Results 1 to 3 of 3
    20mm front hub bearing replacement advice needed
    So I have a 20mm front hub that is running a bit rough to say the least. I was wondering if anyone had some advice on how to replace the bearings?
    The end caps don't seem to pop off. There is an aluminum sleeve in the center but I'm not sure how to access it.
    Attached Thumbnails Attached Thumbnails 20mm front hub bearing replacement advice needed-imag0423.jpg
    Reputation: 006_007's Avatar
    Those end caps will come off, then you will drive the bearings out.
    Hold the end gaps in a vice with a set of soft jaws to not damage the caps, then work them out gently.
    great managed to get the end caps off...do i hammer the aluminum sleeve to get the bearings out ?
