Results 1 to 11 of 11
    weight savings? new drivetrain on heavy bike
    hi guys.
    i have a bike that i love, but it's sinfully heavy. i can't afford the ultimate new bike so i'd rather keep this one going and put money into it to make it better. it's an AM 29er that is 32+ depending on tires. i'm having a new wheelset built up and this will have a big impact. i can change tires and will try tubeless and this always has an impact.
    the drivetrain is a combo of SLX shifters and some sub SLX shimano cranks/cogs/chain. i've got new SLX brakes and they are just fine, despite weight.
    i like my LBS's, but dam the internet, with it's great pricing. looks like i can put together a combo XT/XTR or RF Turbine crankset for reasonable money- around $600 or so.
    i know that shifting would improve substantially, what i don't know is if weight will drop much if at all. i have to assume it will, but weight figures on the net are always subject and i don't know the weight of my components.
    any armchair guesses from the guys in the know? am i hoping for at least a pound and a half for that kind of coin, but may be kidding myself.
    thanks for your input.
    You need to post the exact spec. of your bike in order to get good recomendations.
    Chris.
    I ride bikes
    Reputation: moefosho's Avatar
    Apr 2013
    It depends on what model SLX components they are? Or what year and Model of the reign X you have. Then we can get some accurate weights.
    Going to a 1x10 setup is a quick way to drop weight because you eliminate a shifter, a derailleur, and a couple of chain rings. You also get to put a smaller RD on since you are only running 1 front ring. Try doing the rides that you normally ride while only using the middle chainring. Never switch to the big or small ring. If you can pull it off then think about switching.
    Otherwise SLX are all good parts for an AM bike. Normally I just tell my buddies to upgrade when parts wear out.
    If you really want to spend money then I would watch Ebay for full XT or XTR groupsets. You can find good deals on new take offs or slightly used.
    ups and downs
    There wasn't a huge weight difference between XT and SLX, maybe 5-8% on most pieces. For example Shimano XTR M970 triple cranks were 786gms, XT M770 triple cranks were 856gms and the SLX M660 triple cranks were 886gms. That's a pretty typical of weight gap percentage for the current 10 speed components. There's a sizable and pricey gap between the weight of XTR and XT or SLX.
    Quote Originally Posted by cunningstunts View Post
    It's possible you could save a pound and a half but your current stuff would have to be hilarious. I know race face used to make some hilariously heavy cranks for instance. Just take your stuff off your bike and weigh it. It's the best way to find out what you stand to lose.
    It's pretty easy to get pretty accurate weights on things before you buy them. Either go to the LBS and weigh stuff or look it up online. You can usually find pictures of parts on scales. Recently places like bikeradar and bikerumor have taken to actually weighing things themselves and posting it.
    I don't agree that going from SLX to XTR is going to make shifting better. I went from XT to XTR, my friend has SLX. Does XTR shift better than XT? Maybe but I wouldn't say its a big enough difference to really matter. Does 2x10 shift better than 3x10? I think so, I think it's a lot better in the front but I think the rear shifts pretty much the same. Multirelease on the downshift? I lived without it for a long time...if it poofed off my bike I would get over it pretty quick. I'm often suffering too much to care. Damn the front shifts way better than my 3x10 xt or my friend's 3x10 xtr (which I have over 100 miles on).
    That race face crankset is what, 80g heavier than XTR? Why? Don't make the mistake of thinking you need something burlier than you actually do. Maybe you need it maybe you don't, maybe it's heavier and weaker too. Who knows? Don't assume that just because it's heavier it's stronger.
    Excel is your friend.
    ups and downs
    In your profile it mentions you have a Reign X Coil, is that a coil rear shock and a coil fork? If so there's an extra 2 pounds over air fork and shock, on a frame that is likely about 7.5-8.0 pounds.
    the bike in question is a 2011 norco shinobi. in it's first year it was a stand alone offering, with basic build. the following year it was so well received they made shinobi's 1-3 with 1 being a pretty sweet bike for around 5500, with fox 34 fork. mine is much like the 2 version. it would seem like the rf turbine crankset is fairly light, xtr chain and xt rear cogset. this is the last frontier on my bike, the lev seat post sure ain't going anywhere, nor is the stem and bar set up. this is the exact bike other than my cockpit changes. the new rims will be the light bicycle to a hope front and hadley rear hub. run tubeless eventually.
    Norco Shinobi 29'er - Tested - Pinkbike
    I ride bikes
    Apr 2013
    Looking at that spec sheet, the place where obvious weight can be lost is the wheelset, tires, crankset, handlebar, stem, and possibly saddle.
    Other than that it wont be very beneficial.
    Like I said before, you can easily drop a pound by going 1x10 and that wont cost anything. You can also look into getting a lightweight crankset (possibly carbon) or XTR.
    Why do you want to keep the current cockpit? Usually you can drop quite a bit of weight by replacing OEM parts from Norco like the bars, stem and even grips.
    only because i already have. my bars/stem, post and saddle are all aftermarket selected for fit and comfort. also, living in BC i have a lot of steep climbs, often long and steep, 1x works for only the strongest and lightest guys around here. my knees wouldn't fare well winching my 29er around these mountains...
    I ride bikes
    Apr 2013
    I see...
    Most of your drivetrain parts wont give you much weight savings if you upgrade. Your crankset is low end though.
    You could go with a crankset upgrade go to 2x10
    Shimano XTR M985 10SPD Double Crankset > Components > Drivetrain > Cranksets | Jenson USA Online Bike Shop
    Your current crankset and bottom bracket weigh approx 990g
    This XTR crankset and BB is about 700g. thats 2/3 of a lb right there. All you would need to do is adjust the FD. Or you could buy a new one of those as well.
    That, wheels and tires. can drop you a decent amount.
    Hope this helps man!
    it does, many thanks. yes i was coming to the same conclusion, it's going to be mostly in the crankset and then i would have to go XTR or some carbon stuff like RF Sixc to really make a diff. all the rest of the bits would maybe be a half pound in total. i guess the saying 1000/pound is about right eh?
  1. XX1 weight savings versus XT
    By trenchDiggr in forum Ibis
    Last Post: 03-12-2013, 03:04 PM
  2. 29er weight savings
    By coling in forum Wheels and Tires
    Last Post: 01-11-2013, 07:55 AM
  3. Weight savings and Terrain
    By bank5 in forum Weight Weenies
    Last Post: 01-24-2012, 02:38 PM
  4. Ti spring weight savings?
    By macming in forum Shocks and Suspension
    Last Post: 11-05-2011, 06:44 PM
  5. Weight Savings
    By Singlespeed McGee in forum Wheels and Tires
    Last Post: 01-22-2011, 09:15 AM
