New X01 crankset, gxp, 175mm arms weighed with the retaining screws for the direct mount ring I'll be installing from Absolute Black. New 1091r chain with full links, new XG-1080 11-36 cassette, and a shot of the stock X01 spider with retaining screws. The (3) retaining screws were 5 grams total.
Well its the spider that came new in the box with the crank so....I don't see any reason why they wouldn't use the same spider, only real difference structurally between X0 and X01 is the chain ring, right?
See that would be logical that X0 , x01 and xx1 would use the same spider.
Unfortunately SRAM in their infinite wisdom has made the x01 spider different. Which is why the smallest ring you can get for the x01 is a 30t where a xx1 can take a 28. And from what I have read the wolftooth will not fit the xo1 (unless they make a different interface)
If someone could confirm I am wrong that would be awesome, but that is the info I have after discussions with people in the industry.
I could care less about the spider as I'll be running a direct mount chainring, been doiung that the last couple years with MRP bling rings, excited to try it with the new lightweight Absolute Black no drop ring.
Mine mounted fine. I actually had to warranty the X01, and sram gave me an XX1 replacement (awesome!) and I swapped the spiderless over. Works just as well on either crankset.
The steel insert for the pedal threads began to loosen within the carbon. Thought it was play in my pedal spindle at first, but it turned out that there was a void in the carbon or something.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
