Results 1 to 10 of 10
    Reputation: Tiffster's Avatar
    Titec Pork Rinds Width ?
    Can anyone tell me how wide these are ?
    And a weight without end caps ?
    My ESI Silicons are 40g cut the Titec ones should be about 15 grams i think ?
    More carbon fiber please!
    4 5/8" long. I weighed mine but can't find the note. You're probably on track with the 15g guesstimate.
    Hi
    Thanks mate.
    Can you tell me the width of them in reference to my pic ? The width of the centre bit bascially.
    Will check later and let you know...
    cmh
    cmh is offline
    Sorta related question -- I've got a set of Ritchey WCS foam grips. Little under 32g, but got them cheap. Thing is- I installed them, went on kinda easy. The next day, seemed that the grips had relaxed and they were spinning without much effort on the EC90 bars. Iz bad thing.
    So, with the foam grips, do we have to go back to the old "hairspray" methods for installing grips? I guess I've gotten spoiled with bolt on grips and grips that only need a little water and an overnight dry to install. (like the ESIs)
    Kool thanks.
    Your first measurement - that's 12cm yeah ?
    Quote Originally Posted by Tiffster
    Kool thanks.
    Yes, just barely under 12cm (11.76 if my calculator is right, lol)
    Damn!
    I was hoping i could cut the ends off as they look a bit goofy and use just the centre bit.
    Got a pic of them on your bike ?
    Damn!
    The raised area is close to 9cm long.
