Results 1 to 16 of 16
    Ano fading on rear hub
    Curious if others have experienced fading of the color on their anodized hub. I have a set of red I9 hubs. The front is still red but the back has turned pink. I haven't scrubbed it with a wire brush or used some heavy solvent. I cleaned my bike yesterday and just noticed it. The wheels have almost 3 seasons on them.
    Not a huge deal, the hub still works fine but I never thought it would fade so soon or if it did, not the whole hub.
    Patrick
    I have an old Race Face headset that used to be red. Color doesn't last. Keep your bike indoors, is about the only prevention I can think of. Or maybe there is a UV resistant spray or wax you can put on it?
    Found this:
    4. Does colored anodizing fade, peel, or rub off?
    Following the dying of an anodized surface, a sealer is applied to effectively close the pores and prevent fading, staining, or bleeding out of color. A properly dyed and sealed component will not fade under outdoor conditions for a minimum of five years. Because the anodic film is molecularly bonded to the sub-strate, and this film absorbs the pigment to the depth of the coating, the colors will not chip or rub off.
    All-Brite Anodizing -- Frequently Asked Questions
    Now that I think about it, I have a Santa Cruz anodized frame that spent many, many hours in the Arizona sun, and it seems to be the same color blue as new. But that red headset faded bad.
    So there must be different qualities, or it is the way they seal and finish the job that determines the durability. With that in mind, maybe you have a warranty claim.
    Its likely that different colors react to the sun differently as well.
    But that I9 stuff is pricey! It should look as good as the price tag would suggest. They should do something for you.
    Feb 2010
    Depends on the quality of the sealer and application that they used. I have a 2yr old Titus anodized frame that use to be bright orange and now has faded to a peach/chamagne color but my blue cane creek headset still looks new. And the only time it has spent in the sun is the ride in back of my truck to the trails.
    Mountain biking never gets easier... You just get faster
    I planned on calling them and asking if this was common and if not then maybe see about getting a new hub. If it is common then I can live with that.
    I have a ano grey Motolite. It's a 2009 I believe. Ano still looks great. I have heard of people with Ano frames fading.
    Either way it is still a great hub and wheel. Just lost a little of it's bling.
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    call 'em if it bugs you. their service is fantastic. i don't think it would bug me so much except that it's different front and rear. if they matched i think it would be more tolerable. it is, after all, a wheelSET
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
    Laker and a Trail Blazer
    Reputation: Broncstad's Avatar
    Yup. Call em. I was looking at my black i9's I was thinking they looked kind of rootbeer brown. Seems they were never completely black that o can remember, but it my first bike so I could have overlooked. Bought 10 months ago
    Former Bike Wrench
    Considering the price, I'd think they could do better than that...I got 10 year old Shimano LX hubs that aren't faded and they cost less than 1/10th the price.
    Quote Originally Posted by patrickd72 View Post
    Yeah but you paid for that bling.
    If color fading doesn't have to happen, then a company that charges probably a 500% mark up should figure out how to provide anodizing that doesn't fade.
    Reputation: shiggy's Avatar
    Dec 1998
    Patrick
    Red anno is notorious for fading. Have never heard of fading being covered by warranty.
    mtbtires.com
    Smilinsteve's post is right on. Most of the time the color fades
    is a bad seal job. The two main ways to seal the anodize is with
    boiling hot DI water or with a nickle acetate seal which is a better
    seal. I remember one time I red anodized a skid plate for my friends
    race bike. By the end of the first race the skid plate had turned
    pink. He was POed because his friends gave him a bad time about
    it. Turned out the seal I had used on it had gone bad.
    Best, John
    Red color is the first to go/fade. For some reason red, in all forms, is the most likely to fade. This is true with ano, PC, or paint.
    Yes they are expensive wheels and I thought the ano would hold up better. I mean it's pretty faded and the front looks good as new. So I will call and inquire.
    Well I called I9 yesterday and was told that it is not a common problem. He said it probably wasn't sealed good. So smilinsteve was right. He told me to send the wheels in and most likely they would replace the hub because it sounds like a warranty issue. He also said they would replace bearings if needed and it would be free labor.
    Anyways, like Sram their CS is excellent. I appreciate everyones input.
    Patrick
    Patrick
    Great!
    That raises them up a notch in my book. Companies should realize that treating a customer well, like they did, will pay for itself in word of mouth reputation boosting, and customer loyalty!!
  1. FTM Fading??
    By Chuey83 in forum Titus
    Last Post: 10-18-2010, 11:16 PM
  2. Fading Away.
    By mikesee in forum 29er Bikes
    Last Post: 10-16-2008, 07:39 AM
  3. WW bikes fading away...
    By curtlo-dork in forum Weight Weenies
    Last Post: 09-21-2007, 07:08 PM
  4. Not Fading Away
    By Portola Vince in forum California - Norcal
    Last Post: 08-21-2005, 05:10 AM
  5. Fading Hopes
    By Bigwheel in forum Brake Time
    Last Post: 05-21-2004, 01:18 PM
