Fat On A Bike
SRAM XX Trigger Shifters vs. Grip shifts
Hi.
What is the difference in weight between the Sram XX trigger shifters to the XX Grip shifts?
Ofir
About 290g for the Gripshifts, 190g for the triggers. Thumbies and TT500's get down to 140g (for the true WW).
Fat On A Bike
so taking into account cables and jaws - the grip shifts are lighter?
Ofir
 Originally Posted by bikemaniack
Can't count the grips on the gripshift. No other shifter was weighed with grips. Non of the trigger shifters where weighed with a normal bar clamp either.
My XO triggers weigh 218g with cables and no clamp.
My XO grip shifters weigh 212g with cables and bar clamp is integrated into the shifter.
XO grips weigh 76g, pretty light actually.
Grip shift wins
If the XX grippies weigh the same as the XO's, they would be very close in weight to the XX triggers with a normal bar clamp, probably lighter. I don't have a normal bar clamp, but would bet it weighs more than the matchmaker mount.
I have the clamp to match up to my Hope brakes and they weigh 44g a pair with Ti bolts
I also have a pair of the matchmakers and they weigh 22g a pair
Grip shifters are still lighter, but not as light as the XO 9 speed
P.S the new Grip Shifters are awesome.
Nice. So the bar clamp for the triggers is only 11g, same as the matchmacker. The cables on my XO grip shifters is teflon coated, unlike the Gore cables on the XX grip shifters. I wonder if that is a difference of the 5g?
- You may not post replies
- You may not edit your posts
Forum Rules
