Results 1 to 44 of 44
    Reputation: Limon's Avatar
    Specialized crave build
    Not light but pics with weights
    Attached Thumbnails Attached Thumbnails Specialized crave build-20151118_153118_hdr%5B1%5D.jpg
    Maromero
    Reputation: doccoraje's Avatar
    Quote Originally Posted by Limon View Post
    Cuales fotos mi Lemon?
    sorry doc here you go, crappy cell phone
    dont know what to do have more pics but they dont want to upload
    Attached Thumbnails Attached Thumbnails Specialized crave build-20151120_175323_hdr%5B1%5D.jpg
    blunt ss 29 rims 808g for 2
    X01 cassette 10-42 261g
    X king 2.4 tire 713g
    storm sl 160 94g
    storm sl 180 116g
    Reputation: phlegm's Avatar
    Nice to finally see the pics. Keep us posted as the build progresses.
    Will await stem, bars, seatpost, etc.
    Specialized
    Reputation: Seb K's Avatar
    Did you just call him Lemon ?!!! Dude it's Limon
    same weight front and rear
    8 months later lol
    limon lemon samething haha I think Ill finaly finish this build hopefully
    32 aerolite 288mm spokes same front and rear
    Maromero
    Waiting for the pic of the whole build
    obviously on scale, salu2
    give me a couple days ill build the wheels tomorrow and finish it tuesday
    sorry for all the threads having phone troubles
    Illuminati
    Reputation: scant's Avatar
    firstly thanks for taking the time to weigh & document everything in pictures
    regarding the fox fork, is that weight for the 100mm fork & with a uncut fork steerer?
    Reputation: gks333's Avatar
    Mar 2013
    Quote Originally Posted by scant View Post
    When I received my 2015 pivot mach 4 in november 2015 the bike came with 2016 FOX factory 34MM FIT4 120mm fork. I told them I wanted the 32mm fork for weight saving reasons. They let me take the bike home and mailed me the 32mm 2016 FOX factory 120mm FIT4 fork. I could not believe the weight difference. Weighed with 2 different scales, one a fairly accurate Chinese scale and the other was the park tools scale. 32mm weighed 1770g & 1795g, identical fork but 34mm weighed with same stock thru axle as with 32mm 1805g and 1810g.
    Lets just say that I am rocking the 34mm fork with no regrets.
    The orange decals was the 32mm, blue is 34mm. Just some WW FYI I found shocking.
    2015 Pivot Mach 4. XX1, Guide ultimate, NOX wheels, Next SL, KS LEV integra dropper. 24.56lbs
    Illuminati
    thanks for the info. yes the new 34 fork is pretty light, given how stiff & capable it is. I went from a 36 talas to a 34 float & lost nearly 2/3lb on my long travel bike.
    I was curious to see the actual weight of the outgoing 32 float 29er fork, as I'm waiting for the new 32sc fork (& I forgot to weigh my current fork when I installed it...)
    190mm steerer tube no thru axle
    Illuminati
    cool, thanks!
    no problem scant still going to cut an inch more steerer tube, heaviest wheel I ever had lol
    heavy things that need to go
    stem
    seat
    steel rotor bolts
    front thru axle
    suggestions welcomed
    also need some grips for pedals I think Im going xtr
    I have a lighter wheelset on the works to compare to this one and see for myself about all the wider rim/biger tire thing going on
    I remember when my bikes used to be 17 pounds and under lol Ill be happy if I turn this one 19 pounds
    Mar 2013
    Looking good so far but did you weigh the bike with grips and pedals (ready to ride)? Looks like your brake/shifter lines are about 6" too long unless you do bar spins when jumping or some flat land tricks ;?0 Yes, your wheels are very heavy (are these 29 or 27.5")? I rcvd my NOX skyline 27.5/dtswiss 240 about 3 months ago and they weighed in at 1400g (rim tape, valve stems and valve cap). Loving them. Build list when all is complete please.
    Lol the pic makes them look very long but left them a little longer for future frame swap not planning on keeping frame for to long rims are 29 if I like the wheel set up I'll get some carbon rims and switch them never had rims this wide grips and pedals coming up
    Reputation: RS VR6's Avatar
    To bring that bike down to 19lbs, you'll need to go single speed, rigid carbon fork, and lighter wheels. At over 2000gr, those are some heavy wheels for a "weight weenie" bike.
    Weigh the bike again when it's ready to ride. No cheater weighing.
    Parts list
    frame Specialized Crave 17"
    fork Fox 32 fit4
    headset FSA generic
    Headset profile starnut aluminum bolt aluminum cap
    Headset spacers carbon
    BB RaceFace bsa30
    brakes XTR race
    cassette XO1 9-42
    chain SRAM 11speed
    cranks RaceFace next sl g4
    Der XO1
    grips ESI 30mm
    bar ENVE riser
    qrs steel bolton rear fox thru axle front
    seatclamp generic ti bolt
    seat Aliante carbon
    seatpost ENVE 27.2
    shifter XO1 11speed
    stem Specialized 70mm
    rims Blunt 35
    hubs king
    spokes Aerolites
    tires Racing Ralph 2.35 and X King 2.4
    tubes notubes
    I know 2060g is wrong haha I have to do something about it, Im not going down like that lol I want to keep fork hubs seatpost bar drivetrain brakes and (frame for now)
    Heres what Im thinking racing ralph for the front minus 100g carbon rims and ti spokes minus 300-350g lighter stem another 50 thats about 500g aluminum rotor bolts ti rear skewer fox bolton thru axle lighter seat maybe another 100g so 600g total what else? My weight weenie days are rusty help me out haha
    Illuminati
    front thru axle
    when I looked into Fox compatible 15QR lighter axles, the Fox Kabolt was 1 of the cheaper options. I use 1 on my bigger travel bike & it works fine. I did previously use a Tune carbon 15QR axle, but it was a little temperamental, IE the lever wouldnt always close at the same spot
    Fox kabolt it is and por the rear ti control tech
  1. Specialized Crave 29
    By toni31 in forum 29er Bikes
    Last Post: 03-01-2015, 08:40 PM
  2. 2014 Specialized Crave SL
    By toddx in forum Singlespeed
    Last Post: 11-20-2014, 12:49 PM
  3. Specialized Crave good base for a build?
    By Rushca01 in forum 29er Bikes
    Last Post: 10-02-2014, 09:13 AM
  4. Specialized Crave sl???
    By Sickmak90 in forum Singlespeed
    Last Post: 07-28-2014, 05:02 PM
  5. '14 Specialized Crave Comp 29
    By AE Beej in forum 29er Bikes
    Last Post: 07-13-2014, 06:43 AM
