Results 1 to 6 of 6
    12mm axle in 10mm drop outs???
    I just purchased a wheel set that can be converted to 12mm axle. The threaded portion of the axle that sits inside the dropout measures 11.65mm. My dropouts mic at 10.25mm...can I just drill out the dropouts to accommodate? There is a ton of meat on the back end of the dropout, so not really worried about getting too close...what do you think? Pipe dream? Or do able?
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by outtashapeguy View Post
    How would you secure a 12mm through axle in open dropouts?
    mtbtires.com
    A nut on each side...just like a bmx bike
    Reputation: Fix the Spade's Avatar
    Azonic Momentum Axle 12mm X 135mm | Azonic | Brand | www.PricePoint.com
    Azonic did (discontinued now) a step down bolt-up axle that let you run a 135x12mm hub in a 135x10mm quick release frame without having to drill anything out.
    Pricepoint still have them in stock and I'd recommend one of those over taking a drill to your frame, even with shipping it will be under $20.
    Reputation: Ronnie's Avatar
    Sun Ringlé also have a 135 X 12 bolt on axle that steps down to 10mm. that should work. It's also fairly cheap and any LBS should be able to order it for you I agree that I would not take a file or Dremel to my frame.
    The trouble with having an open mind is that people will insist on trying to put things in it.
    Crap....didn't even know these existed! Well that solves my problem...quick and cheap....that's the way I like it!
  1. 10mm saint and zee rear 135 mm hubs fit QR drop outs?
    By aBicycle in forum General Discussion
    Last Post: 07-19-2012, 02:10 PM
  2. Rear 10mm thru bolt vs. 12mm axle
    By jbf in forum Wheels and Tires
    Last Post: 06-10-2012, 06:01 PM
  3. 12mm hub in 10mm drop out??
    By expatrider in forum Turner
    Last Post: 12-07-2011, 11:09 AM
  4. 12mm to 10mm step down through axle, where get one?
    By reptilezs in forum Wheels and Tires
    Last Post: 05-14-2011, 01:13 PM
  5. Hadley 10mm thru bolt for horz drop outs?
    By Jason B in forum Urban/DJ/Park
    Last Post: 04-25-2011, 11:05 AM
