    SRAM shifters/ derail w/ Shimano chain/cassette?
    Hello. I'm using SRAM X.0 shifters and rear derail. w/ Shimano XTR chain and cassette. Shifting is really good, but would it be better if I switched to a SRAM chain and cassette? If so, does the SRAM chain and cassette weigh more or less than the Shimano stuff?
    Thanks,
    Craig T
    Max
    Max is offline
    Velodramatic
    Reputation: Max's Avatar
    shifting is on par i guess, maybe the shimano stuff is even better. expect 10-15 g weight savings when using the PC-99 hollow pin chain by SRAM. given you wanna stick to the 11-32 gearing, the XTR cassette is about 40 g lighter than the lightest SRAM cassette.
    but check out weightweenies.starbike.com for more detailed weights
    Skinny guys fight 'til they're burger
    Reputation: Bullit_cn's Avatar
    Quote Originally Posted by Craig T
    Thanks,
    Craig T
    Shouldn't be a problem...I got mine setup with X.9 trigger shifter and derailleur on a Shimano XT cassette and crank using an XTR chain and I had no problem whatsoever. The shifting is perfectly crisp and precise.
    As a rule of a thumb, it's better to keep your drivetrain in 1 family but for me, as long as your chain, cassette and/or crank are the same family, then you can use whatever derailleur available since the chain will just pass on it...
    I maybe wrong but that's my 2 cents...
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    kinda using the same thing.
    Thanks,
    Craig T
    Im using sram shifters/RD,shimano FD, shimano XTR cassette and a Sram PC 89 chain. Shifting is great but the real reason i went this route was ease of removal and maintenance using the PC-89.
  1. Numbered or lettered SRAM shifters with Shimano RD
    By jrm in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-14-2004, 07:10 AM
  2. SRAM X.9 shifter/ XO R. Der. vs Shimano
    By Manny Omega in forum SRAM
    Last Post: 04-15-2004, 01:39 AM
  3. sram vs shimano shifters
    By yeroc in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-11-2004, 10:42 AM
  4. SRAM shifters: X.0 twist vs X-9 trigger (x-post general)
    By 1speed_Mike in forum Weight Weenies
    Last Post: 01-28-2004, 06:48 AM
