Results 1 to 6 of 6
    Reputation: in the trees's Avatar
    Mar 2005
    American Classic Front Hubs
    Yay or nay? How are these hubs (particularly the front hub) holding up? I've heared of sheared rotor mounts but did this just occur on older models, or newer versions as well? Before Disc Reinforcing Rings were used? And okay to use with180mm rotors?
    Used them heavily for years and never had an issue. Light and reliable. Rear hub engagement is too low (feels like 12 Poe due to ring drive).
    ^ Agreed, those rear hubs suck. I think they moved away from the old cam plate design, but its still nothing special.
    AC uses a cheap asian imported design, marks it up 10 times and resells. They're certainly not high end hubs. Id buy budget asian hubs before I paid them for the same thing with a sticker.
    Not that theres anything wrong with asian hubs, some of them are pretty great these days... but they are low cost hubs. Paying brand name prices for them seems silly to me.
    If someone knows where to buy asian (Rear) hubs that are same weight and as reliable as the AC, please let me have the link
    But dont't think the Rotaz,A2Z, Circus Monkey and Novatec are the same league they are either heavier (Novatec) or more fragile than the American Classic.
    flyMTBfish
    For a long time, A2Z's were identical to AC hubs, and WTB hubs. bikehubstore.com sells a very similar hub to the one i run. It has bigger bearings, more engagement, and is comparable in weight to AC. Also easy to get replacement parts.
    As owning a Rotaz and american claasic hub. They are NOT the same....Rotaz weighed the same but was junk under my 230lbs body. Totally different freehub design also.
    Sent from my MB855 using Tapatalk 2
    http://Theclydeblog.org Big guy cycling product tester
