Results 1 to 12 of 12
    2.25 Schwalbe Optimal Rim Width?
    I am looking for opinion on rim width for Schwalbe 2.25 tires for xc and trail riding. My go to is rhe 2.25 racing Ralph for most of the riding season. Currently I have been running them on 23mm internal width Stans Crest MK3 rims. I really like think they shine on rims around this width. Last season I was running 19mm internal rims the profile was just too round for me.
    I have ridden a few bikes with carbon hoops and this is the route I plan to go. The precision steering and lack of wheel maintaince is pretty awesome.
    I am looking at rims between 23 and 30mm. I think the 2.25's are just too narrow for the 30mm. I am about 155lbs and the 2.35 is nice, but for my size the 2.25 is all I need.
    Anyone care to chime in on rim profile they like?
    I am thinking maybe NOX and they offer 23mm, 26mm and 30mm internal models.
    Reputation: solarplex's Avatar
    Apr 2014
    When ever my RR comes in ill be running it on a i27mm rim. Top fuel running a xr1 2.2" in the back. Really depends on the tire... some trek team riders run i29mm rims and Bontrager 2" tires.
    I thought 30 was a bit wide so i went 27mm
    Fatbike, XC bike, Gravel Bike....
    I saw that Emily Batty was running crazy wide rims, but those Bontrager tires have a pretty large volume casing.
    Even Nino is on the top shelf DT carbon 1200 wheel that are like a 24mm internal. I am thinking 26mm for the NOX will be the ticket.
    Apr 2014
    These are 2.25 racing Ralph's on 30mm internal width rims
    Have only ridden with them once yet but wasn't really amazed with changing from 23 to 30mm rims although that's also when I changed from 2.4 mountain king to racing Ralph's. In the past I did ride the racing Ralph's often, more tyre is not really needed in the Netherlands and they probably work perfectly on a 25~26mm rim as well.
    Sent from my Moto G (4) using Tapatalk
    I'd go 26mm for 2.25 I've ran them on 30 and 26 I think the 26 felt better for that size. I'm currently on 30 with 2.35 and after slowly dropping pressure a lot I love them. But 26 with 2.25 were lighter and faster rolling from my experience.
    Reputation: MSU Alum's Avatar
    My conditions are different than yours, as I ride in Park City and Moab (Utah, USA).
    I have run 2.1 and 2.25 RaRa's on a 26" 19mm id rim for years (SS pacestar) as a rear tire and loved them. On timed climbs, I found the 2.1 to be slightly faster than the 2.25 (and I posted personal records on them). But they wore out after 150 miles, so I gave up on them.
    I've ridden different tires on 19mm, 23mm and 35mm. My personal experience is that rim width, within reason, has very little affect on my times, the amount of grip I get or my cornering ability. Ride whatever makes you happy, because you may get a bit more comfort from increased volume.
    If you are running WT tires (Maxxis), or tires bigger than 2.4" width, then I think going bigger is a good step. But I've ridden 2.6" tires on 23mm and 35mm id rims. I prefer the 35, of course, but if you're on a budget, 23mm will work well, they just require about 2-3 psi more. The tires only have a round profile with no weight on them. Once you load them up, they flatten out, of course, so that round profile no longer exists. The issue with big tires (that is less of an issue with smaller ones) is that there is less sidewall support, so the wider profile allows lower pressure.
    There is a big push on for wide rims, so I am a bit of a heretic.
    As I said before, my fastest timed climbs were on the 2.1 RaRa at about 23 psi rear. I have since gone to a 27.5x2.6 Rocket Ron rear at 16 psi and I have beaten the times I clocked on the little RaRa! The tires wear way better (but any 2.6 will wear better than a 2.1 or 2.25), they grip way better as the tread is deeper, and the wide rim in this case really does allow me to run low pressures. I recently put a 2.6 RoRo Addix on the back, went out the door, and immediately got another personal best on a timed climb. That's no small feat, as I'm 65 years old riding above 7000 feet.
    I know the question was rim width Vs. narrow RaRa's, but if you are considering wide rims I think 2.6" may be a "sweet spot" on tire size, if you can run them.
    How's that for a long rambling response?
    Apr 2014
    Quote Originally Posted by DannyvG View Post
    Whats the tread width and body width of that tire on those rims? Thanks
    Apr 2016
    I've ran 2.35 on 32 ID rims and I thought they werent a good match. Felt like the tire got squared off and and the sidewall tread was touching when going straight.
    That being said I could run between 16-20 psi with no issues. Horse for the course may no be the right option for you
    I'm 225ish geared up for ref.
    Apr 2014
    Quote Originally Posted by solarplex View Post
    Thread width 55.5mm and body width 57.6mm
    Reputation: Dougal's Avatar
    How big a deal is ripping open a sidewall? Some trails make it a real danger, some it's never a problem.
    I have 30mm rims and maxis 2.35 have the knobs level with the sidewall. I wouldn't go past 25mm for 2.25 tyres.
    Sent with 100% recycled electrons.
    Owner of www.shockcraft.co.nz and NZ Manitou Agent.
    www.dougal.co.nz Suspension setup & tuning.
    SPV Devolve
    psycho cyclo addict
    Reputation: edubfromktown's Avatar
    No difference here...
    All of my bikes and also my wife's have Racing Ralph 2.25's Crest, ArchEX, Flow and FlowEX other than a 2.35 RaRa on my of my single speed 29er's.
    I scored seven of the 2.25 RaRa's with Niner logos (seem slightly narrower than the blue/silver manufacturer boxed Schwalbe 2.25 RaRa's) from Jenson for $20 each months ago.
    They work fine (no difference for me in terms of rim width vs performance). I haven't slashed a sidewall on non-snakeskin ones yet (I run a couple of snakeskin 2.25 RaRa rear tires too).
    【ツ】 eDub 【ツ】
    Reputation: Mark16q's Avatar
    I'm running 2.25" schwalbes and just yesterday ordered up a set of 27.5 Nox Teocalli's. Encouraged that i26 sounds like a good match for this tire size. Don't need new wheels but had to have these and can't wait 'til they show up.
    '16 Scott Genius 700 Premium
    '14 Giant Anthem Advanced 1 27.5"
    Cervelo R3sl
    Seven Alta
    Curtlo h/t
  1. Replies: 8
    Last Post: 10-22-2017, 07:27 AM
  2. optimal tire width to WTB asym i29?
    By Amit Ifrach in forum Wheels and Tires
    Last Post: 11-15-2016, 01:50 PM
  3. Looking for optimal tire width/tire for Super V2000
    By autobon7 in forum Cannondale
    Last Post: 10-12-2015, 01:49 PM
  4. 29er optimal front and rear rim inner width?
    By party_wagon in forum Endurance XC Racing
    Last Post: 05-24-2015, 10:25 PM
  5. 30mm width rim an upgrade from 24mm width rim?
    By metrotuned in forum Wheels and Tires
    Last Post: 07-22-2012, 07:30 AM
Members who have read this thread: 74
