Results 1 to 13 of 13
    Jul 2013
    29 x 2.25 tire on 700c rim
    Hi, would i be able to fit a 29 x 2.25 tire on a 700c (622x14mm) rim? Thanks for your help. Specs of wheel: Alex AKX - R1.0 Double Wall Aluminum, 700c.
    Sent from my mind
    Reputation: joe_bloe's Avatar
    Re: 29 x 2.25 tire on 700c rim
    It would probably mount up okay, but the ride would be terrible. with such a narrow rim, the tire would try to roll over on its side wall. it might actually fold over, right off the rim.
    Sent from a boring meeting.
    Jul 2013
    Quote Originally Posted by joe_bloe View Post
    Thanks for the input! Would you say the same goes for a 622 x 19mm rim? Sorry for being a pain in the arse. My budget is very limited for purchasing actual 29er rims
    Sent from my mind
    19 millimeters would certainly work better. What kind of riding are you planning on doing on these wheels?
    Jul 2013
    Just cruising, no off road
    Sent from my mind
    I Tried Them ALL... Moderator
    Reputation: Zachariah's Avatar
    ^What they said^. Running a 29 x 2.25 tire works best on a rim wider than 23mm ID. Otherwise, you'll get squirrely, unstable handling; you'll point the wheels, but the tire will go where it wants to go....scary and frustrating.
    "The mind will quit....well before the body does"
    Trail Prospector
    Reputation: Flyin_W's Avatar
    OP, No need to apologize, as the term 29-er is pure mktg hype (overall height).
    All 700 c rims are spec'd @ 622, and not too long ago were all based on narrow(er) road touring rims.
    Could you mount fat rubber on a 14mm internal / 19 mm external rim? Yes, with a tube and at 35-45 psi it will work. (I did for years on an early set of stock Bonty Race Discs.)
    Yet, like the earlier post implied it would not be ideal - fat tires really like and perform better on wider rims. YVMV.
    (by phone)
    The best is the one you want to ride most often..
    Jul 2013
    So is there such a thing as a "fat tire" for that size rim -622x14mm?
    Sent from my mind
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by tugofwar View Post
    Sent from my mind
    I do it often. Fits fine. I have a wheelset with 19mm (13 inside) rims. Use tires from 23mm to 2.4". Mostly 35-42mm roadish or 1.75 (45mm) to 2.1" knobbies.
    The wider tires can get squirmy unless you run the pressure higher. Some treads may not handle well (but the same can be true for narrow tires on wide rims).
    Note that a 23mm rim has an internal width ~17mm. Your rims are ~20mm external.
    mtbtires.com
    Jul 2013
    Thanks shiggy
    Sent from my mind
    Jul 2013
    Well i went ahead and installed the 29 x 2.25 tire on the 622x14mm rim, it fit and handled very well for my type of riding, cruising. thanks for all the informative input guys, I really appreciate it
    Sent from my mind
    Aug 2013
    oof, 2.25" tire on a 14mm ID rim? be careful, it might fit but you're at risk for pinch flats
    see also Tire Sizing Systems
    I run Michelin Mud 2 30C cyclocross tires on my old 622x15C factory rims & they work great.
    For a 2.25" tire you should be using at least a 19mm ID rim and really a 23mm or wider would be a better idea.
    Dec 1998
    Quote Originally Posted by funkboy View Post
    IME too narrow a tire on too wide a rim increases the chance of pinch flats.
    A wide tire on a narrow rim does not.
    Wider rims are good for 2.25 tires, but the OP wanted to use his existing wheels.
    mtbtires.com
  1. 29er vs 700c tire
    By jahfakin in forum 29er Components
    Last Post: 07-28-2013, 08:29 PM
  2. 700c Tube With A 29er Tire?
    By Sizzler in forum Wheels and Tires
    Last Post: 04-13-2013, 04:31 PM
  3. 29er Tire on a 700C Rim
    By Markleo in forum 29er Components
    Last Post: 05-23-2012, 07:57 AM
  4. 700c tires?
    By manida in forum Wheels and Tires
    Last Post: 09-22-2011, 10:58 AM
  5. Widest 700c tire when using FreeRadical
    By dfltroll in forum Cargo Bikes
    Last Post: 09-18-2011, 08:19 PM
