Results 1 to 6 of 6
    May 2012
    Trying to build a light-ish 29er race hardtail
    Im building a 29er from the frame up and I'm sure that you guys (and gals) have some awesome weight saving ideas that I am unaware of. My budget right now is at 2000 bucks. so far the things I plan on getting:
    Frame Sette Razzo 29 $220.00 Link 1587
    Wheelset Easton EA70 $460.00 Link 1990
    Fork RockShox 29er XC32 $216.00 Link 2200
    Break (front) Avid Elixir CR Carbon X9 $150.00 Link 331
    Break (Rear) Avid Elixir CR Carbon X9 $150.00 Link 331
    Crankset Sram X9 2x10 $277.00 Link 881
    Front Derailleur Sram X9 $50.00 Link 142
    Shifter Sram X.9 Trigger $100.00 Link 262
    Rear Derailleur Sram X.9 10 $90.00 Link 204
    Cassette Sram PG 1070 $85.00 Link 290
    Chain Sram PC 1051 $35.00 Link 271
    Seat Sette Rez $35.00 Link 226
    Seatpost Sette Edge Carbon $40.00 Link 261
    Tires Kenda Tomac Small Block Eight $72.00 1080
    Total $1,980.00 10056grams (22.2 pounds)
    I'm aware that I still don't have handlebars, stem, tubes, anything small. I have that stuff at home already, Since Im already at my 2000 dollar limit if a more expensive part is suggested ill have to compromise somewhere else. Open to anything! thanks in advance!
    May 2012
    How about the Sette Razzo X7 Carbon - $1600 right now, 24.5 lbs. Leaves you with an extra $400 to swap wheels, cassette, etc.
    DFMBA.org
    Reputation: MTBeing's Avatar
    Quote Originally Posted by axiszen View Post
    I agree with this poster. With the extra $400 you could upgrade some bits to make it even lighter, like a 2x10 drivetrain. The Recon Gold fork on this bike will be much better (and lighter) than the XC 32 you spec'd as well.
    Please donate to IMBA or your local IMBA chapter. It's trail karma.
    the tires and wheelset are the most important item on a 29er. no tubes crest at 550$ is worth the extra $$$. you could skimpy somewhere else. They say 1 pound of rotating mass equals
    3 pounds of frame weight.
    May 2012
    for the time being I wanted to keep away from carbon, I don't think I'm ready for that leap yet, sorry, something I should of mentioned. I am thinking of a Niner EMD frame instead of the razzo, I know it is a little heavier but from what I have heard the ride quality is worth it
    Feb 2010
    You'll save some weight and about $100 by going with Hygia SLP brakes. Elixer CRs can be good brakes, but the Hygia SLPs are better - superior modulation and just as powerful. They are also really simple and easy to work on.
    Build yourself a wheelset with some dt rev spokes, circus monkey or novatec 711/712 hubs and crest rims - cost around $400 and weight around 1550g. Alternatively, look at some of the handbuilt wheelsets from the euros - eg 1495g Novatec / FRM. Remember you don't pay the 19% VAT if outside the EU.
    As others have said, the XC32 is heavy and crap. Save some more money for a better fork or look for something second hand. Fox RL, Rockshox Reba, Rockshox SID will be good choices and can be had for around $300 second hand.
