Results 1 to 42 of 42
    Hack Racer
    Reputation: Cheers!'s Avatar
    What is the story on Acros .54 hubs?
    Front Hub Disc: 103g w/ Ceramics
    Rear Hub Disc: 208 g w/ Ceramics
    and if you don't believe in Ceramics (I'm not convinced they are better except for being lighter), there exists non ceramic models:
    Front Hub Disc: 113g w/ Ceramics
    Rear Hub Disc: 214 g w/ Ceramics
    Are the claimed weights accurate? Hubs reliable?
    Comparison:
    Tune King: 136g
    Tune Kong: 225g
    Dtswiss 240S front: 154g
    Dtswiss 240s Rear: 273g
    Is this the new 'must have' hubs? Ever since Tune started getting creaking issues (I haven't had a problem), and Alchemy Bicycle Works here in the USA stopped being the distributor for them... Tune seems to have fallen out of favor.
    That would save 100gr compared to a 240 setup.
    I would like to see how those hub are made (inside).
    Hack Racer
    Looking at prices online... just do a search on google for "acros 54" shows from UK bike places they are around
    $145 USD
    $265 USD
    when VAT is removed and the British Pounds converted to USD. Which is a damn fine price if you ask me. I wonder if Acros will give me a free set for just mentioning it here on this forum.
    Looking at the Acros manual it says the rear hub has 5 pawls with 30 points of engagement. In the manual the lightest weights mentioned are 136g and 242g... so there is some discrepancy between the website and the user's manual...
    Reputation: Hand/of/Midas's Avatar
    well Acros is Distributed in america by J&B, a very common distribution center, so that's great news either way.
    and those are great prices, even if they only are the same weight as 240s and the like.
    Reputation: Tiffster's Avatar
    If they have different hub caps to use 9mm RWS skewers id definetly be interrested...
    Reputation: Batas's Avatar
    Any more info on this hubs? Where to get the manual?
    Universal Cycles has these hubs, and the weights listed there are about 50 grams more per hub.
    Even so, not bad if they proove to be reliable...
    Hack Racer
    I never ended up going with these hubs. When I was searching for these things back in Nov 2008 there were no where to be found. If you wanted the "ultimate" versions that are the lightest they are not sold by BTI or the other USA distributor...
    I went with Tune in the end.
    Reputation: Dex11's Avatar
    May 2005
    * Bump*
    Anybody got some more info/ride reports on these hubs ?
    They look really interesting......
    Last season I raced on a .54 based wheelset. It took a lot of abuse from my side but it's still running smoothly. I will continue using it this season.
    There isn't really much more you can say about working hubs, is there? Well, Acros seems to be one of the better companies (if that matters at all). My "personal" wheel builder, who also works for some pro teams, speaks in high terms of this company and their products ... and he's definitely more qualified for making such a judgement
    Doesntplaywellwithmorons!
    Reputation: DeeEight's Avatar
    The hubs are Chin Haurs, these are a similar version labeled as A2Z on ebay.
    http://cgi.ebay.com/New-a2z-Disc-Bra...item27aeca4263
    119g and 231g respectively for 350g total. I remember when a shimano rear hub alone, non-disc, was 350g.
    May 2005
    I thought Acros wase a craftmanship company, but also they relabel there stuff.
    Is it the same with there headsets ?
    @ quax
    Are you using a standaard .54 hubset ? or the ultimate ones ?
    What rims and spokes you use them with ?
    Hack Racer
    What does Chin Haurs hubs have to do with Acros hubs?
    Acros is a manufacturing house in Germany. They produce many parts for Tune. I was trying to get my hands on a set, but availability 1 year ago was poor. Also I got a sweet deal on a set of tune hubs from Alchemy Bicycle Works.
    Cassoulet forever !
    Reputation: 20.100 FR's Avatar
    you can clearly see on the hub flange of the drive side that these are NOT the same.
    Deeight, you are wrong.
    Acros are reputed here in france for the quality of their products. I haven't tried them myself, but know of several happy ridders.
    By the way there are lighter version of the tune hubs than the weight listed here.
    Frenchspeaking 29"ers community site http://VingtNeuf.org
    DeeEight, sorry, that's bs what you're saying. Acros is finest German engineering, no relabeling. You can see their machinery for the hubs at 45sec in that video:
    <object width="512" height="288"><param name="allowFullScreen" value="true" /><param name="allowScriptAccess" value="always" /><param name="movie" value="http://videos.mtb-news.de/v/2253" /><embed src="http://videos.mtb-news.de/v/2253" type="application/x-shockwave-flash" width="512" height="288" allowFullScreen="true" allowScriptAccess="always"></embed></object>
    (Source: German mtb forum)
    Dex11, I could only afford the standards. Setup is with ZTR 355 and Sapim CX-Ray.
    West Chester, PA
    I'll be damned. He picks up one of those hub shells and shows it to the camera. I would have also guessed that they came from taiwan too, the design is so similar to them.
    Acros BB
    I am using an Acros ceramic bearing BB. It is excellent and very light. Machining quality is the finest.
    Oh yeah, no similarity at all.... just nearly identical flanges, disc mounts, end caps, all that's just a coincidence.
    damn communists, I knew that they are still around, flooding the hub market
    end caps are completely different, Acros hubs are much larger in diameter and have no gap between disc mount and flanges
    you're right about the flanges, they have both 32 holes
    (I actually feel a little bit silly explaining what really everyone can see.)
    Chin Haur is a big manufacturer and there are slight stylistic differences between all their many branded hubs. Are you naive enough to say that because an AC hub doesn't look like a WTB hub, that they didn't share a common manufacturing origin ?!?
    "Hand built in Renningen, Germany"
    May 2005
    Different opinions where they are made.....
    Anyway, weight wise they are interesting. To bad not many people have used them, after all those horror things I had with my Tune hubs, as well as a lot off other people here, I am in doubt between these and DT Swiss 240's....
    After the post from Quax, I think I am heading Acros. ..
    West Chester, PA
    Quote Originally Posted by DeeEight
    I was buying some stuff from universal today and saw these hubs - $583 for the set
    They better not be chinese for that price !
    They're only $583 because of the import duties. Same reason Hope hubs are expensive in NA, but cheap in the UK.
    May 2005
    In Europa they cost 424 euro, thats about 532 US.
    sometimes cheeky
    ones more disqualified.
    Why don't you shut up when you're not sure about the thinks you blubber ?
    Why don't you shut up yourself when you're incapable of spelling correctly ?
    pedal pusher
    Reputation: f3rg's Avatar
    DeeEight, stop being a prick. So you were wrong about a minor thing, so what? Just let it be.
    sometimes cheeky
    Is that all ?
    Topic: the first charge(s) of the .54 hubs had some problems (e.g. loose freebody or gets cracks in the rear hub body). Therefore I recommend not to by such hubs at Ebay, could be a mistake
    (no, I am not a dealer ;-)
    Slovakia (Europe)
    Reputation: PeterG's Avatar
    I'm looking for some lightweight but reliable front disc hubs with larger bearings than Tune King uses. Can anybody confirm, what bearing size or type is used in Acros .54 front hub? Thanks.
    Reputation: phlegm's Avatar
    This thread is >5 years old, however I did a quick check at Acros and they don't appear to make the MTB .54 any longer. It is listed, but their page is blank:
    http://shop.acros.de/hubs/.54-mtb/
    Slovakia (Europe)
    I've found that too before asking , but .54 hubs are still available on the market but any detail information is missing.
    After 3 non-answered e-mails to Acros, today I've finally received reply from them with technical information about newer Nineteen ED hubs, which replace .54 and .74 hubs.
    The Nineteen looks like it could be a great hub:
    Angular contact Stainless bearings, with adjustable preload, and a good weight.
    Not as light as extralite, but not as expensive either, and I'd guess that the bearings would last longer in the acros.
    Not sure what POE they are though. If I had the $$ i'd consider swapping my chris kings for these
    Lapierre XR29ei, Chris King LB Carbon, XTR 1 X 10
    Planet X Dirty Harry
    Chiner 29er SS
    Slovakia (Europe)
    Bearings are stainless steel angular and very large, 19/30x7 mm (compare to quite narrow Tune King bearings 17/26x5mm), actual weight in the TA15 version is 137.2g (claimed). Flange parameters are the best of 12 lightweight hubs I've checked (DT, Tune, absoluteBlack, Soul-Kozak, Sram X0, POP, ...) allowing the widest spoke bracing angle. Lightweight hubs usually use small and narrow bearings, which are not as strong as larger ones (e.g. DT Swiss used 15/28x7 bearing has almost twice static and dynamic load than Tune 17/26x5 one).
    What is POE?
    Points of Engagement, but I think you were just looking at a front hub, and thus it is irrelevant.
    Slovakia (Europe)
    Yes, looking for front hub only.
    Rear Nineteen ED 32H 142x12, actual weight is 229.9g (claimed by manufacturer technical support), 38-tooths ratchet (POE), 148x12 available in January 2016. However, ratchet wheel and freehub body with "integrated" ratchet are made of aluminium alloy (hard anodized), so I'm not convinced about longevity, although claimed it was tested and proved by professional racing team for one year. Otherwise the rear hub looks interestingly too.
    Illuminati
    Reputation: scant's Avatar
    Quote Originally Posted by PeterG View Post
    Absolute Black also use larger than average size bearings
    I'd have preferred double that. I think Chris King is 72. I switch between that and an American classic with 24.
    On some short sections of singletrack on the american classic hub, I don't even bother pedalling, as I know it will take too long to engage the freehub.
    Chiner 29er SS
    Slovakia (Europe)
    Quote Originally Posted by scant View Post
    Yes, correct, 17/30x7 size (Soul-Kozak as well), but their flange dimensions make only 11.9 deg. of spoke bracing angle in my simulation vs. 14.1 deg. of Acros Nineteen ED (2nd best is Acros .74, 13.4 deg, followed by Tune King, BOR MD7, DT Swiss 240s QR9 DBIS with 13.3 deg., ..., Soul-Kozak 11.7 deg.).
    Slovakia (Europe)
    Quote Originally Posted by xcbarny View Post
    In such case the number of hubs is very limited. I would suggest you Onyx Radical hub with instant engagement system (one way bearing) , unfortunately a bit on heavier side (and CK as well).
    Hmm. I'll just stay with Chris King. I see extralite is 36 also.
    Chiner 29er SS
