    Reputation: metrotuned's Avatar
    30mm width rim an upgrade from 24mm width rim?
    Comparing two rims equal in materials, running a 29 x 2.4 tire, will the 30mm outer diameter rim perform that much better than a 24mm outer diameter rim?
    I'd like to run CX-Ray spokes to brass nipples on shallow 30mm wide rims. If I go freehub, it'll be Chris King. If SS specific freewheel, going with White Industries freewheel and Paul bolt-on hubs. Rider weight 200lbs dry.
    Lead actor Will of the Sun, Author Platform Pedal Shootout 900K+ views
    HJH
    HJH is offline
    Pros:
    + better grip
    + possibility to use lower tire pressure
    Cons:
    - more weight --> more inertia
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by illnacord View Post
    You better mean 24 vs 30mm width, not diameter. A 29er tire has a bead seat diameter of 622mm.
    Generally the wider tire will perform better on the wider rim. An inside width of ~22mm seems to be the sweet spot for most mtb tires.
    mtbtires.com
    Thanks. Went with the 30mm wide rims. Now to decide on spokes: bladed cx rays, butted Phil, or Marwi titanium.
