Results 1 to 6 of 6
    Reputation: cabbgage's Avatar
    Seat post length
    I have a 400mm carbon seat post with only about 120mm above the frame. Is there an agreed amount that should be in the seat tube, so i can cut some off?
    ups and downs
    Most frame manufacturers want at least 100mm of seat post in the seat tube to protect the frame and most seat post manufacturers want about 100mm of seat post in the frame to protect the seat post.
    Cheers, that will save me a few grams.
    Reputation: phlegm's Avatar
    Before you cut, just double-check to see if you can find the actual specs for both the frame and post.
    Reputation: RS VR6's Avatar
    The rule of thumb I "heard" is that as long as the post extends past the top tube...entire top tube...you should be ok.
    Dec 2008
    Some bike Manufactures use a formula for calculating seatpost insertion. Ibis for example uses seatpost size 31.6mm X 2.50 = 79mm insertion. This formula doesn't really work for smaller seatpost sizes, but for the larger ones seems to work. I have run 79mm on a couple of Ibis frames for years with no issues.
  1. seat post saddle clamp length
    By Gabe3 in forum General Discussion
    Last Post: 12-28-2014, 07:40 PM
  2. Ibis mojo HD seat post length
    By eshew in forum Ibis
    Last Post: 12-25-2014, 02:23 PM
  3. seat post length?
    By outlaw in forum Turner
    Last Post: 02-21-2012, 10:31 AM
  4. which adj. seat post length for hd
    By cavo in forum Ibis
    Last Post: 07-03-2011, 03:39 PM
  5. Giant Trance X3 seat post length
    By gene22 in forum Giant
    Last Post: 06-28-2011, 02:59 PM
