Results 1 to 16 of 16
    Reputation: mpap89's Avatar
    Mar 2005
    Wheelset build questions
    I am thinking about building a wheelset. I'm kinda thinking of going with:
    stans olympic rims
    sapim cx-ray spokes
    dt aluminum nipples
    am classic disc hubs or 240 disc hubs
    i have some questions about using the sapim spokes. since they are bladed am i going to need to drill out the hub flange to fit the wider spokes? i'm wouldn't be too thrilled about doing that. also what do you guys think about those stans rims?
    thanks
    -Mpap
    Reputation: Some Guy's Avatar
    Mar 2005
    The spokes are only bladed in the middle section, the ends are normal shaped.
    That's the rim end, but you get the idea.
    As for your other questions, I'd recommend the American Classic hubs over the DT swiss ones. My last wheelset (Bontrager Racelite) used DT hubs, and I've found the AmClassic to be a bit more reliable.
    Mar 2005
    well is the middle section of the spoke too wide to fit into a normal mtb hub flange?
    Mar 2005
    Do you see how those spokes taper down to a normal shape at the end? They do that at both ends, so they should work like any other spoke.
    Reputation: KMan's Avatar
    The spokes will fit..
    thru any standard hub flang without the need to do any drilling.
    KMan
    Mar 2005
    thanks for the quick answer...i leave a question when i go to bed and the answer is there when i wake up. do you guys know the best place to get these spokes? i see that universalcycles.com has them for 2.49 each. any cheaper.
    http://www.universalcycles.com/shopp...9&category=780
    thanks
    -Michael
    Feeding your addiction
    Reputation: Ventanarama's Avatar
    Dec 2001
    Quote Originally Posted by Some Guy
    You must have just had bad luck, because in general the 240's are vastly more reliable than the AM Classic, not even close.
    Larry
    Mountain High Cyclery
    "It is inhumane, in my opinion, to force people who have a genuine medical need for coffee to wait in line behind people who apparently view it as some kind of recreational activity". - Dave Barry
    It's not about the ends, he's talking about the width of the bladed section in relation to the diameter of the spoke hole at the flange. If the bladed spoke is too wide it won't go thru the holes in the flange of the hub unless the hole is slotted by hand or is slotted from the manufacturer.
    Reputation: Strong Ti's Avatar
    Jun 2005
    I got mine from
    Thorusa, same price give or take a cent, but the black CX-Rays are cheaper at Thor.
    http://www.thorusa.com/product10.htm
    I see that Universal have 10% off offer on for order over $100 so a set of CX-Rays should qualify
    Mar 2005
    Quote Originally Posted by consolidated
    yeah, thats what i was thinking. is attempting to slot them myself to risky. i've heard it voids the warranty. are there any hubs that are pre slotted. Thanks
    -Michael
    Dec 2001
    Quote Originally Posted by mpap89
    -Michael
    You don't need to slot them at all, as someone already said above, CX-Ray's fit through normal spoke holes just fine. I build with them all the time and have never had to use a slotted hub.
    Larry
    larry@mtnhighcyclery.com
    Don't CX-Ray spokes come with Sapim Polyax nipples?
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Daner
    I have always ordered nipples separately. Never needed a locking nipple either.
    mtbtires.com
    Weight Weenie Shop Owner
    Reputation: DIRT BOY's Avatar
    Aug 2002
    Aslo look at DT Swiss Aerolite spokes....
    same weight and overall better quality from what I am hearing.
    Also look at Wheelsmith XE14 "The Edge" spokes. Cheaper than both, close in weight and bladed.
    Mike @ oddsandendos built my set with these for cost, strength and his reccomendation.
    I am using DT Aerolites on my road set and I am very happy after 800+ miles now....
    DIRT BOY
    Light-Bikes.com
    The Largest Site Dedicated to Light Weight Bikes and Sales
    Twitter: @lightbikes_com
    Mar 2005
    cheaper sapim cx-rays
    i found some really cheap cx-rays. I found them on wheelbuilder.com for $2.10 silver or $2.20 in black. then its an extra $.26 for colored alloy nipples.
    http://www.wheelbuilder.com/closeup....d=142&offset=0
    -michael
    Reputation: Carbon Ken's Avatar
    Mar 2005
    Michael,
    I was just about to post a link to wheelbuilder.com. I also found them to have the best prices on the CX-RAY's.
    By the way, did you determine the lengths of your spokes ? I was just playing with a few generic spoke calculators and they all seem to be much shorter than the calculator on the Sapim site - like up to 7mm different. I find it strange since the Sapim calculator is also a generic one which doesn't even take into consideration the type of spoke you're using.
    Ken.
