    Reputation: carlos's Avatar
    Token Scandium ISIS Bottom Bracket 150grms
    hey guys, check out this sandium isis bb...
    CNC machined hollow Scandium spindle
    Alloy body, Alloy cold forged cups
    4 High Rolling sealed bearings
    113mm ISIS Drive for Triple cranksets, 68xBSA1.37"x24T, R/L cups
    Chainline: 48mm
    Weight: 150g w/o bolts
    Includes M12 7075 Alloy X-Long crank bolts
    U$95.
    hey
    ho
    lets go!
    MaLóŒ˘*size=
    Reputation: MaLoL's Avatar
    i want one of those spada bb.
    Where did you find it at 95$? Are you gonna buy one?
    any web for more info?
    thanks
    Quote Originally Posted by MaLóL
    thanks
    The Spada BB is available from Spada-USA@earthlink.net
    I tried a Token BB, they were cr@p. The Spada BB was much better - bearing quality, axle is thicker walled (14mm bolts instead of 15mm) and replaceable bearings.
    Recovering couch patato
    Reputation: Cloxxki's Avatar
    I think Easton patented the use of scandium in aluminum alloys, and as a trade name. If they pay easton for either the name or the alloy, hey can legally call it Scandium. Would 100% Scandium, apart from priceless, also be better?
    Using Scandium for the spindle at least makes sense over plain alu, especially if they use the same amount of material as oreviously put in alu spindles, it should add strength.
    Quote Originally Posted by MTBikeBoi
    They should change the name from scandium to scamdium, as the spindle is not made of scandium, it is made of aluminum that has been alloyed with a small percentage of the element scandium.
    Calling the spindle scandium is like calling alumunum silicon, calling it magnesium, or calling it by any other one of it's minority alloying elements.
    Klok - XC - Skate - Ski
  1. ISIS and E-Type bottom bracket question...
    By Hardtail in Georgia in forum General Discussion
    Last Post: 08-07-2004, 12:26 PM
  2. ISIS and E-Type bottom bracket question...
    By Hardtail in Georgia in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-07-2004, 11:46 AM
  3. @#$%^&* Shimano bottom bracket mounted derailler
    By old_dude in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-02-2004, 10:04 AM
  4. Token ISIS bottom brackets [o]
    By positron in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-24-2004, 04:04 AM
  5. ISIS bottom bracket: Is there one that lasts more than 6 months?
    By FuelForThought in forum Weight Weenies
    Last Post: 04-16-2004, 05:26 PM
