Results 1 to 34 of 34
    Feb 2010
    A2Z hubs (Rotaz too?) Long Term Review
    Well not exactly long term, but in the last 7 months I've put somewhere between 5000 and 7000km on these hubs.
    The good:
    - front hub is great and trouble free;
    - bearings are excellent quality, well sealed and still going strong;
    The bad:
    - rear hub engagement mechanism has an inherent flaw - it has started to flog out in the last 1000km or so. The pawls sit in the alum hub shell and the softness of the alu mean that they eventually deform it and things go downhill from there.
    I'm not sure how long it'll go before complete failure, but I'm ordering either a DT Swiss 240s or Tune King to replace it ASAP.
    Conclusion: maybe OK for a cheap weight weenie wheelset for occasional racing, but not up to serious everyday offroad riding. How long they'll last for you will probably just depend on how much time it takes you to do 5000km.
    More pics here.
    Nov 2008
    thx for the review, gonna get it for my kid's 24 inch wheel build. Think it'll do well for lightweight riders/kids.
    Front hubs don't do much. Buy a cheap light front and spend the big bucks for the rear...
    Feb 2010
    Quote Originally Posted by mhkang View Post
    They'll be perfect for that. A2Z front hub is lighter than Rotaz equivalent (Rotaz has larger heavier flange on NDS). A2Z/Rotaz rear hubs weigh about the same. Rotaz are generally a little cheaper.
    For a cheap high engagement hub, the bitex hubs are very good. They're also within a few grams of the A2Z. Uses a more conventional pawl setup. bikehubstore.com sells them.
    Former Bike Wrench
    Quote Originally Posted by One Pivot View Post
    By more conventional, do you mean the pawls in the freehub body vs in the hub body?
    Yeah, pawls on the freehub, set in a steel ring on the freehub.
    Former Bike Wrench
    What's the POE and are those the MTB252 hubs?
    48pt! I used to import and sell a ton of them, but its hard to compete with BHS so I kinda quit. Never saw one come back or heard a complaint, I think they're kind of a overlooked gem. The bearings arent fantastic, but changing them to decent ones is cheap (I havent bothered yet).
    Its the mtb252's.
    Those MTB252 hubs look strangely similar to my PureXCR hubs from BWW.
    Feb 2010
    Quote Originally Posted by Bryank930 View Post
    I thought the PureXCRs looked more like the Rotaz / A2z hubs. Does it have a ring gear in the hub or teeth on the freehub?
    Former Bike Wrench
    Quote Originally Posted by TigWorld View Post
    BWW have the gears on the freehub body like the Rotaz
    Reputation: solitone's Avatar
    bitex hubs
    Its the mtb252's.
    So in your experience these are pretty reliable.
    It seems you think they are better than the Rotaz, which on BHS are more expensive?
    I'm not concerned with fast engagement (I'm currently riding a pair of AmClassic hubs and I'm very much happy..). just want a reliable hub, possibly cheap..
    Do Bitex's use standard industrial hubs?
    Quote Originally Posted by mtnbiker72 View Post
    I heard new rotaz hubs now have a different free hub? Has it been improved since the version reviewed in this thread?
    Feb 2010
    If I was after some relatively cheap hubs now I'd get either:
    • circus monkey HDW3 - very lightweight - but unknown reliability;
    • bikehubstore 252s' - seem to have better engagement mechanism than A2Z/Rotaz/BWW XCR, Chin Haur etc.; or
    • novatec 811/812s - heavier but stronger with easy parts availability
    My A2Z rear hub is still hanging in there and I've probably got almost 10,000km on them. Engagement mechanism aside, my main beef with these types of hubs is the flexy alu axle that allows contact between freehub and hubshell on bigger jumps.
    Quote Originally Posted by solitone View Post
    I think they're a lot better than rotaz just for the pawl arrangement. Id say they're reliable like a hope hub. Its a buncha pawls, decent sized teeth and pretty hard steel. I dig them.
    Im guessing you mean standard bearings, but yes they're regular sized nothing-special bearings. Easy to find and replace.
    They've gotten really big in the road bike world. bigger than people know since they're so often rebadged and sold under other names. I honestly cant recall even hearing about someone having issues with them (even under different names). The mtn hubs are basically the same, but beefier.
    So now I'm lending towards Bitex, rather than Rotaz hubs.
    @One Pivot What about the axle of the Bitex's? In your opinion is it stiffer than the "flexy alu axle [on the Rotaz's] that allows contact between freehub and hubshell on bigger jumps", as reported by @TigWorld?
    But is the MTB252 on BikeHubStore a Bitex?
    MTB252 Rear Disc Hub - 10mm Axle
    I see several rear mtb hubs on bitex's website, but I don't find any perfectly equal:
    Bitex + Bicycle & Wheelchair hub
    To me this shouldn't be an issue as I have a 15 mm front thru-axle and a 142x12 mm rear thru-axle, should it?
    Feb 2010
    You'll have to look at the design and see where the 12mm thru axle is supported but I'd guess it shouldn't be a problem.
    I'm not sure I understand it correctly, but the thru-axle is supported by the frame dropouts.
    Feb 2010
    Take a look at where the thru axle is supported by the bearings in the hub. If you can't find a cross sectional diagram, you can sort of work it out based on the bearing sizes.
    eg. the 252 rear hub has 6902 and 6802 bearings. Both these bearings have a 15mm inner diameter, so the hub uses a 15mm axle.
    In QR config the hub is supported on the ends by axle end caps. What you need to find out is if the 12mm thru version only supports the 12mm thru axle on the ends or if the 12mm thru axle supports the 15mm hub axle all along its length. ie, is the inner diameter of the hub's 15mm axle 12mm, or is it larger and needs end caps to drop its inner diameter to 12mm?
    On BHS.com, the mtb252 specs say:
    Axles: 9mm (135mm) or 12mm (142mm)
    But this refers only to axle compatibility, doesn't it? So it does not refer to the hub axle inner diameter (?)
    I cant really speak for BHS's products, but he has told me that no, its not a "bitex".
    It is however, very very similar. The pawl spring setup on the BHS hubs is better than what bitex sells if you buy direct from bitex. The overall design is the same, the geometry and weight is the same too.. but its just a little different and maybe better.
    For comparisons sake, what ive said about bitex and my experience with them is applicable to BHS, but BHS is not 100% a bitex hub. Might sound weird and like semantics, but thats how a lot of asian sourced stuff goes. I bet the rotaz/chin haur/A2Z branded stuff has similar slight differences.
    I just pulled my axle caps off, and it looks like its a 14mm axle, just eye balling it. Its pretty thick too. with QR's, I never felt this hub flex even at 220lb.
    I have nothing to do with BHS, but I do think its a good product and one I like to endorse.
    Yes, I think I'll go with those Bitex-like hubs. I've read lots of good comments on both Bitex road hubs and BHS.
    Plus, I have 15 and 142x12 mm thru-axles, and supposedly Rotaz hubs aren't available in those options.
    I'm just waiting for Brandon's answer to some questions I sent him regarding availability (front 32 holes unavailable?), and then I'll probably buy them.
    I'm thinking of lacing them to Stan's NoTubes ZTR Crest 29" rims and DT Competition spokes with alloy (?) nipples. It should result in a good weight, hopefully not too weak!
    Reputation: Johnnydrz's Avatar
    My experience might not mean much to heavier riders (I'm 135lbs) but I have been using the MTB252 hub on my SS and it's been trouble-free. Spins really good, very quiet and the 48POE are really good for SS riding. I just built another wheel with a new MTB252, DT SWISS Aerolite spokes and Light-Bicycle 26" carbon rim. Makes a nice light wheel.
    Johnnydrz
    New question here. Installing Shimano cassette on BHS MTB252 hub
    @One Pivot and @anyone who has used BikeHubStore MTB hubs, like @nbwallace
    Eventually I bought a pair of BHS hubs (MTB162, MTB252), 32 holes, red anodized.
    They seem quite good, and they weigh less than declared:
    - MTB162 (front): 140 g, 15 mm thru-axle version;
    - MTB252 (rear): 255 g, 142x12 mm thru-axle version.
    I had them laced to a couple of Stan's Crest 29 rims, with Sapim Polyax alloy nipples, and Sapim D-light spokes.
    I just have an issue with cassette installation.
    I tried to install a new Shimano XT 10 speed cassette (CS-M771-10) on the rear hub's freewheel body. Unfortunately, though, I can't tighten the cassette lock ring at the required torque.
    The cassette locking tool (a ParkTool FR-5) doen't engage firmly on the teeth of the lock ring. The tool interferes with a cylinder inside the freewheel body, and I can't push the tool down enough to make it firmly engaged.
    I didn't have such problems when installing the same cassette on an American Classic freewheel body...
    Do I need some extra spacer to install a Shimano 10 speed cassette on the MTB252 hub? Where should I put the spacer? Before the biggest sprocket? Or maybe between the last smallest sprocket and the lock ring?
    Thanks for your advice!
    Reputation: Bike Whisperer's Avatar
    10 speed cassette usually need a 1mm spacer as the body is actually narrower than a 9 speed cassette.
    Quote Originally Posted by Bike Whisperer View Post
    Thanks for your reply!
    How comes Shimano does not include that spacer in their package?
    Where should I insert that spacer? Before the lock ring?
    I'll go to my LBS, and hope I can find one.
    I have read something around on this topic.
    Isn't this true for road 10 speed cassettes only?
    Thanks again!
    Thanks again!
    Road and Mountain 10 speed cassettes are the exact same spacing, no difference at all with Shimano or SRAM cassettes. Not all hubs need this spacer but some do. Shimano hubs do not need it, so why would they include it with their cassette? My WTB hubs came with the spacer and you put it on first before the cassette.
    Armature speller
    Sep 2004
    Just had my rear A2Z XC hub crap out. The pawls and engagement points chewed each other up.
    There's slight distortion in the alloy around each spring loaded arm, similar to the one in the pic in the first post.
    I was 40min into a 3hr epic loop. Lucky I could coast back almost all the way home.
    Jan 2014
    This is clearly an oldish thread, but for truth's sake, brass nipples will outlast "alloy" READ: {aluminum} nipples due to the durability of the harder brass superceeding aluminum's softness, strengthwise. If you ride hard taking jumps, are obese, run 24 spoke nipples, are a strong accelerator you will break the aluminum eventually. Brass as a rule of thumb, is stronger. Decades later, many brass nippled wheels have stood the test of time and repeated use. Often, if one alu nipple breaks, the rest will follow. Hope this helps.
    Armature speller
    Sep 2004
    Re: A2Z hubs (Rotaz too?) Long Term Review
    Quote Originally Posted by NordieBoy View Post
    Replaced it with an A2Z downhill hub with 32 poe and a nice beefy pawl setup. Almost twice the weight of the XC hub, but looks like it'll last forever. The XC front hub is still running very smoothly.
  1. Pure XCR hubs-Long term review?
    By chivo in forum Wheels and Tires
    Last Post: 09-14-2010, 04:23 PM
  2. Rotaz Hubs. Semi-review.
    By DukeNeverwinter in forum Weight Weenies
    Last Post: 06-18-2010, 10:47 AM
  3. Long Term 429 Review
    By padrefan1982 in forum Pivot Cycles
    Last Post: 04-04-2010, 08:37 PM
  4. Ibis long term review
    By nzl62 in forum Ibis
    Last Post: 10-20-2009, 03:06 AM
  5. On-One Mary long term review
    By Professor in forum Singlespeed
    Last Post: 04-25-2006, 02:37 PM
