AKA Mr.Habanero
26in chinese carbon all mountain rim
I really enjoy the 29er chinese carbon rim thread but l didnt see anything for all mountain chinese wheels or rims. I'm looking for some 26in carbon all mountain rims that need to be wide, pretty light and strong to go on my Tracer2. Going through all the Asian carbon stores is big undertaking. That, and l dont fully understand everything about wheels. Are all the rims pretty much for xc if not can someone point me in the right direction
Well the company that everybody is buying the wheels from in the 29er thread also makes 26er carbon rims as well.
26er MTB carbon MTB rim clincher - light-bicycle
That is the regular 24mm wide 26er. They are also in the process of producing a wider 26er that will come in at 30mm wide (external), 23mm wide (internal), and 23mm depth...which is wider than the ZTR Flow. Not sure on the weight of the wider rim since I'm still waiting for a reply from Nancy.
Current Ride:
Ibis Mojo SL-R - Medium - South Beach White
'11 Specialized Roubaix Compact Rival
Commit or eat sh!t
Do you know what the internal width is on those rims? Price and weight looks reasonable. Found the 29er rim thread. Has others used the 26er version?
http://forums.mtbr.com/29er-bikes/ch...ms-673410.html
they will be ready around the end of the month, this is the profile of the similar 29er rims...id imagine the 26" will be identical
I see there's no inner ridge to keep the bead in place.
Here is what Nancy sent me for the wider 26er...she also mentioned that the weight will be right around 370-380g.
Current Ride:
S-Works all the bikes!
Just another used cat for sale
 Originally Posted by JoshS
Suitable for DH?
Impossible to tell, as these are not in production yet. However given that a Mavic 823 weighs over 600g, it's a bit hard to imagine that a sub 400 carbon rim is intended to compete in that usage category.
Check the 20 page thread in the 29er section for some short term ride reports.
Yeah, I have been, I actually want to build up a set of normal 29er rims for my 29ers
But currently I am planning to build a set of DH rims with Stans Flow or DT swiss 500, so I wonder if these would work. The real question is what would happen if you hit something hard enough that would normally dent a aluminum rim.
well, pound for pound, properly laid up carbon will be stronger than aluminum in pretty much all aspects, too many variables here to know though if these will adhere to that, i dont think id risk it on DH as the risk far outweighs the reward...light-bikes can build the rims up beefier for heavier riders upon request, so that might be an option if you are brave
enve has a DH rim coming out soon that has been quite durable in testing, much moreso than aluminum DH rims and weighs in around 475g...they will assuredly be better than these chinese rims, at a major cost penalty
Enve DH
Commit or eat sh!t
I have seen Enve rims fail. One rim that a pro DH rider was using broke, with the bead hook chipped off. An AL rim would have bent at that spot. Granted, this was at Bootleg, so not too many rims last there.
Enve DH's are $1000 per rim. It's a joke.
For DH, if you are going to use light rims, you are better off using something cheaper like Flow and replacing it every season or more.
read the article i linked about the testing they did, may be one you were talking aobut:
During the 2010 season, the Syndicate’s first on the carbon rims, they replaced 53 wheels, which was down from a reported 180 wheels per season when the team was on alloy. In 2011, the team had to replace just 11 wheels.
Of last season’s 11 broken wheels, not one lost air pressure or warranted their rider to slow before the finish line. “They were cracking hook beads,” said Schiers of the failures
Article on Enve DH rims (including weights) are here: ENVE Launch DH Rims And Wheels - BikeRadar
So will a sub 400g rim be suitable for DH? Especially when the manufacturer has stated a rider weight limit? The answer should be self evident.
Yeah ENVE, is a little too pricey for me. I love high end stuff, but when cost is 1000% ($600 vs. $60) greater then a comparable aluminum rim that weighs about the same, I think there is a better way to go.
But like it has been said, if the carbon fails it's one of 2 ways, it's a crack and it's not a huge deal, or it is a fracture, and all hell breaks loose in your world at that moment.
That profile doesn't look like it'll be tubeless compatible at all. The profile looks exactly like their current narrow 26 rim profile and the current rim is not tubeless compatible according to Nancy when I inquired about them.
I hope they make the profile like the wider 29er rim.
Per Nancy just a few minutes ago:
"Hello sir,
It is tubeless compatible,but we are doing the strength testing & also the outlook checking. To make them perfect.
Thanks,
Nancy"
Current Ride:
well, if thats the case, the rim profile she sent you is incorrect...
Agreed,
I have the popcorn and wine in hand watching this thread. If I could get a sub 400g 23mm wide (internal) rim for my new Lefty build I'd be thrilled. I'd even go as high as $200 for it.
Lead by my Lefty straight down the trail, no brakes.
Looks like March 5th is the ETA for the wider 26er. Nancy is checking back with the engineer to get me an up-to-date cross-section.
Current Ride:
What's the profile of their XC rim? At 330gr, it could make a killer rear wheel.
Faster is not always better, but it's always more fun
you can send them an email to get the exact one
here is the 29er XC rim from the other thread
Eagerly awaiting when someone gets an updated cross section profile of the new wider version.
well, if thats the case [it's tubeless compatible], the rim profile she sent you is incorrect...
Can you explain or draw what the profile needs to be or how it needs to change for tubeless and why that is? Thanks!
Would something like the Bontrager rim strip work, granted it would add weight but, doesn't it have a beadlock on the rimstrip.
See the flat ramps on the sides? Holds the bead in place so it can seal.
- You may not post replies
- You may not edit your posts
Forum Rules
