Results 1 to 12 of 12
    all mountain UST wheelset - which one?
    Hi,
    After riding two seasons with mavic 819s and one season with 321 (with tubeless kit) i'm looking for new wheelset for aggressive all mountain use which must be UST type (because i don't like tubes and also tubeless kits are not the true thing..) and not too much weight. I only found these:
    Mavic crossmax SX
    Fulcrum Red zone
    custom with ZRT Flow ? (not really an ust rim)
    Are there any other choices? i would like to have custom wheelset with mavic ust rims but there aren't any in this category - 819s are too narrow, 823 too heavy...
    What do you think?
    I'd get the 821...you just have to wait on Mavic to step up.
    OR, you can do like I did, I went with the DT Swiss 5.1 rims with the UST conversion kit. Light and strong. To save some bones, get the Bontrager strip instead - you get the same center channel for seating and the rim remains the same bead interlock that you desire.
    I have run mine for years without any problems.
    Apr 2005
    If 819 is too narrow and 823 is too heavy - SX.
    Also look at XT - the 20mm through wheelset uses a wider rim.
    Quote Originally Posted by epic
    I'd stay away from XTs due to crappy internals. They have apparently not gotten any better with the new design.
    Former Bike Wrench
    No factory pre-builds using proprietary parts
    Go with a nice handbuilt wheelset
    Stans Arch
    Hope Pro II hubs
    2.0/1.7 spokes
    Like you said, not true UST but works tubeless just fine.
    Quote Originally Posted by mtnbiker72
    Stans Arch
    Hope Pro II hubs
    2.0/1.7 spokes
    I would even say it's the better tubeless system! Lighter and safer, in particular when ride low pressure
    Quote Originally Posted by quax
    Why do you say that?
    http://www.notubes.com/moviecompar.php
    ... and also personal experience from mounting/dismounting many tires: simply compare dismounting a tire from a ZTR and UST rim. You have to apply much force with the ZTR to bring the tire off.
    should know better.....
    Reputation: neverwalk's Avatar
    May 2005
    I LOVE my Crossmax SX's. I had an older pair, absolutely bombproof. Still have them, 3 seasons old.
    Then, got this years model, for a different bike, and they are even better. Better engagement, lighter, wider. Fantastic so far.
    Huge fan.
    My DH wheelset (which I built), is Hope Pro II's, laced to 823's.
    Riding the two back to back, the SX's are way lighter, but track just as well.
    "Always Ride."
    -Anthony S.
    Reputation: Jlar's Avatar
    Quote Originally Posted by CharacterZero
    What internals. When first released the freehub was prone to failure but from what I understand they fixed this. Mine as well as several others I know are rocking them just fine.
    But my vote is for 823's.
    Hope hoops with ZTR Flow?
    I would rather go with custom wheelset because of lower price and maintaining costs - Crossmax SX are sure great but price tag is way over my budget.
    so, what do you think about hope hoops with ZTR Flow rims ( http://www.chainreactioncycles.com/M...?ModelID=40780 ). Price is OK and weight also. I'm not sure about Flow rims, are they stiff enough - compared to Mavic 321s (which i'm totally satisfied with). Any thoughts?
    Reputation: in the trees's Avatar
    Mar 2005
    '09 Crossmax SX
    I've been very happy with mine. I've been on them since the beginning of the season and they have held up real well.
    toby
