Results 1 to 5 of 5
    I like turtles
    Reputation: TiGeo's Avatar
    Take a look at my setup and make recommendations
    My current set-up is as follows:
    2012 15.5" Specialized Stumpjumper EVO 29 HT
    Fork: Fox Float RL Evolution 80mm 1.125" non-tapered
    Brakes/levers: Avid Elixir 7 SLs
    Rotors: 180 f/160 r Alligator Serration rotors
    Pads: Kool-Stop steel-backed organic
    Shifter: Sram X7
    F. der: E.thirteen XCX chainguide
    R. der: Sram X0 short cage
    Tubes: Tubeless w/Roval tape, Roval valves, 2 oz BAMFS/tire
    F. tire: Specialized S-Works Purgatory 29x2.2
    R. tire: Specialized Ground Control 29x2.1
    Seatpost: Niner RDO carbon 27.2x400mm
    Seatpost collar: Specialized
    Seat: Specialized BG Phenom Comp
    BB: SRAM PF30
    Crank: SRAM S1250 33t 170mm
    Pedals: Shimano M520
    Chain: KMC X-10
    Handleba:r Specialized XC Mini-Riser 31.8x720mm
    Grips :Specialized Grappler
    Stem:Specialized XC 75mm 31.8
    Headset: FSA integrated w/carbon spacers
    Cassette: SRAM PG-1030 (X5) 11-36 10-spd
    Wheels: Roval Control 29
    Bottle cage: Specialized Rib Cage
    Computer: Garmin Edge
    Bike weight is 23.9 with winter tires (including a bottle cage, Garmin mount, and Shimano 520s) and 23.3 with summer tires. Its respectable and durable. I am thinking of trying to get it down into the 22 range. Some items I am considering:
    Trimming down the excess seatpost its a 400mm and I dont need it that long (should be able to loose 50mm of it and maintain the min. 100mm insertion length)
    S-Works Prowess carbon bar (already ordered)
    Syntace 75mm F109 stem (not sure how much this weighs less than the stock one will weigh when I replace the bar)
    SRAM XG-1080 cassette
    KMC X10SL chain
    Shimano XTR (980) pedals
    S-Works carbon crank
    Things I am not ditching for weight savings:
    Grips not doing the foam grip thing
    Narrower bar I love my 720
    Eggbeaters tried them and just dont love them (even though I want to for the weight savings!)
    I know I can replace the seat, but Im not.
    Change cassette gear ratios - I have a 1x10 so a 11-36 is 100% necessary to get some range.
    At some point, I may go to a carbon frame like the S-Works or Niner Air 9 RDO. I may also consider going full-suspension like an Epic. This would be in a few years.
    Thoughts?
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro are #@$%
    Feb 2012
    Alternates:
    Ward TI spindles - rated up to 220lb
    - cheaper to put in M540 pedals and resulting weight similar to M980 w/same ti spindle for less cost.
    the 1070 cassette is way more bang for your buck, paid only $52 for mine shipped
    E-13 XCX+ crank at 575g. I find no reason to be concerned on this one - love mine, still overbuilt.
    I like turtles
    ^^^ is that the actual weight of my SRAM crank w/single chainring?
    On the cassette - the 1070 looks to weigh nearly what my 1030 does??
    Feb 2012
    right, from the 1030 to the 1070 there isn't a huge weight loss,
    The 1080 at $140 more trims about 100g and is still a fairly cost effective way to remove rotational mass.
    I figured your crank was in the 900g range (but I may be wrong), and an ideal weight loss candidate.
    Feb 2012
