Page 8 of 18 FirstFirst ... 456789101112 ... LastLast
Results 701 to 800 of 1796
  1. #701
    Reputation: SwintOrSlude's Avatar
    Quote Originally Posted by highaltitude View Post
    For those that built their own - how much spoke tension are you using on these rims?
    Front: 120kgf disc side
    Rear: 160kgf drive side
    holding up just fine!
  2. #702
    Reputation: thuren's Avatar
    Quote Originally Posted by tahoeyeti View Post
    Rock hard is WAY too much pressure. I usually run about 23 psi front and 26 psi rear, and depending on your weight, riding style, and how chunky your trails are you could go as low as 18 psi.
    Some would call 35psi rock hard, and I would call 18psi damn near flat.
    I NEED to run 35psi on the rear, and 32psi in the front, unless running full on 1200g DH tires.
    There are no "rules" with tire pressure.
    Bend, Oregon
  3. #703
    RTM
    RTM is offline
    #1 Latex Salesman
    Reputation: RTM's Avatar
    Quote Originally Posted by thuren View Post
    there are no rules for tire pressure
    precisely! In fact, for riding purposes I don't even bother with the guage, just give the tire a squeeze.
    By the way, tahoeyeti, we were talking about temporary pressures for seating a bead. I think we could all agree that 50-60 PSI would be ludicrous for any type of off-road riding.
  4. #704
    Going to be riding mine for the first time on sunday, can't wait as I built them up a month back and haven't had the time since I managed to seat some tyres! Bought conti rubber queens 2.2 ust for them as they are a large tyre so thought the depth would help protect the rim. Once I got the tyres on and seated (very easy) its clear that they are no longer the over sized tyres they used to be! Still great tyres though. Will report back once rode them a few times.
  5. #705
    RTM
    RTM is offline
    #1 Latex Salesman
    I'd like to run a set of matte finish rims tubeless. Would thee be an advantage to asking for a gloss finish on the inner channel of the rims? Better sealing, or air tightness maybe?
    - Rob
  6. #706
    MattSavage
    Reputation: mattsavage's Avatar
    Sep 2003
    Quote Originally Posted by RTM View Post
    - Rob
    No.
    "I wrote a hit play! What have you ever done?!"
    Have Ashtray, Will Travel....
  7. #707
    May 2010
    re: my wheelsets....
    Howdy,
    Thought i'd put some useful feedback up here for everyone.
    I've got 2 sets of 30mm AM Carbon rims, 1set 32h on American Classics (1505g), and 1set 24h on Sun Ringle's (1475g).
    I ordered them with 3k Matte finish, and Pillar 1420 spokes at the same time.
    ERD was 536mm on all 4 rims measured at multiple points.
    They built up really easily, but would probably recommend using internal nipple washers, as they don't angle the internal nipple hole. So the nipples want to point straight out and not at the actual spoke angle.
    Example washers here: "bdopcycling.com/Pillar-Nipples and Washers.asp"
    Built them up with linseed oil, and tensioned to 120/160Kgf (disc/drive rear, and non-disc/disc front).
    I've taken the american classic 32h set out in anger the other day, and gave them a good working over on a 10m loop, and some really rough DH runs.
    They've held their tension fine, although the nipples have now bedded into the rim at the correct spoke angle. Really really surprised how strong the pillar spokes have built up with the wheels!
    Tubeless.........
    Now this was a right PITA, but they do work and work well.
    The biggest issue for me was the tyre not sealing initially due to the deep internal channel. I ended up making a rim strip out of a 20in tube cutting it into the right width. Once the rim strip was in the tyre was able to seal just enough to seat up on the bead correctly. (although I really really had to work at it with my track pump!!)
    This would be way easier it you actually used a correct rim strip, like the bontrager strip.
    I just used a bontrager tubeless bolt in presta valve and my bodged bmx tube.
    This may be easier with the non matte finish rim, but mine are running fine.
    Tyres being used were: Schwable Fat Albert 2.4, and Nobby Nic 2.4 (tripple evo tubeless ready)
    Pics of mine here: "scar4me.pinkbike.com/album/CarbonAMRims/"
    Scar
  8. #708
    Hi,
    I am going to buy this rims but I am afraid of putting the tires on that rims. Now I am using Mavic XC 717 disc with tubes and Rocket Ron EVO (not tubeless). I have no problem to put them on or off without any tool. Will I have such problem with the new Chinese rims? Or is the problem only with tubeless tires?
  9. #709
    Quote Originally Posted by czarli View Post
    Hi,
    I struggled with Schwalbe Hans damph tyres, but had no problems mounting continental rubber queens which are ust tyres. Just keep pumping till they seat as the rims are definitely worth the effort.
  10. #710
    Thanks for answer. What about situation when I get a puncture on the trail (I'm using tubes)? Will it be possible to remove the tire? How is it difficult?
  11. #711
    MattSavage
    Sep 2003
    Treat it like any other tire and any other rim... Some combo's are easy to work with, some are hard. Bring the right tools.
  12. #712
    Light Bicycle carbon Rims
    I recently built up a pair of the 26" AM carbon rims with CK hubs and DT aerolite spokes. Easy build-more so than flow rims. They are very stiff and true having ridden them a few times. The rims appear to be very high quality. The rim also has a pronouced bead-not sure if this is a knockoff off stans or specialized but it looks like it will really hold a tire in a tubless setup. I used the bontranger rim strips instead of usual stand tape or gorilla tape and installed maxxis Ikon and Ardent tires (non tubeless ready but work great with stans rims). They inflated easily with no stans or soap using a compressor and held air without stans sealant. I was impressed. I have been running with stans sealant with zero problems. There was very little seepage upon first inflation-again very impressive tubelss compatability.
  13. #713
    Reputation: wannabeRacer's Avatar
    What lenght nipple did anyone use 12mm or 14mm?
    Also, I'm thinking of building with DT 240s 6 bolts DISC hub. What's the lenght for 3 cross as the calculator came up 259.2 left and 259.1 right and Sapim spoke range are 259mm and next size up is 261mm and also DT Swiss Revo range 259mm next size 260mm? I'm guessing order 259mm, can anyone advise?
  14. #714
    I used 12mm dt nipples.
  15. #715
    RTM
    RTM is offline
    #1 Latex Salesman
    Quote Originally Posted by wannabeRacer View Post
    I couldn't tell if you had a preference for one spoke over the other, but 259mm AND 260mm w/12mm nipples would be fine. If you want the 259, and want extra peace of mind you could go with a 14mm nipple though its not necessary.
  16. #716
    Reputation: Eazy_E's Avatar
    Tag for interest
  17. #717
    May 2010
    Set available for sale....
    Just thought i'd post up here as if someone in the UK wants a set of these the set I made up for a mate is up for sale:
    Would love to keep them along with my other set, but don't earn enough to get away with another bribe to the missus!
    Scar
  18. #718
    Quote Originally Posted by scar4me View Post
    Scar
    I am interessted. I will contact you via PM.
  19. #719
    obsessive
    Reputation: eurotrash666's Avatar
    Has anybody ordered these without holes in the inner channel? I'm thinking of placing nips with a magnet and a ferrous stub to drag them into place through the valve hole. For you guys who have built them, is there enough room in the cavity to accomplish this?
    Go out and ride your bike
  20. #720
    May 2010
    undrilled inner...
    I wouldn't advise it.
    I looked carefully at some of the spoke drillings, and some of them didn't have the cleanest finish on the inside edges, so might scupper you.
    Easiest way to get them in would be fishing wire in through the nipple hole, out through the valve hole, put the nipple on, tia knot then pull it through.
    But again is risky, especially if there are any remnants of the internal bladder left over stuck in the inside of the rim.
    Scar
  21. #721
    Feb 2010
    Quote Originally Posted by eurotrash666 View Post
    The normal way rims are drilled at manufacture is from the outside in. Do you know that their jig drills from the inside out? If not, they won't be able to do what you want.
  22. #722
    obsessive
    Quote Originally Posted by TigWorld View Post
    Earlier in the thread someone quoted "Nancy" as having that as an option. It doesn't sound too far fetched to me, considering the Chinese have been known to paint a poem on a grain of rice using a single human hair...
  23. #723
    Reputation: ScottW's Avatar
    I built up the first of 4 wheels I will be building up with these rims. LB wide rim, Hadley 110x20 front hub, DT Swiss revolution spokes and alloy nipples. Wheel weighs 710 grams, once I added a stip of gorilla tape and a Stans valve the weight was 740.
    I put on a used but lots of tread left Continental Trail King UST and it sealed up immediately without even using sealant. It probably helped that this tire has already been mounted on my old front wheel, I just used a little soapy water on the rim and bead.
    Next will be building the rear wheel, also using a Hadley hub and DT spokes. Should get a ride on the front today, looking forward to it.
  24. #724
    is RAD
    Reputation: Van Cuz's Avatar
    Jun 2010
    Has anyone switched from Stans Flows to this rim and noticed a change in stiffness?
    I have Hope Pro II's with DT Revolution spokes on Stan's Flows and noticed a lot of flex, so I have retired them to my commuter. I'm wondering that if I change out the flows for these carbon rims I will notice an improvement in stiffness? or do I need to go to a thicker spoke?
  25. #725
    Mr. Knowitall
    Reputation: hssp's Avatar
    If your flows were flexy with revo, I guess they aren't tensioned enough. My Flows on CX ray are very stiff. Thicker spokes do not necessarily mean stiffer. On the contrary. I have problems building stiff wheels with thick spokes
  26. #726
    is RAD
    Jun 2010
    Quote Originally Posted by hssp View Post
    From what I have read, CX Rays would build to a stiffer wheel than Revo's.
    My understanding was that a thicker spoke would stretch less under load (at the same initial tension), leading to a stiffer wheel.
  27. #727
    Feb 2010
    CX-Rays and Revos have about the same cross sectional area. They are equivalent in elasticity. A thicker spoke would be less elastic (ie. stretch less under the same load) but the CX-Ray is wide and flat while the revos are round, but the amount of metal in cross section is the similar.
  28. #728
    May 2010
    The carbon rims allow a much higher tension overall in the wheel as the rim itself give structural support.
    Alloy rims do have a fair amount of give compared to the carbon ones, so if you tried to build them with the same high tension, the natural flex of the alloy rim would lead to snapping spokes as the flex is in concentrated areas.
    The carbon rims spread the load much better across more spokes, leading to less high stress peaks on single spokes when really putting the rim in high lateral and vertical loads.
    Bladed spokes do support stronger wheel builds. As the spokes are not just stressing directly in-line with the spoke, they have side loading aswell. Bladed spokes are much less prone to failure under repeated side loading when under high tension.
    Cross sectional area is not the only factor in actual durability, as both Revo's and CX's could be tensioned up to the same high tension, but the Revo's would fail way before the CX's did under actual riding conditions.
    Scar
  29. #729
    Feb 2010
    ...Bladed spokes do support stronger wheel builds. As the spokes are not just stressing directly in-line with the spoke, they have side loading aswell. Bladed spokes are much less prone to failure under repeated side loading when under high tension.
    Cross sectional area is not the only factor in actual durability, as both Revo's and CX's could be tensioned up to the same high tension, but the Revo's would fail way before the CX's did under actual riding conditions...
    Got any empirical data to back this up? A spoke is under tension, its cross-sectional shape is irrelevant. CX-rays claim to have a higher fatigue life than the equivalent non-bladed spoke. They do not claim to be stronger.
  30. #730
    Jun 2012
    Now that the season is winding down does anyone have any video of themselves riding these rims in technical stuff or hitting jumps/drops with them? Or even just comments on how well they performed for you this season, along with what bike they are on and style riding you prefer? I would love to hear from those Mojo HD riders!
  31. #731
    Quote Originally Posted by ttengineer View Post
    Well I don't have a seasons use out of mine but I built up a front wheel last week and my rear wheel yesterday. Rims came in at 360 grams each, Hadley hubs, DT revolution spokes and alloy nipples. Wheelset weighed in at 1550 grams without rim strip or valve. I used one wrap of gorilla tape with a Stans valve and my Conti Trail Kings seated easily.
    I've had a few rides on the front wheel, first ride on the rear wheel today. No complaints, the front seems like its stiffer than my DT 5.1/Hadley wheel I was using previously.
    These are on a Mojo HD and I feel like it was a good investment. Think I ended up spending around $850 for everything. The new wheels dropped around 3/4 lbs from my wheels which doesn't suck.
  32. #732
    I've been beating the snot out of mine. No full DH rock garden charging, as Carbon and rocks still freak me out, but I have pushed them as hard as any rim on any trailbike. Jumps and berm bashing like crazy, and I come in at 200lbs. These things are STIFF!
    If I were running 1000g+ tires on a DH bike, and higher pressures, I would trust them.
    They would probably be on my long-travel Enduro, IF they had a true bead-lip like my XT wheels do. I do fear of burping these if I ride REAL hard, with no bead lock. I head the Bontrager strips have this lip though might try that.
    Bend, Oregon
  33. #733
    obsessive
    Tech note from Brian:
    The recommended spoke tension is 80kgf to 130kgf
    3 of charging tension are involved in wheel building. Riding comfortability and performance are supposed to be considered while choosing charging tension.
    A. Tension for "transportation riders" (Comfortability) 80-90kgf are ideal for regular tansporation riders or exercise on a regular basis.
    B. Tension for "enthusiast riders" (Balance) 100-110kgf are good for people with enjoyful and training purpose.
    C. Tension for "professional riders" (Performance) 120-130kfg are charged for riders who are expertized in riding or competition.
  34. #734
    obsessive
    Custom red paint for me!!
    Gonna replace some 620g Transitions with these... 400g reinforced version, UD under gloss red. These guys have been great to deal with. They say they have addressed the tight fitting/not fully seating tire problem... hope so.
  35. #735
    Was the custom colour at any extra cost? Might get my next set in a union jack colour way!!
  36. #736
    obsessive
    15 USD to paint and polish the pair. I bet they could do all kinds of paint, considering they do frames. Another Chinese company called Miracle did my frame with a design of my choice, but they charged per color, not on the complexity of the design. These guys are really striving for success.
  37. #737
    I've recently built up four wheels with these rims and all have seated Continental trail kings (both UST and regular) without issue.
  38. #738
    Oct 2011
    Quote Originally Posted by ScottW View Post
    What type of rim strip are you using? I'm planning on trying out gorilla tape with my mountain king II's.
  39. #739
    Oct 2012
    Subscribed
  40. #740
    Jun 2012
    Quote Originally Posted by sraak View Post
    From what I have seen on here, that combo seems to work VERY well. The bontrager rim strips seem to work well also.
  41. #741
    I just use one wrap of gorilla tape.
  42. #742
    May 2010
    Howdy,
    Tubeless.........
    Did it the cheap way with £6 bolt in valves, and an old bmx tube.
    Couldn't be bothered to spend £25-30 for a propper strip.
    Scar
  43. #743
    Scar
    Bontrager rim strips are £3.50 each
    Gorilla tape is £4 a roll
  44. #744
    I have the 29" version of these rims and initially built them with Revo's-2.0-1.5-2.0, and found them to be too 'flexy' in rough tech, pretty scary actually. I rebuilt them with 2.0-1.7-2.0 spokes, same tension, and they are much better holding a line in the rough tech. I feel more confident. I may even go to 2.0-1.8-2.0.
  45. #745
    Quote Originally Posted by rockinrod35 View Post
    Too flexy compared to what? Isn't the primary benefit of carbon rims the stiffness? I run Stan's Arch EX and am considering these FOR the stiffness. Would I be disappointed in this swap?
  46. #746
    Jun 2012
    Quote Originally Posted by kroe View Post
    He was referring to the spokes, not the rim i believe.
  47. #747
    Understood, but thought carbon rims were super stiff, and could get away with lighter or less spokes (seems to be how the commercial Carbon wheelsets are set up). I weigh around 210 and haven't seen a huge difference in stiffness from spokes (from tension yes, from spokes not so much, even my current Industry Nine aluminum spokes).
  48. #748
    I went from Stans Arch rims and its like night and day, you won't be disappointed.
  49. #749
    Reputation: Fix the Spade's Avatar
    Depends how light you go on the spokes, Revolutions are very light, so much so DT only backs them up for XC use ~(They go 2.0-1.5-2.0).
    Comps/Supercomps have a much less drastic butting to them, so you can get away with fewer and higher tensions. But really you want 32 and live with the extra 100g, wheels with 28 or fewer spokes can be a complete pain to true.
  50. #750
    RTM
    RTM is offline
    #1 Latex Salesman
    Quote Originally Posted by Fix the Spade View Post
    This is great advice. In the planning stages it's easy to get obsessed. Doing a recent build i realized I was agonizing over every gram, in reality, when I'm actually RIDING my bike I care a whole lot more about functionality and durability.
  51. #751
    My old wheels were Stan's Arch (not the EX version)-DT-2.0-1.8-2.0 Comp spokes, Hadley hubs, 15mm front, 10mm thru rear. LB wheels are-wide AM rim, 2.0-1.7-2.0 wheelsmith spokes, DT Swiss 350 hubs, 15mm front, 10mm rear. So far, my old wheels are definitely better in the rough, i.e bombing down rough downhills. The LB carbon wheels are lighter, and they definitely allow the tires to hook up better, especially climbing.
  52. #752
    I just order my matte stronger DU rims i should see them in a few weeks! im excited to see if they hold up!
  53. #753
    I had the Arch rims just swapped everything over onto the carbon rims and the new rims make the wheels 100% better in all situations, so I would disagree with your findings. Just my opinion.
  54. #754
    Well, it was fun while it lasted...
    After about 5 weeks of riding, I was riding my favorite local trail and I rolled off a tiny jump (about a foot drop). I didn't notice the rock in the landing area until I hit it.
    The carbon rim didn't like handle the impact well.
    So sad, I really liked it until this happened. I'll be rebuilding with an alloy rim (Nancy says this is not covered by warranty).
    Attached Thumbnails Attached Thumbnails 26in chinese carbon all mountain rim-img_1111.jpg
  55. #755
    knobby noob
    Reputation: axl886's Avatar
    Oct 2012
    Just received from Nancy a day ago... 3k matte, hope it stands up to my usage.
    Attached Thumbnails Attached Thumbnails 26in chinese carbon all mountain rim-2012-11-14-11.22.03.jpg
  56. #756
    Reputation: gmats's Avatar
    Apr 2005
    Nice! I've been enjoying mine for several months now. I've used them through the rocky jungle riding we have here in Hawaii and even three weeks of CO single track trails. They've been wonderful. Hope they work as great for you as they have for me.
  57. #757
    just ordered a set to lace over to my I9's...fingers crossed...
  58. #758
    Quote Originally Posted by dabe View Post
    Curious, did you pinch flat? Running tubeless? I've upped my pressure to avoid any chance of rock to rim contact.
  59. #759
    Ouch, bad luck.
    I doubt an alloy rim would have handled the 'one sharp object on landing' scenario much better, but then again it doesn't hurt nearly as much to bust a $40 rim as a $150 carbon.
    Better luck with the replacement!
  60. #760
    Reputation: hardboiled's Avatar
    bummer dude. out of curiosity, what did that rim weigh? curious if it was on the lighter or heavier/more reinforced end of the spectrum that they offer. thx.
  61. #761
    my broken rim
    Quote Originally Posted by hardboiled View Post
    The rim weighed 384g.
    I was running tubeless. The impact broke the rim which caused the tire to leak down very quickly.
    I was running tubeless using gorilla tape with Continental Mountain King tires (version 1). I never had any trouble burping or getting the tires to seat.
    I was running 32 psi at the time of the failure.
    I agree that I might have damaged an alloy rim in same circumstances. We will never know for sure, since I promptly removed the rock.
  62. #762
    Reputation: 006_007's Avatar
    OK, for the sake of our testing, please rebuild the wheel with a similar weight alloy rim. Place rock back in spot. Hit it the same (or as close to) as possible and report back
    Seriously, bummer on the rim - and good job on the trail maintenance so the next person along doesnt suffer the same fate.
  63. #763
    knobby noob
    Oct 2012
    Just laced them up with Hope Pro 2 Evos:
  64. #764
    Greystoke
    Reputation: geo025's Avatar
    Dec 2010
    Are you guys building these wheels with nipple washers?
    I think someone suggested it may help with spoke nipple alignment, but my worry would be
    the amount of carbon that the nipple could wear away.
  65. #765
    74 & 29 pilot
    Reputation: MTB Pilot's Avatar
    Oct 2010
    Quote Originally Posted by geo025 View Post
    No, didn't find it necessary.
    MTBP
    "GIVE ME LIBERTY OR GIVE ME DEATH!"
    Turn on the truth: http://www.ronpaulchannel.com/
  66. #766
    bicycle rider
    Reputation: morganfletcher's Avatar
    Quote Originally Posted by litany View Post
    Straight gauge spokes aren't stronger than butted spokes, they are weaker. Its a common misconception that the heavier spoke is somehow stronger. Spokes are very strong nevertheless. it's just harder to build with double butted spokes because they tend to "wind up" easier which just means when you are turning the nipple it's not turning on the spoke, you're turning the spoke which doesn't actually increase tension. There are techniques to deal with this it just makes building the wheel harder.
    DT-Swiss Aerolites, or a similar bladed spoke, and a good bladed-spoke holder are a great way to build a strong wheel to high tension without spoke wind-up. I built a set of Edge Composites (now ENVE) wheels like this. Helped me get the very high recommended spoke tension, safely and easily.
    Morgan
  67. #767
    RTM
    RTM is offline
    #1 Latex Salesman
    Quote Originally Posted by morganfletcher View Post
    Morgan
    I agree 100% with everything you said but for me at least, it is tough to stray from the tried and true (and reasonably priced) double butted spoke.
  68. #768
    Greystoke
    Dec 2010
    I've gone over this thread & the 29er & didn't see/read failures of the burlier build rims, Is that the case so far?
  69. #769
    74 & 29 pilot
    Oct 2010
    I had a "beefed up" 402 gram 650b rim break running normal to more than usual tire pressure and they are sending me a new one. The front is going fine so far. Pics in the 650b/27.5 forum.
    MTBP
  70. #770
    obsessive
    There is one undeniable fact that you will find true 100% of the time: In any review or thread about mountain bike wheels, both extremes will be represented- those that hammer a wheelset and love it, and those that have "I was just riding along..." stories of catastrophic failure.
    We have varying riding styles and talents, different body weights and wheelbuilding skills. There are the silent majorities and the vocal minorities. Some demand the impossible, and are never satisfied. Some understand limitations and have realistic expectations.
    Use your judgement. I bought a set of these rims for the fun of an experiment. There are tried and true workhorse wheelsets out there if you can't afford to gamble. I would still buy Deemax wheels even if some dude on a forum posted a pic saying he folded two hoops and blew the freehub hopping a curb. I'd still avoid a $100 wheelset if some other dude claims three seasons of dirt jumping without ever having to adjust tension or bearing preload. There is enough info in this whopper of a thread to base a decision on so long as you are honest with yourself about how well you can build and ride these wheels, and accept that sometimes mountain bike parts break when pushed near the limit.
  71. #771
    I quit e-MTBR
    Reputation: OldManBike's Avatar
    Well said.
  72. #772
    Greystoke
    Dec 2010
    Thanks for the blog....
    I decided it was worth the risk so placed an order for the heavier built rims last week, they should be popping out of the mold any time now.
    I'll lace up the front front wheel, see how it rides then venture on to the rear when I'm happy with it.
    I remember not that many years back I had a carbon bar that folded on me in a race, not a great experience I want to repeat. Now I'm confidently using Carbon bars again & they are stronger than any alloy bars I've owned( but still expensive).
    Carbon rims I expect will get better & hopefully cheaper down the track & we will wonder how we ever rode on alloy rims, I just need to man up now & not become the crash test dummy again...
  73. #773
    Looking for advice on tubeless setup on the rims... Trying to mount 2.35 nevegals (non-ust) and cant get them to inflate at all, even with 3 layers of stans tape. The tire bead is very loose in the groove. Has anyone managed to get these to work tubeless?
    Only options seem to be to inflate at gas station with sealant inside - would this work?? The lbs said a bontrager strip wouldn't work as they are designed only for bonty rims, but others here seem to have had success.
  74. #774
    Reputation: bajaguy's Avatar
    Having three layers of tape won't make it any easier to mount vs. one layer of tape. I ran a non UST Nevegal tubeless before on a Mavic wheel and remember it was pain to get the bead to seal. If you're using a floor pump forget about mounting it. You'll need a compressor so you can blast it with high pressure and its ok to have sealant in the tire. You really have to massage the bead all the way around to make sure you can make it seal. I remember it took me some time to get it to hook up.
    Bonty strips work great on these wheels and I have no issue running them. Not sure how they would work with Kenda tires but no issues mounting tires or holding air with Specialzed or Maxxis tires I've ran.
  75. #775
    MattSavage
    Sep 2003
    You must use a rim strip. Bontrager or Stans or ghetto... Something.
  76. #776
    74 & 29 pilot
    Oct 2010
    I've had no problems with the Nevegal on L-B rim. Seated and sealed right up with an air compressor. Take the internals out of the valve and blast the air through the valve stem to get the tire to seat. 3 layers of tape is unnecessary and is taking up room to get the bead to seat. One layer of Stan's or Gorilla tape with overlap at the valve hole should work fine.
    Good Luck
    MTBP
  77. #777
    Got my rims in the promised 4 working days. Laced them over last night and am patiently awaiting arrival of tensiometer before mounting tires and whatnot.
    They build up very nicely...considering their rigidity, that should not be news...
    They are laced over to an I9 build with Stans rims. It was weird that the spoke holes are not staggered. Weight was almost a wash...maybe 50g lighter with the new set...much wider though. the Stans rims were a 355 and Arch (non-EX).
    I think I'll order and extra to keep in the gear locker for inevitable rock hit of operator error type wheel failure.
  78. #778
    Thanks for the tips. I'll try the rim strip as I've now run out of tape!
  79. #779
    RTM
    RTM is offline
    #1 Latex Salesman
    FYI, for the archives...
    I just mounted a 2.35 maxxis dhf, wire bead, single ply, 42a "super tacky" tubeless with one layer of gorilla tape and Stan's sealant. Took about three puffs from the compressor for the bead to seat and had almost no leakage. Still holding firm 2 days later. It has been my best tubeless attempt to date and that includes an actual UST rim & tire. Good times.
  80. #780
    74 & 29 pilot
    Oct 2010
    Target, Wal-Mart, Lowes and Home Depot sell Gorilla Tape "To Go" which is a roll that is already cut to 25mm for less than $3.
    MTBP
  81. #781
    Quote Originally Posted by MTB Pilot View Post
    I'm living about 10,000 miles away from any of those stores! But I should able to get the bonty strips on Saturday from my lbs. thanks.
  82. #782
    Oct 2011
    After several rear hub shipping mishaps I finally got my set built up, 1450g!
    Wider Rims UD Matte (~360g)
    DT revolution spokes (~110 kgf tension)
    DT 240S Rear Hub (10mm)
    Hope Pro Front (20mm)
    I also managed to mount them up tubeless without any issue. This is my first tubeless (and my first carbon) wheelset so I was pretty jazzed when it all worked right away.
    This is what I did:
    1" (25.4mm) Gorilla tape on the rim (overlapping the valve hole by 2" on either side)
    Mounted Tires (Mountain King II 2.4 Protection)
    2 Scoops of Stan's per wheel
    Inflate!
    I had recently purchased a high volume floor pump from Lezyne that supposedly can mount tubeless tires. Not the case here and I don't have a compressor so I was kind of annoyed that it didn't work. I decided to try a CO2 cartridge (16g) and it worked right away on both tires, it took one cartridge per tire and they were about 25 psi after the cartridge had emptied.
    I did not put any soap on the bead and the beads still seated right away. The tires were mounted on another wheelset for the last few weeks though which supposedly helps.
  83. #783
    MattSavage
    Sep 2003
    I had recently purchased a high volume floor pump from Lezyne that supposedly can mount tubeless tires. Not the case here and I don't have a compressor so I was kind of annoyed that it didn't work. .
    Heh,heh... I fell for that sales pitch too. I wanted a pump that moved the most air for setting up tubeless and naturally the salesperson said the Lezyne was the best (coincidentally the most expensive!) but it didn't work worth crap. I hate the heads on those as well.
    I bought a Topeak Joe Blow Pro and it has worked about 80% of the time. That new Topeak JB Ace looks even better, though!
  84. #784
    Oct 2011
    Ha ha. yep. What's even more funny is that I bought the CNC version... Wait, maybe that isn't funny....
    The head is kind of annoying, I found out pretty quickly that if you use the screw on "flip chuck" adapater they have it removes the core when you're taking it off... ughh.. Oh well, I'm very happy to just use a CO2 cartridge to get teh job done.
  85. #785
    Reputation: 'size's Avatar
    so it looks like an even wider/DH version will be available at some point.
    info from ridemonkey :
    "Hello Noah,
    Thanks for your mail. Wish you will like our rims.
    One of our customer is going to design the much wider rim, it will be 35mm wide, and 27mm for the inner width. But it will take quite a long time to test.
    You can order from him when the rim is ready to sell. We will manufacture the rims for him.
    Thanks,
    Nancy"
  86. #786
    Nov 2012
    What is the length of spokes to hubs 240s ,110 20mm front and 150mm rear with 26 extra wide rims stronger 450g ?
  87. #787
    Greystoke
    Dec 2010
    Quote Originally Posted by Andrewandy View Post
    You should find what you're after here.
    #1 Wheel Building SPOKE CALCULATOR Now Online | PROWHEELBUILDER
  88. #788
    Reputation: nybike1971's Avatar
    My experience with the Light Bicycle carbon rims has been very disappointing. I built a set of their UST compatible 26in wide rims in August 2012 and the rear rim cracked while I was preriding the Moab Enduro race course down Porcupine Rim at the end of September. I had a Conti Mountain King II 2.4 tire tubeless at 28psi mounted on the rim when it cracked and I weigh 165lbs. For reference, I had ACL reconstruction surgery in May so am not taking any chances this year and riding very conservatively.
    I had to scramble and buy a rear wheel so I could ride in the race and finish my Moab trip.
    They replaced the rim under warranty and they sent me what they called a reinforced rim (around 400g). I rebuilt the wheel (CK hub and DT Comp spokes at 110kgf driveside tension) with the new rim and after only 4-5 rides it cracked again. This time I was running a Conti Mountain King 2.4 tire (850g) with a much beefier sidewall than the first generation MK tire, also tubeless at 28psi. I cracked the rim rolling down Bailey's at Blue Mountain (Peekskill, NY) - definitely just an XC trail with some rocks.
    They replaced this rim under warranty again and sent a new reinforced rim. They still charge $40 for shipping for the replacement rims, so not free, and I need to rebuild the wheel, again. Definitely not worth the uncertainty and the hassle for me. I am going back to the Stan's Flow that I had on those hubs for 4 seasons.
  89. #789
    Sucks to see - out of curiosity what did your stans flows look like after 4 seasons of riding (dents n dings?) Some people are just harder on wheels then others - and for those that do dent/ding alloy rims I dont think carbon is a great option.
    Plus side is their customer service appears ok - replacing both rims. Ya - you had to pay shipping, but that is not uncommon.
  90. #790
    Quote Originally Posted by 006_007 View Post
    Front Flow rim is perfect (that's the one I am going to use to rebuild the rear wheel) and the rear one had a couple of small dents over the years that I straightened out with channel locks and still holds air for a tubeless setup without any problems. The only reason I bought the carbon rims was to try and lose some rotating weight without compromising stiffness and width.
    In both cases when I cracked the rims the tires did not flat and Stan's sealed the crack. I don't consider myself particularly hard on gear. If you look at this video I shot a few years ago at Blue Mountain you will see exactly the spot on the trail where I cracked my rim (somewhere between 0:26 and 0:31):
    <iframe src="http://player.vimeo.com/video/2389095?badge=0" width="500" height="359" frameborder="0" webkitAllowFullScreen mozallowfullscreen allowFullScreen></iframe> <p><a href="http://vimeo.com/2389095">Fall ride at Blue Mountain</a> from <a href="http://vimeo.com/user989488">Luca Marinelli</a> on <a href="http://vimeo.com">Vimeo</a>.</p> <p>Ian, Pete, and Luca ride at Blue Mountain Reservation in Peekskill, NY on November 29, 2008.</p>
    As I said, it's an XC trail. Not really where I would expect a 30mm wide rim to fail.
  91. #791
    Nov 2012
    What is de ERD for the 26 wide rims extra stronger 450g ?
  92. #792
    knobby noob
    Oct 2012
    Noob question:
    If the trails I ride are generally free of thorns, can I just choose to get a pair of Stan's universal valve stems, a set of UST tyres (say Small Block 8s), pump it up and go ride, without adding sealant?
    Currently running a tubed setup and I believe yellow tape was already installed by my LBS. Thanks!
  93. #793
    Reputation: saruti's Avatar
    nybike1971
    maybe its time to use more PSI on the rear tire....
    I guess you would break any carbon rim with 28 PSI on the rear.
  94. #794
    obsessive
    Q: How do I lose 1.5 lbs off my bike?
    A: Replace the Transition 32s with carbon!
    Painted by Light-Bicycle to match. Extra fiber added to 385g. Per Brian, they make the extra weight with more wraps of fiber, not just resin. Can't wait to build!
  95. #795
    nice!!!
  96. #796
    ride more
    Wow...Looks great
  97. #797
    bicycle rider
    Quote Originally Posted by saruti View Post
    nybike1971
    I disagree, 28psi in a 2.4" tire is not low pressure, especially for a 165lb rider.
    I've got ~400 miles of mtn bike racing on a set of Edge Composites (now ENVE) XC 29er rims. I've only ever run them tubeless, with xc-level tires, and I think the max I've ever had in them was 32psi. I'm just over 200lbs. I usually raced them at 28/29psi. I'm a lot heavier than nybike1971, and these tires were in the 2.0" - 2.2" range. I don't know anyone running tubeless that regularly puts more than 32psi in their tires, and no one running 2.4" tires who inflates them to more than 30psi. These light-bicycle rims should be able to survive in conditions, as well as or better than aluminum rims.
    I have a set of the 29er wide rims on the way, built with extra material. I do have some trepidation about their durability, but I'm treating this like an experiment. I will build them up and ride them hard on my fun bikes, and hopefully they hold up. I'd get more ENVE rims if I could afford them. Right now I have Stans Flow rims on three 29ers. Ideally I'd race them in the Downieville Classic next summer, but... we will see.
    There's a human tendency to defend an idea in which we've invested resources, or in which we place a lot of hope. Right? Keep an open mind about these rims. The price does seem too good to be true. We'll all find out. Hopefully light-bicycle.com, and carbon manufacturers like them are using our real-world experiences and broken rims to improve their product.
    Morgan
  98. #798
    bicycle rider
    Quote Originally Posted by axl886 View Post
    Noob question:
    I don't think so, but try it and report back. Dry tubeless might work on a UST system - I believe that was the design goal - but in a Stans-style system, sealant helps to seal the system. The puncture repair aspect is another benefit. I don't have many tire-puncturing thorns where I live, but I have pinch-flatted and punctured tires, running tubeless, and sealant has gotten me home without putting a tube in. (Sometimes, I have to put a tube in.)
    Never a preposition end your sentence with,
    Morgan
  99. #799
    74 & 29 pilot
    Oct 2010
    nybike1971
    Well your guess would be wrong then
    Been running Easton Havens carbon version at 28 PSI for 6 months of hard riding in the AZ rocky terrain and no failures and I'm 190 lbs without gear. My buddy has them in 26" and 29" with the same results.
    MTBP
  100. #800
    I will agree. I am 210lbs riding weight I ride extremely aggressive and I never inflate more then 30 psi even during park riding. This is on a Hans dumpf 2.3 Stan's flow. I just had my carbon wheels built looking forward to my first ride.
