    There were no instructions on the bottle, but the guy at the parts counters said you goop it on the bead of a tire before mounting.
    However, the dried form seems too sticky, and I would be worried about the tires getting stuck on.
    Doesn't sound like something I'd want to put on my bike tire beads, and clean-up sounds like a b**tch.
    Reputation: scoutcat's Avatar
    Have FUN!
    G MAN
    agreed, why make more work for yourself? do it properly with appropriately sized tires and you wont burp or get blowoffs. you dont need to glue your tires to the rims with mold builder - overkill.
    That is why the OP is looking for some one that has actually TRIED IT.
    Thanks once again for your constructive input.
    I use something that sounds like it serves a similar purpose, which is why I posted my experience.
    Jan 2005
    That stuff is only for old rusty crappy steel wheels that won't seal and it works marginal at best . What would work good is "Murphy's mounting compound" it is a water solubal goop used for bead lube and mounting industrial tires.
    Quote Originally Posted by scoutcat
    did you read anything that i wrote? painting with latex is primarily for seating(sealing) tires, for which it works perfectly. every tubeless set-up i do is floor pump-- first time, every time, people recommend buying $200 compressors to fix the difficult set-up issue, even that compressors are a 'must have' for tubeless, and you're saying my $13, 100% bulletproof solution is overkill?
    i was looking for a solution to a problem (difficult tires to seat) and found it.
    Your welcome....
    Post what you have used brand etc....so we may judge ourselves.
    Natter Natter natter
    Sounds like you have a system, guess what so does everyone else.
    Probably overkill, and definately over sold.
    Your welcome....
    You obviously don't need anything to start judging... and I already posted all info on the product I use that "sounds like it serves a similar purpose," which is bead sealing for mounting tires, according to the OP.
    What have you got?
    You've got to be kidding me. Over sold?!? I only ever post up about it when I think someone might benefit. What have I got to gain? Whether or not you think it's overkill, it cheaply and 100% solved a problem. How that can be construed as overkill when you've never used it or seen the benefits, I have no idea.
    What's your point with these posts, Jeff?
    What have you got?
    So again havn't tried solvent based automotive bead sealer....continues yammering about latex...
    Since I have not tired automotive bead sealer I don't have naything to add.
    Continued yammering? I posted once on it and answered a couple of questions. You've got a personal problem? I already PM'd you about this BS sniping to try and settle whatever beef you might have in a reasonable and private way. WTF?!?
    Yet you keep spewing...even quoting my pictures to spam the thread.
    Continued yammering? I posted once on it and answered a couple of questions. You've got a personal problem? I already PM'd you about this BS sniping to try and settle whatever beef you might have in a reasonable and private way. WFT?!?
    Stay on topic or STFU.
    back at ya... how about get on topic? ths is ridiculous. you haven't posted anything even remotely related.
    And how does this relate to the topic?
    Last word-itis maybe.
    Sorry for all the off-topic crap, people. I don't know what jeff's problem is. i tried to take it to PM and resolve it and he's not interested... so he's on my ignore list until he wants to be a big boy and hash whatever out so we can avoid these ridiculous flame wars.
    I thought I was just contributing to the thread.
    ~peace
    ~peace
    So is this your last word?
    Save Jesus
    Quote Originally Posted by dadat40
    The Murphy's doesn't sound like it dries and seals, though.
    I4NI
    Reputation: S_Trek's Avatar
    May 2010
    MF have you always been 100% Ghetto?(I noticed the cut tube) or are you using tubeless tires?
    There....Are... Four...Lights!
    Reputation: chas_martel's Avatar
    Why don't you guys just use UST rims and tires?
    Nobody cares...........
    I4NI
    May 2010
    Quote Originally Posted by chas_martel
    I'm a tube guy BUT the tubeless people I've been(including one DH guy who rides Whistler) talking too all say its a weight issue.
    Hi.
    Reputation: jtmartino's Avatar
    Jeff Scott
    Here to provide input
    But not related to the OP's topic
    And he'd much rather bash on MF than talk about bikes
    And construct his posts in a poetic fashion
    We'll assume the bad spelling and grammar are poetic license, too.
    Quote Originally Posted by S_Trek
    I have different set-ups on different bikes, as well as set-up sometimes for people I build wheels for.
    The wheelset pictured is split-tube-less on Salsa Delgado Race Disc 29er rims with Geax Saguaro TNT tires on my rigid ss.
    I run split-tube-less with Bontrager XDX TLR tires on Velocity VXCs on my dually.
    I have standard Racing Ralphs on Stan's 355s with just yellow tape and a valve on my HT.
    I like tubeless ready tires, but I ride 29ers, so no UST for me.
    Reputation: twowheelsdown2002's Avatar
    Because then you would have no purpose in life.
    Without us, you would not have any posts to troll with your close minded ignorance.
    I had thought about trying contact cement on "split tube ghetto" setups. As it is now, the beads pretty much end up bonding to the tube anyways, and I have never had a tire burp with "split tube ghetto". But contact cement would have them completely glued together.
    Seems like it would be almost impossible to burp if they were bonded together.
    I4NI
    May 2010
    Thank You!
