Results 1 to 14 of 14
    Dec 2004
    Two kinds of micro front AC hubs?
    I purchased six AC front hubs. I weighed all of them and noticed three of them were significantly heavier (65.6, 65.6 and 65.8g) than three others (57.1, 57.1 and 57.2g). The heavier ones have also "Braxxo Classic" logo instead of "American Classic". Besides the weight difference Braxxo hub has a little bit different axle end (see pics) than American Classic.
    So guys please help me. What is "Braxxo Classic"? The separtate manufacturer from AC?? Or just a new name used by AC??
    thanx in advice
    doktoree
    6x7=Dont Panic!
    Reputation: TheRedMantra's Avatar
    My guess is they are knock-offs. Ive seen fake Chris King, Thomson, and a few other high end companies coming out of Taiwan and other places.
    Herro prease
    Max
    Max is offline
    Velodramatic
    Reputation: Max's Avatar
    braxxo is the german AMC importer. never mind, these are quality hubs. the lighter ones are the '05 models, while the braxxo hubs are the '04 models.
    i believe the main difference beside the weight is that the newer ones are sealed differently or so...
    Skinny guys fight 'til they're burger
    MaLˇîó*size=
    Reputation: MaLoL's Avatar
    good post!!
    do the heavier ones come with a built in greaser?
    Max
    Max is offline
    Velodramatic
    no, they dont have any grease ports. they got normal industrial bearings, the axle ends are plugged-in
    Max
    Max is offline
    Velodramatic
    nm,
    Max
    Reputation: nino's Avatar
    Quote Originally Posted by Max
    if i'm not completely wrong older Amclassic series hubs had the grease port. at least i have a 68g Micro WITH and one withou grease port.
    the newer 2005 model weighs 58g
    Max
    Max is offline
    Velodramatic
    i believe there were even older models that DID have grease ports indeed. or were those available as upgrades?
    Max
    Max is offline
    Velodramatic
    ok, it seems to prove what i suspected:
    http://www.amclassic.com/Technical.html
    there are tutorials how to change the grease port hubs to fully sealed ind. bearings and vice versa
    WAWE
    Quote Originally Posted by TheRedMantra
    More info, please?
    Dec 2004
    thanx
    now everything is clear
    I have the old one (65g) with normal sealed cartridge bearings and plugged-in axle ends...it's great! I see the slight difference in the above pics but is the '05 model basically the same design?
    Is the '05 model less stiff or less reliable? If not, I wonder how they would save the extra grams.
    Max
    Max is offline
    Velodramatic
    havent had the chance to try the new ones due to an injury, but i doubt there are big differences in the feel. i suppose the weight savings come from the different axle-ends that seems to have undergone some machining. also, what might be more important, the new ends are bolted into the THREADED axle. ergo they are stiffer?
    2005 has ends that screw in with a hex key rather than press in. Keeps from having too much side load on the bearings from overly tight skewers and the ends can't get crooked as easily. 2005 also uses 688 bearings instead of R4 size. And of course they are 10g lighter.
  1. real front disc hubs - any good?
    By Tourendo in forum Wheels and Tires
    Last Post: 12-21-2004, 03:50 AM
  2. AC front derailleur
    By twouareks in forum Giant
    Last Post: 11-14-2004, 03:52 PM
  3. wheelbuilding gurus: spoke tension on front disc hubs
    By minh in forum Wheels and Tires
    Last Post: 07-15-2004, 03:56 PM
  4. LX or XT front Disc hubs???
    By CaptainKodak in forum Where are the Best Deals?
    Last Post: 07-07-2004, 11:45 AM
  5. American Classic Micro front roadhub for MTB ?
    By Danne in forum Weight Weenies
    Last Post: 05-13-2004, 12:38 PM
