    Jun 2013
    S-Works Cranks on Ibis HDR 650b?
    I saw a thread awhile back that talked about installing the S-Works carbon cranks on an Ibis SL with a Lightning spider and Hive cups. I was wondering if the same could be done on the Ibis HDR 650b BUT with the SRAM XX1 rear cassette and shifters. The bottom bracket on the HDR is 68mm BSA (English threaded). Anyone know if this is possible and what I would need to order?
    Feb 2010
    If its a 68mm BSA BB then you're all good. I use the s-works cranks on my 68mm BSA Anthem X along with E13 bottom bracket cups. For XX1 you'll need to order the speci s-works XX1 spider as well.
    If it is exactly the same as the HD it will work. My brother & I both have 2012 HDs & we are running S-Works cranks. We use the Hive (e13) bottom bracket, Lightning 104BCD adapter & Wolftooth chain ring with no chain devices. Works incredible & possible one of the lightest setup you can buy for a reasonable price.
    Jun 2013
    Thanks guys!!!
  1. Running S-works Cranks on ss?
    By ardmoregeorge in forum Singlespeed
    Last Post: 01-02-2013, 04:28 PM
  2. S-Works cranks, how good ?
    By thirdnipple in forum Specialized
    Last Post: 03-23-2012, 04:39 PM
  3. Soecialized S-Works Cranks ?s
    By barrows in forum Weight Weenies
    Last Post: 10-07-2011, 09:16 AM
  4. Replies: 3
    Last Post: 08-19-2011, 08:52 AM
  5. S works cranks - where to buy?
    By singletracknick in forum Specialized
    Last Post: 06-19-2011, 07:28 PM
