Results 1 to 10 of 10
Thread: 2.6 Minion DHF
    Reputation: tungsten's Avatar
    2.6 Minion DHF
    Is it taller than a 2.35 Magic Mary?
    Weapon of Choice
    Reputation: Iceman69's Avatar
    Will it fit a non boost Fox 36 fork? any one try this?
    Super Unknown
    A 2.8 will fit in my non-boost Pike so I pretty sure you're ok.
    About that height? Anyone?
    Ultimated Outsider
    Reputation: sundowner's Avatar
    It fits in a non boost fox 34
    If I disagree with you, it's because you are wrong.
    Reputation: Ineedmorecowbell's Avatar
    Jun 2010
    Quote Originally Posted by tungsten View Post
    It's definitely taller. Can't say how much but, don't have room for my Marshguard anymore.
    I can tell you on I29's I went from a 2.35 MM to a 2.8 Minion and the height increase was a touch over 1/2". Also, the casing width went from 2.48" for the mary to 2.58" on the minion. One set of knobs measured about 2.65" (the wider sets) and the other was right at casing width.
    So, what I'm trying to say is, you're increase probably isn't much, since the 2.8 Minion should be larger, and the height increase wasn't all that drastic.
    One caveat: both these were 26" versions (26x2.35 and 26x2.8), though I think the tires should be pretty consistent between the sizes.
    Reputation: Dpca10's Avatar
    Sep 2012
    So the DHF 2.6 in the 27.5 to the best of my measuring capabilities has a diameter of 28 3/16". Now this is from the tallest center knobs with a tape measure. It's exactly the same measurement I got for my 2.8 Rekons.
    Reputation: stepping-razor's Avatar
    how would the fit be on 27mm internal rims?
    Be yourself. Everyone else is already taken.
    I run my DHF 2.8 27.5 on stans 29mm inner width and they are awesome! running 26 x 2.8 DHRII rear on my Liteville 301 Attachment 1198018
    btm
    btm is offline
    Apr 2017
    Just mounted 27.5 DHF 2.6 on Hope 35W (34 mm inner width) and there's good clearance in my 2015 fox 36. Measured the casing width to about 64 mm, didn't measure the diameter. Looks awsome, close to plus-size IMHO.
  1. Maxxis Minion 29x3.00 Minion DHF 3C
    By bonesetter2004 in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 2 Days Ago, 04:31 AM
  2. Replies: 9
    Last Post: 02-13-2018, 02:06 PM
  3. Dhf ust or standard dhf 2 ply for tubeless
    By trap121 in forum Downhill - Freeride
    Last Post: 06-04-2013, 10:08 PM
  4. Maxxis, Minion DHF, 26 x 2.5, EXO single-ply reinforced sidewall
    By CrashTheDOG in forum Wheels and Tires
    Last Post: 10-11-2011, 05:12 PM
  5. minion dhf 60a 2.5
    By GOONRock in forum Downhill - Freeride
    Last Post: 01-06-2011, 04:25 PM
Members who have read this thread: 80
