Results 1 to 17 of 17
    The "pusher"..
    Reputation: Dream Bikes's Avatar
    XTR Rear Der - 174g [Tuning]
    Thisi is my last tuning :
    http://www.forumfree.net/?t=6514663
    Nice. What pulleys are those?
    Reputation: nino's Avatar
    Vuelta...
    Quote Originally Posted by consolidated
    those are some older Vuelta Delrin pulleys. nice things that also dropped 10g on my Dura Ace...
    sorry Marco for posting your pics!
    Reputation: Twiggyperson's Avatar
    Feb 2005
    too bad its rapid rise... jk, very nice though! im jealous of all you with time/money/patience to tune all your parts. i think its cool!
    Im just saying..
    Reputation: scapin's Avatar
    Quote Originally Posted by nino
    Mauro!!!
    Quote Originally Posted by scapin
    Mauro!!!
    oh Dio....sempre lo stesso sbaglio
    MAURO!
    Aug 2005
    I have also done a little tuning work on my xtr mech. 960 longcage org 202.. now 161 with ti bolt for wire. I have order a dousin of al bolts, and a srp bolt to mount the mech to frame is coming.
    I've done custom pins (for the links) in the lathe with m4 screw threath in the end to make it possible to dismount. I have also made a pair of carbon plates in the miller with CC of 70mm (longcage is 87mm)
    otherwise I've change the end screws to plastic ones as the jockey screws.. the jockeys is homemade ones in carbon with smooth skf bearings.
    Reputation: AndrewTO's Avatar
    Mar 2005
    Hey, wait a minute!
    I thought XTR RD's were already supposed to have a titanium pivot bolt?!?!?!?!?!?!??!?!?!?
    I ..... need ..... DIRT!!!!!
    ... and cookies.
    correct...
    Quote Originally Posted by AndrewTO
    Hey, wait a minute!
    correct - but Aluminium is half the weight of Titanium!
    SUBLIM8er
    Reputation: Axis II's Avatar
    I wouldn't go AL for my RD pivot bolt. The first time you drop you bike on the drive side you lose your RD. This seems like a good example of foolish weight savings to me.
    Every man has inside himself a parasitic being who is acting not at all to his advantage.
    William S. Burroughs
    Quote Originally Posted by Axis II
    X.0 has already alluminium pivot bolt...
    I don't know. I just got my X.0 - the pivot bolt is drilled right through which is nice and it looks to be aluminum but I'm not 100% sure.
    Anyways, I think those aluminum bolts are pretty damn tough...
    Quote Originally Posted by eurorider
    Aaargh!
    XC Geek
    Reputation: AZ Steelhead's Avatar
    Good job!
    5 years never broken one, they're tougher than you think
    I should be doing something more productive with my time!
    Do It Yourself
    Reputation: Homebrew's Avatar
    Quote Originally Posted by AZ Steelhead
    I've broken 3 of them back when I had a SC Superlight (non-replaceable hanger). Each time it broke, it stripped the nub on the derailleur body rendering it useless and scatter the b-tension parts all over the trail. Not worth it. It's too bad SRP stopped making the Wreck-Defier which could be changed without removing the b-tension.
    Long Live Long Rides
    Reputation: jeremyb's Avatar
    in what ways was the Wreck Defier different than just the aluminum pivot bolt? Any pictures out there?
    Also, anyone have some tips on how to change out the pivot bolt fairly easily?
    thanks
    jeremyb
    Reputation: top_ring's Avatar
    Quote Originally Posted by jeremyb
    thanks
    jeremyb
    Getting it off is the easy part.
    Here`s what I do to get it back on. Put a 5mm allen tool snugly in a vise pointing upward, then insert the new pivot bolt into the deraileur body with all parts lined up ready for installation. Now put the pivot bolt (with all the parts lined up) onto the tool in the vise holding the parts together. Push down to compress the spring and twist at the same time to align the derailleur body to receive the retaining clip. Once the spring and derailleur body are in line and in their compressed state, you can install the retaining clip.
    Once you do it, you`ll realize how easy it is.
