Results 1 to 35 of 35
    Reputation: sylvain's Avatar
    XTR cranks are not all born equal
    Well after years of using postal scales at work i finally got myself some ;-)
    Trying to decide on a new drivetrain for next season - I checked the xtr bits i have:
    - 952 cranks in 170mm
    - 950 cranks in 170mm! (ok they have been polished, on one side and only with sandpaper, so that's gonna take off what, 2gm maximum):
    You can see the difference in size between the two which explains the 57gm difference:
    - 950 rings (used):
    - 952 rings (new):
    So with a 184gm 950 bottom bracket, lockring and crank bolts i can have a complete crankset for just over 800gm - not bad for standard-sized, top shifting quality, super stiff parts that are mostly over 5 years old.
    So i think i'll do this rather than compact cranks with a ti square bottom bracket. Will have to see if i can do with the 24 * 27 smallest gear when coupled with a Dura ace cassette ...
    Fuel Master
    Reputation: emkay's Avatar
    You should try replacing the xtr rings and spider with a TA Specialites spider and rings - would make the set lighter!
    Well seeing as i have all those spare parts i might as well use them. And the rings are not exaclty dead heavy are they. I have got a spider though, but it's for 5 bolt, standard rings (which i also have in xtr 26/36/48 brand new - but that would be pushing it a bit on the gear ratios!).
    Reputation: carlos's Avatar
    wow! thats almost the same setup i use. i have been using the arms and bb for almost five years.. but last year i changed the rings and spyder to xt. now im going to put some ti crank fixing bolts and thats it.
    hey
    ho
    lets go!
    Cool.
    You mean crank bolts or chainring bolts? Cos i doubt ti crank bolts would be lighter than the stock alloy ones?
    Quote Originally Posted by sylvain
    Cool.
    i mean the crank fixing bolts, the ones that fix the bb to the crank arms.
    or if you trust aluminum, you can get these from FSA. i bet it will be lighter than ti.
    hey
    ho
    lets go!
    the ones that came with the xtr cranks are alloy and weigh 16gm a pair i think.
    mine´s where steel. dont know the weight...
    hey
    ho
    lets go!
    i've think you've been done!
    jonny_mac
    Guest
    where did you
    get the sid world cup with the nitride coated stanchions
    and the carbon crown? i knew they released it with the aluminum
    crown but i thought they had problems bonding the carbon crown
    to the nitride so they went with the "slippery silver" instead.
    its slipery silver, its looks gold but its not nitrid coating.
    hey
    ho
    lets go!
    MaLóŒ˘*size=
    Reputation: MaLoL's Avatar
    i wonder how much weights that bike?
    jonny_mac
    Guest
    thats actually
    a clean build that i would feel safe riding.
    Quote Originally Posted by MaLóL
    i weight it complete and it was 9,684grams. since i weight 86kg i think i can loose at least 400grams on this bike without spending too much $$. more than that is beyond my $$ now.
    hey
    ho
    lets go!
    -> SickLines.com <-
    Reputation: mtb_biker's Avatar
    Quote Originally Posted by carlos
    Those are some shiny rims.. they dont' seem to have been touched by a brake pad. I assume the picture was taken when it was new
    Get your freak on!
    Those look like Shimano skewers! You should really replace those
    Forging Elite Awesomeness
    Reputation: Upandatem's Avatar
    Quote Originally Posted by bike_freak
    Of course they're shimano skewers, deore apparently, what's wrong with them?
    Old man on a bike
    Why would different parts need to weigh the
    Quote Originally Posted by Mr. Scary
    Wow, so there are weight variances in production parts? Yet whenever one of the "supposed" weight weenies throws up a spreadsheet for their lighter than light bike-the parts are ALWAYS at the absolute bottom end of the production claim (and sometimes lower)...
    Kind of makes you wonder, doesn't it?
    same? Just because they're XTR doesn't mean all XTR over the years are the same....
    suum quique
    Quote Originally Posted by Bikinfoolferlife
    True, but you'd've thought that over the years the XTR parts would've gone lighter not heavier.
    Get your freak on!
    Quote Originally Posted by Upandatem
    They are very heavy, can save 70grams there, for only $10 if you get cro-mo bolt-ons.
    you are both right. those are deore skewers and are pretty heavy. but i already choose some parts to loose weight this christmas:
    ritchey wcs (31.8) stem
    bontrager xxx lite carbon flat bar (31.8)
    post moderne bar ends
    shimano 959 pedals
    bolt on skewers
    i think i will loose at least 300grams with these changes.
    hey
    ho
    lets go!
    the catalan connection
    Reputation: What&son's Avatar
    They even change cog spacing....
    ...so go figure.....Get a CS M 900 xtr cogset and is 8 speed, but you get a CS M 960 xtr and is 9 speed !! That´s abuse.
    "Blessed is the man who, having nothing to say, abstains from giving us wordly evidence of the fact." George Elliot
    Maybe I'm just not a 'true' WW but bolt-on's just seem like a dumb idea for anything other that a city bike. Who want's to fumble with a stupid wrench un-bolting the wheel after an exhausting race? It's hard enough after a grueling ride to un-do a skewer never mind a bolt on...oh well it's just skewers...(did that offend anyone? I forgot i'm on the WW board)
    nightriding is fun !
    Reputation: Big Bad Wolf's Avatar
    Carlos, Peleaze level that saddle, your wife or girlfriend will be grateful
    Nice bike !!
    Titanium or Bust !
    Candlestick Maker
    Reputation: baker's Avatar
    Such an overwhelming task...
    baker
    Quote Originally Posted by Big Bad Wolf
    Nice bike !!
    i knew someone was going to say that.....
    the problem is with my a$$! i already tried everything but this is the best position for me, i have been riding this way for at least 10 years and my son is 3 years old!
    hey
    ho
    lets go!
    Quote Originally Posted by jonny_mac
    thats actually a clean build that i would feel safe riding.
    as opposed to what?
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Sylvain
    If you decide to not use the M952 170mm XTR arms, would you kindly email me at mikec@bwn dot net?
    I'd like to buy a set (have been looking on MTBR and eBay for about a year) of 170's and I'd gladly buy them from you.
    Thanks,
    MC
    Reputation: tmaybee's Avatar
    Thanks for the weights. The bike looks great! I find bolt-ons to be easier than QRs. Dusted74 ti skewers are 44g w/ springs.
    Cheers,
    Trevor
    Quote Originally Posted by tmaybee
    agreed
    Trevor-
    Do you know anyone who has gotten these skewers recently? I have sent two emails inquiring if they are still available and not received a response.
    Cheers,
    Trevor
    LE Reporter
    Reputation: Markus B.'s Avatar
    Dec 2004
    Good job!
    Thank you for that information, I was just about replacing my old scratched FC-M950 crankarms by brandnew FC-M952 arms.
    But now I can't do that anymore: 371 g compared to 420 g (both 175 mm / without spider, spider lockring and crank bolts).
    perhaps the 952 crank arms are the downhill version? that could explain the extra 'beefiness'.
    120 pounds of xc sex!
    Reputation: carbnjunkie's Avatar
    Aug 2003
    carlos...
    is that what i think it is on your avatar with the bug...heehe
    Team X-poser is back for 2006-
    WTB; 1.25 inch tow rack in SoCal
    >Ankur<
    Quote Originally Posted by carbnjunkie
    That will rattle the crowds..
    Titanium or Bust !
  1. HELP..new FSA cranks OR quality rings for 952 XTR..OR 2x9
    By seatstay in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-30-2004, 10:19 PM
  2. XTR cranks on a SS
    By Winky in forum Singlespeed
    Last Post: 06-26-2004, 10:27 AM
  3. smaller ring on XTR cranks?
    By FishMan473 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-11-2004, 09:16 PM
  4. XTR 952 cranks + new spider (Paging Homebrew & Shylock?)
    By slcpunk in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-03-2004, 12:21 AM
  5. spindle length on new xtr cranks
    By yeroc in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-06-2004, 03:36 PM
