    Are thru axle hubs heavier, generally speaking?
    ups and downs
    Not usually, the 15mm axles aren't included in the weight, for example.
    DT 240S 9mm CL hub 130gms
    DT 240S 15mm TA CL hub 126gms.
    20mm TA hubs are heavier
    bike rider
    Reputation: Lelandjt's Avatar
    It gets complicated. You have to compare the weight of:
    Hub, skewer, and fork
    Hub, thru-axle, and fork
    If the 9mm setup uses a Ti bolt-on skewer it's gonna be lighter. With a steel QR skewer it's gonna be close, but that depends on the fork. This is a pointless exercise anyway cuz QR15 works better and is stiffer. It's worth the extra 10-50g.
    Keep the Country country.
    Doesntplaywellwithmorons!
    Reputation: DeeEight's Avatar
    Generally speaking, yes, because the bearings are larger as are the hub shells to hold those bearings, and support the larger thru-axle. Unless you're buying high end hubs (like Hope or DT or Chris King) then chances are you're into the 200g range for a hub to fit a 20mm thru-axle. A 9mm axle QR hub for a similar price level will be a couple ounces lighter.
    I don't post to generate business for myself or make like I'm better than sliced bread
  1. Hubs: XX1 + centerlock + thru axle ?
    By Motivated in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-10-2013, 11:11 AM
  2. How popular generally is XC racing in the US?
    By whathaveisaidnow in forum Endurance XC Racing
    Last Post: 05-30-2013, 09:42 AM
  3. Replies: 2
    Last Post: 01-29-2013, 07:22 AM
  4. Heavier Tires that noticeable for heavier riders?
    By offroadcmpr in forum 29er Components
    Last Post: 06-16-2012, 07:38 PM
  5. 9mm thru axle with ZTR Hubs?
    By SnowStorm in forum Shocks and Suspension
    Last Post: 04-20-2011, 10:31 AM
