Results 1 to 30 of 30
    Weighed: S Works crank arms (175mm) with Wolf Tooth 32T direct mount ring
    As luck would have it my phone won't send the pic of the scale (please, no neg rep, blame it on Samsung); my friend's 175mm S Works crank arm with 32T WolfTooth direct mount is a total of 407g. Just the arms/shaft/ring, no bolt.
    Comparison: the RaceFace Next SL 1x 175mm crank arms with 30T RaceFace direct mount is 430 grams.
    Ole
    Ole is offline
    How does that add up The Wolf Tooth ring weighs 71g in 32t, and the S-Works arms are around 370g with lockring. ??
    Flipping through jotted down notes....
    S Works arms were 337 grams left + right arm
    WT 32 ring = 70g
    total: 407g
    See the notation of bolt: 24g added is 431 grams.
    The RF SL1x is anywhere from 430g to the RF posted pic of the arms, 32T RF ring attached and the adjusting preload collar thingy (word of the day) at 445 grams: Raceface Next SL 1x crankset
    Not that WW takes cost into consideration all the time, but the SWorks were $225 including bottom bracket (local dealer Black Friday blowout) and the 32T ring retails for $79 but he got it for $53 on sale. Total $278 out the door. But MSRP is $300 plus $79 for $379.
    Next SL 1x doesn't come with BB and is $372 at bikeman.com for the arms and about $55 for the ring = $427. A bb is about $45?
    Ole
    Ole is offline
    Thanks for pointing out the bolt. I didn't see that. Good price for the crankset!
    Just weighed my 175mm S Works crankset (the current version) with ring and bb.
    Two arms 185 + 155 = 340g
    Lock ring + parts to attach chainring and join crank arm bb spindle: 36g
    Wolf Tooth 1x 32T direct mount ring: 70g
    BB cups, bearings, 73mm setup and wavy washer minus center sleeve: 74g
    Crankarms, 32T ring and all necessary parts: 446grams
    RaceFace Next SL 1x and XTR 985 1x setup weights here: Raceface Next SL 1x crankset
    Grand total for a 175mm S Works crankset with 32T ring and Specialized 73mm BB: 520g
    Anyone know where to find a Ti bolt for the S-Works crankset? That's a big chunk of steel!
    What big chunk of steel?
    I like turtles
    Reputation: TiGeo's Avatar
    I just picked up and installed a S-Works 170mm crankset w/32t Wolf Tooth direct-mount ring. The crank, ring, and complete BB weighed in at 552g (unfortunately this has some +/- to it b/c they didn't have a scale at the LBS and I calc'd this based on the before and after bike weight....the before was completely detailed [clean] and the after was a bit dirty). Assuming the ring is 71g as the WT site states, that puts the crank+BB at 481g. I used the sleeve which, along with the dirt, if you take them out, probably gets me close to the weight westin is showing.
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro are #@$%
    The "big chunk of steel" is the bolt that connects the two spindle halves. I forget the actual weight but that bolt is significant. If I remember right it is nearly an ounce. A Ti bolt would actually matter in that application, but I haven't found one.
    Dec 2008
    Quote Originally Posted by kroe View Post
    This bolt in Ti would be a good seller, would likely take the weight of the 175mm arms to 350 grams as I seem to remember it weighing 24 grams.
    Attached Thumbnails Attached Thumbnails Weighed: S Works crank arms (175mm) with Wolf Tooth 32T direct mount ring-img_0583_1.jpg
    I have mine from here.
    FTC Titanschraube M12x1 für S-Works Kurbel, 9,90 €
    Bye
    Marcus
    Dec 2008
    Quote Originally Posted by epicbiker View Post
    Nice find Marcus. Does this use the same Specialized tool for installation = Torx head?
    No, it does not use a Torx head. But you can use the Specialized tool. For me it works fine.
    Bye
    Marcus
    Dec 2008
    Thanks.
    Maybe I'm still hungover from NYE, but the total weight savings of the ti bolt vs the stock "big chunk of steel" is about 15 grams?
    Feb 2010
    5.45g. Not a huge difference.
    I like turtles
    Wow 5 grams....
    Sent from my SCH-I545 using Tapatalk
    That Ti bolt could be lighter... even at 5 grams it's more savings than most Ti bolts will deliver.
    Price is high for that bolt though, anyone find a cheaper alternative?
    Dec 2008
    Bye
    Marcus
    Something is strange here. Ti is approx. 50% of steel weight. I checked the weight of my 2011/2012 MTB version Hirth bolt = 20.2 grams. Weights will vary, but not that much on one short bolt. This puts the weight of the Ti bolt about where it should be.
    Marcus, in your scale pics the steel bolt looks much shorter than the Ti bolt. Is the steel bolt maybe from an older Road version of the S-Works cranks?
    Attached Thumbnails Attached Thumbnails Weighed: S Works crank arms (175mm) with Wolf Tooth 32T direct mount ring-img_6465.jpg
    Quote Originally Posted by xc71 View Post
    I don´t know. That is the bolt that came with the cranks.
    Bye
    Marcus
    I like turtles
    ^^^I think you are correct that that is the road bolt - mine was longer than that like the Ti bolt pictured.
    Anyone have the length of the steel bolt handy? The J&L one available on ebay looks too short (but it is M12x1).
    Dec 2008
    Its 23 mm not including the head of the bolt. Do you have a link. The only J&L M12 Ti bolts I found are 15mm, but it doesn't list the thread pitch.
    Reputation: andrepsz's Avatar
    Jan 2013
    So...I have the same crank. How can I remove the bolt??? by taking off the end cap? doesn't look like I can.
    Jan 2013
    Got it ! Don't need to answer... Reading instructions sometimes helps!
    Do we have any Hirth extensions available yet? I've bought some cranks (not yet received) so I'm not sure if they're road or MTB version, but I need an extension to fit them in an MTB 73mm BB application.
    Jan 2013
    Quote Originally Posted by BlownCivic View Post
    Mattias from Experimental Prototype can make it. I need one myself (5mm) and I already talked to him but just for one person will be expensive. He recommended me to find more people interested and lower to cost. I know about a guy in Germany, so that makes two, plus you?
    Your are talking about this correct?
    http://www2.picturepush.com/photo/a/...40/8032390.jpg
    Apr 2005
    Quote Originally Posted by andrepsz View Post
    there's another thread about these already, but it seems to have stalled.
    if you're going to get them made i would take a 5mm, but also need a 5mm longer bolt made too. what's the price to have these made?
    Jan 2013
    if you're going to get them made i would take a 5mm, but also need a 5mm longer bolt made too. what's the price to have these made?[/QUOTE]
    I'll ask him for 3 people or more and I'll let you know.
    I am so mad that is M12 and not M10....because PROTI has a M10x29mm 1mm pitch hollow 9.3g and would be perfect!!!.....but is not M10..
  1. Wolf tooth chain ring users!
    By nndo in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-27-2015, 06:48 PM
  2. 1x S works Wolf Tooth Components chainring
    By WolfTooth in forum Specialized
    Last Post: 04-02-2014, 11:04 AM
  3. Anyone ride a Wolf Tooth chain ring?
    By Ebig in forum 29er Components
    Last Post: 09-09-2013, 10:25 AM
  4. Homebrewed ring direct mount on xo crank?
    By yeti-j in forum Singlespeed
    Last Post: 06-05-2011, 03:19 PM
  5. Replies: 78
    Last Post: 01-29-2011, 02:24 PM
