Results 1 to 6 of 6
    Apr 2016
    Is this able to be fixed?
    Hi, I am Mr. Lee.
    I have a bicycle with rear wheel mavic.
    When I was doing downhill, chain was stuck in drive sidespoke and smoe spoke was torn out.
    It looks like one spoke hole of hub was broken.
    I wonder if this can be fixed. If they can fix, how do they fix this?
    I uploaded its photo so that you can have better idea what happened.
    Thank you.
    Lee
    Is this able to be fixed?-1-crop-vert.jpgIs this able to be fixed?-3-crop-vert.jpgIs this able to be fixed?-5-crop-vert.jpgIs this able to be fixed?-7-crop-vert.jpg
    Mr. Buck E. Fikes
    Reputation: Oh My Sack!'s Avatar
    Looks to me that because that's a straight-pull spoke arrangement, replacing the spoke would probably be the answer. It does not appear there has been excessive damage to the hub that would allow the spoke to pull through. Other than maybe peening that burr back into place (if it could stand the movement), I'd fit a new a spoke, tension/true the wheel, and go ride. If the attachment point fails, the hub is done but I wouldn't worry about crossing that bridge till I got to it.
    Apr 2016
    It was really helpful. Hopefully it would be able to fixed. : )
    Thank you.
    Apr 2016
    Hello.
    We leave feedback on what happened before the spoke was pulled from the hub.
    It has been repaired, but it can be missed if you drive rough.
    I did not have any problems when I ran soft after a repair, but when I ran wild, I got a problem that the spoke was pulled from the same position of the hub.
    turtles make me hot
    Reputation: NYrr496's Avatar
    Get rid of that hub. If you like the rim, lace a new hub with J bend spokes into it.
    I like turtles
    Barely in control
    Reputation: Schulze's Avatar
    Feb 2007
    I would fire up the TIG welder and add some material, then carefully file it to shape.
  1. Fixed/Fixed multi cog MTB hub
    By Mr.Bee in forum Singlespeed
    Last Post: 08-03-2011, 07:35 PM
  2. 2011 Scalpel (UN)ABLE descender???
    By Sacke in forum Cannondale
    Last Post: 03-07-2011, 11:00 AM
  3. Asr 7 Un-be-liev-able
    By titusquasi in forum Yeti
    Last Post: 01-08-2011, 08:37 AM
  4. Hey Boulder-Flagstaff is ride-able
    By Oh-my-tush-a in forum Colorado - Front Range
    Last Post: 01-06-2011, 02:28 PM
Members who have read this thread: 68
