Results 1 to 7 of 7
    Seatpost for SLR Kit Carbonio Flow
    I recently acquired a Selle Italia SLR Kit Carbonio Flow saddle, and found that I had a great deal of difficulty clamping it into my Airborne Laidback Ti seatpost. With a lot of filing and sanding, I finally got it to fit, but it still loosens after a few miles of riding.
    Does anyone absolutely know of a seatpost that meets these requirements below?
    - Setback design
    - 27.2mm diameter
    - Weighs 192g, or less
    - Firmly and safely holds the Carbonio's rails
    Thanks for your help..................Frank
    thomson masterpiece?
    any min. length requirements?
    gone for a bike ride
    Reputation: culturesponge's Avatar
    there's been a few threads on your saddle regarding suitable seatposts:
    selle italia slr kit carbonio gel flow saddle
    Selle Italia SLR Kit Carbonio Flow Saddle
    i'm using a cut 30.9 Syntace P6 & a shimmed 27.2mm WCS single bolt post with Carbonio Flow saddle's with no probs.
    hope that's of help
    I don't believe that the Thompson Masterpiece is a setback design, but thanks.
    Frank
    Quote Originally Posted by Frank_Zuccarini
    Frank
    Actually they do a few setback sizes in 27.2 dia
    http://www.lhthomson.com/masterpiece_sizes.asp
    27.2 x 330mm
    Not sure if that is enough for you as you didn't specify.
    Thank-you, one and all, for your help.
    I have read the two listed threads (thank-you, culturesponge) and viewed the Thompson listings (thanks, gixer7), and it sure seems like the Thompson Masterpiece will suit my needs just fine. I just need to find out who's selling it.
    My apologies to civil. I went to the Thompson website yesterday and could not find the setback model, even though it obviously exists.
    Again, thanks..............Frank
    Frank
    Yep, I've got one in a 30.9 and a 27.2 setback, work well and relatively cheap. Mine came in at 188g for a 350mm length. If you want to weenie it out more, toronto cycles has a Ti bolt kit for it to drop ~10 to 15g.
    I picked mine up at chain reaction cycles when they were having a sale. They seem to go on sale every once and awhile at various places.
