Results 1 to 12 of 12
    moar alike..
    Reputation: Deerhill's Avatar
    Dec 2009
    2010 weirwolf 2.3 am tcs
    Just got this new tire. If anyone is interested it's a little heavier.
    Web site says 800g, scale says 954g... tread looks nice though
    Anyone know the weight of the 2010 weirwolf am in 2.3 ust?
    All barks have been rendered into english...
    moar alike..
    Dec 2009
    4.08 lbs w/o fluid or rotor
    That's 4lbs 8oz on hope/flow
    Reputation: chas_martel's Avatar
    They actually have a pic of a "slime" bottle on 'em? Wow!
    Nobody cares...........
    moar alike..
    Dec 2009
    Quote Originally Posted by chas_martel
    And the lime green/gray in cursive looks worse than an Ardent.
    Side walls feel strong
    Reputation: 5H2O's Avatar
    So, WTB comes out with another version of the Weirwolf that they say is compatable with tubeless systems. I can't help but think that this is nothing but marketing for them.
    I've used a number of their tires with homemade brew without any problems. Even the seepage through the sidewalls has never been a problem.
    Am I missing something here, or is this just a way that WTB can say that they now have a tire that can be used tubeless with their blessing?
    Doug
    moar alike..
    Dec 2009
    try'n the new
    Quote Originally Posted by 5H2O
    Doug
    Got these because the new tread and rubber seems to have good support. It better for $50
    My dhf minions like to slide a little on some turns before they hook. It's a tall order, but if I can get rid of the slide in that part of the lean then I might have a new favorite.
    Never used another WTB tire.. except for a vraptor back in the day, and the tread on the old Weirwolfs don't look like anything special to me.
    moar alike..
    Dec 2009
    Doug
    What is your homemade brew?
    Quote Originally Posted by DeerhillOG
    There's a huge thread over in the 29er section called "Best Tubeless Brew". I'm using his basic mix.
    Basically it's:
    1 part Latex mold builder (I get mine at Michael's)
    1 part Slime (I use the ATV/Mower type with the black granules in it.)
    2 parts Water
    A lot of the recipes call for Anti-freeze as an extender to keep the brew from drying out. Since I live in Michigan I don't have the drying out problem that riders in hotter regions have.
    I've run this for a year now without any problems.
    I just checked into the new WW more and really like the new tread pattern. It looks like they cut down the outside row of knobs from five to three.
    They also stepped the knobs for better grip. Now if they can make this available in 29er sizes!
    Doug
    err, 27.5+
    Reputation: AL29er's Avatar
    That is pretty heavy. I have run the Stout, Prowler, and Mutano 2.2-2.3 tires tubeless. All of them were 800-900g. At 924g that is UST tubeless territory, heck even a bit heavy for that in a 2.3 size.
    Quote Originally Posted by saturnine
    that's the stupidest idea this side of pinkbike.
    moar alike..
    Dec 2009
    it's 954g
    Quote Originally Posted by AL29er
    It is a little heavy. And the side knobs seem really soft when I push on em. I want to find out the actual weight of the UST version.
    On these, the extra weight comes from the sidewall. It's seems like there's a stiff insert supporting the side knobs. When I unfolded the tire and flipped it right side out, it made a weird, almost cracking noise.
    Reputation: AK47's Avatar
    Same here...
    Doug
    I recently converted a set of Wolverine's (non-TCS) on Mavic 717's without much fuss. For the extra 140g per tire weight gain with the TCS version, I'm not sure what the point is.
    moar alike..
    Dec 2009
    800g is not that heavy
    Quote Originally Posted by AK47
    954g is pushing it a little, kind of bummed about the extra 154g's that shouldn't be there.
    How much do you and your bike weigh?
