Results 1 to 21 of 21
    Oct 2012
    2 broken spokes in 6 months from Light Bicycle
    Should I be concerned? I do trail riding and did an enduro this month. So I'm not doing any insane riding or anything. I have the 35mm wide 27.5 wheels that were laced with hope pro 2 hubs by Light Bicycle. How many times should I bring in my wheel to have a spoke replaced plus or minus truing before I just redo the wheel? This is my first experience with broken spokes so I have no idea.I was willing to let one broken spoke go but two seems a bit fishy.
    Thanks,
    Greg
    Re: 2 broken spokes in 6 months from Light Bicycle
    Did you re-tension the wheel after the first few rides? Check spoke tension regularly?
    It's about showing up.
    Reputation: Berkeley Mike's Avatar
    Spoke tension, yeah, a great place to start.
    I don't rattle.
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    I'd be very suspicious of the build quality. If you have a reputable wheel builder in the area, have them take a look at it. If you're not an animal, then it's either crappy quality spokes, or a crappy build. Or both.
    Bro Mountainbiker
    Reputation: Sheepo5669's Avatar
    May 2010
    Its likely that your wheel was a crappy build from the factory and the shop fixing it just popped in a new spoke without tension balancing.(effectively making it worse)
    Thats the funny thing about Chinese carbon wheels. Some come out of the box great, and some come out are god awful. It really depends who the factory has working... Could be the guy who has been building bike wheels for years, or it could be a builders first day on the job.
    Raised in a Chicken-Coop by Chickens
    West Chester, PA
    I don't like unknowns. Pillar spokes are unknown to me. Therefore I wouldn't buy wheels built by light bikes.
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    Quote Originally Posted by beachbum1 View Post
    I'd be... it was probably a crappy build from the start, and who knows what spokes were used.
    I'd probably de- and re-tension the wheel before I throw everything out and start over. But that'd be me doing the rebuilding, not paying someone to do it, and I'd be 100% sure of the end product.
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
    Save Jesus
    Reputation: beanbag's Avatar
    stress relieve spokes
    Quote Originally Posted by 92gli View Post
    Well you better not trust DT Swiss or Sapim spokes either, they use the same Sandvic stainless wire as Pillar.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Ratt View Post
    Same wire does not mean the finished product is the same quality.
    mtbtires.com
    I'm not sure the wire is actually the same. Sandvik makes more than one SS wire product.
    The rough stock is not the only factor.
    Spokes always fail at the points where DT or Sapim's factories would be forming/threading that wire, so I would say the manufacturing processes of those individual companies are more responsible than the company making the wire. If failures in the middle section of a straight gauge spokes were an issue then I could see the wire being a real concern, but that just isn't the case.
    One thing I can say for sure is that I see an astronomically high number of failures on Sapim spokes in comparison to DT.
    Nov 2012
    I had spokes snapping on the drive side of my Novara '29er with factory built wheels. First couple replaced on warranty by REI, more snapped every 600 miles or so. Small LBS owner comment was: 29 inch wheels, machine built wheels, spokes snap. I eventually re laced the wheel entirely, no more snapped spokes. Most snappers were on the drive side (PITA to replace) and finally one or two on the non drive side. Replacement spokes were nothing special, REI stock stainless.
    Quote Originally Posted by JSchmitz View Post
    Typical oversimplification that is short on facts.
    Glad you got your wheel sorted.
    May 2013
    Having worked on a few pairs of LB wheels I've noticed a few things.
    The spoke tension on their wheel builds is really high from the factory.
    To the OP I would like to ask if it was the spoke that broke or the nipple? LB use alloy nipples which are more sensitive to temperature change, I've had several where the 'head' of the nipple has snapped off so I've replaced the lot for brass.
    Ant
    Oct 2012
    Thanks for all of the information. They have broken at the nipple. In fact a third one broke today. same spot, at the nipple. Ugh.
    Yup. Alloy nipples generally suck. Always use brass. Slight weight penalty but worth the reliability and peace of mind.
    Dec 1998
    Quote Originally Posted by iscariot View Post
    I almost always use aluminum nipples and have for 25 years. Have had 2-3 fail during that time. I have had spokes pull out of rims with the nipples intact.
    Aluminum nipples from DT, Wheelsmith, and Sapim are more than strong enough.
    Nipples on the OP's wheels are an unknown quantity.
    mtbtires.com
    One breaking could be a fluke, or impact damage. Two typically means there is a problem. There are 1000 people smarter than me that might know the real reasons. Spoke tension, spoke twist, nipples, who knows. All I know from experience is that there is no reasonable way for mortals to fix it. If the tension, twist, or nipple lube is jacked enough that spokes (plural) have broken the wheel cannot be fixed by working on it or simply replacing the broken spokes.
    Continue to replace offending broken spokes to feed your riding habits until you can assemble the money and or parts to start over.
    A wheelist
    Reputation: Mike T.'s Avatar
    I think I remember one broken one in many sets of my wheels in maybe 24 years. So I guess you're right
    Mike T's home wheelbuilding site - dedicated to providing Newby wheelbuilders with information and motivation.
    Broke 2 on a set of 16-year old road wheels back in '97. Broke one on some factory Fisher wheels in '98.
    I don't rattle.
  1. Replies: 48
    Last Post: 07-01-2014, 04:02 AM
  2. light-bicycle or carbon-bicycle
    By superflyAL in forum 29er Components
    Last Post: 12-29-2013, 07:50 PM
  3. Broken Spokes
    By bloodninja in forum Beginner's Corner
    Last Post: 01-16-2013, 09:48 PM
  4. Broken Spokes
    By rickcin in forum Wheels and Tires
    Last Post: 10-01-2012, 10:56 PM
  5. Replies: 9
    Last Post: 03-02-2011, 08:46 AM
