Results 1 to 2 of 2
    Reputation: mf9point8's Avatar
    saving weight with ti bolts
    where are the most effective places to save weight with ti bolts?
    Reputation: Ultra Magnus's Avatar
    Everywhere... At least with a mix of ti and alum. Each bolt you change out is only going ot save a couple of grams, just a drop in the bucket. But collectively, you can make a good difference. Usually you can use ti for stem, seat bidner, brakes, etc, and alum for bottle cage bolts, brake lever clamps, shifter clamps, deraileur clamps, etc.. Stuff that's not so highly loaded, and won't kill you if it comes loose.
    "I've come to believe that common sense is not that common" - Matt Timmerman
  1. ? Are Ti bolts for stem endcap and steerer a good idea?
    By LocoMotoMan in forum Weight Weenies
    Last Post: 11-04-2004, 03:01 PM
  2. Weight difference between Steel and Ti bolts on Pazzaz stem
    By DaFireMedic in forum Weight Weenies
    Last Post: 08-30-2004, 06:11 PM
  3. Price of Ti and Al at Redmist and SRP and bolts heads?
    By swalters in forum Weight Weenies
    Last Post: 07-21-2004, 02:22 PM
  4. The Official Weight Weenies F.A.Q
    By Trevor! in forum Weight Weenies
    Last Post: 02-25-2004, 01:31 PM
