Results 1 to 9 of 9
    Reputation: DavidR1's Avatar
    XTR Dyna Sys Shifter with Dura Ace 7900 FD?
    Well, has anybody tried this? I would like to use a braze on Dura Ace 7900 front derailleur with my XTR M980 shifters. Will this combination work?
    I don't shift down to my little ring alot, but I certainly don't want to have any issues when I need to. Looks like a weight savings of ~60g to be had here, if it will work.
    CyclingCentralVa.org
    Cable pull will work fine- pull is the same regardless of road/mtn, Shimano/Sram. My concern would be the jump between rings might be tuned differently. Ask in the Drivetrain forums. Some guru there would be able to help better than I can.
    Hello,
    I'm using a XT M770 shifters with a Dura Ace 7900 FD and I don't have any problem.
    Before I had a SLX FD and this Dura Ace shifts much, much better and it weights half.
    I'm using 24-38. chain rings.
    Best
    X.
    Oct 2007
    Quote Originally Posted by ryguy135 View Post
    Cable pull is different for Shimano road and mountain front derailleurs. You can use a mountain shifter to shift a road front derailleur (and I have), but it takes more tuning to get it to work right.
    2015 Niner Jet 9 Carbon
    2014 Focus Raven 27R
    2017 Lynskey GR250
    2016 Niner BSB
    1987 Haro RS1
    Good to hear guys, thanks for the feedback. I'm going to give it a shot.
    Litespeeder
    I had this combo, and could get it to shift well, but could not get it to work without rubbing, drove me mad! This was on XTR 42:30 Double Crank, XTR Shifters, XTR Block etc
    Quote Originally Posted by stevec1975 View Post
    What is an XTR Block?
    The Missing
    block is referring to the cassette.
    Feb 2007
    using combination of XTR 970 shifter and DA brazed on FD
    chainring combo is 37-24 and work perfect
    Just have to file some material at derailleur ( see pic. ) to accomodate for extra movement
    Attached Thumbnails Attached Thumbnails XTR Dyna Sys Shifter with Dura Ace 7900 FD?-img_5786.jpg
