Results 1 to 11 of 11
    Apr 2016
    Removing Hardened Sealant from tires
    Hey folks, anyone have a good method to remove excess dried sealant from tires to keep the weight down ?
    Specialized
    Reputation: Seb K's Avatar
    Glue remover and a scrubber...lots of patience .
    Reputation: sfer1's Avatar
    Removing Hardened Sealant from tires-how-clean-earrings-rubbing-alcohol2.jpg
    RAKC
    Reputation: tigris99's Avatar
    A brush like above and water.
    You remove it, you open up the leaks again. And your back at it all over again. Total waste of precious riding time IMO unless it's really thick and can be peeled out easily by hand.
    Sent from my XT1565 using Tapatalk
    Reputation: phlegm's Avatar
    Quote Originally Posted by sfer1 View Post
    Actually, blue brushes work better on dried tire gunk than purple.
    > /dev/null 2&>1
    Reputation: Procter's Avatar
    Feb 2012
    Dried sealant is virtually weightless. Let an ounce dry and weigh it, it's like 3 grams. And Tigris is right, it's sealing the porosity in your sidewalls.
    Reputation: nunokas's Avatar
    Aug 2014
    Hi.
    I just remove it when i have to patch the tire from the inside and only in the area needed for the patch. To remove it faster try a disc cleaner (i use finish line) with the blue brush that phlegm recommended
    Anytime. Anywhere.
    Reputation: Travis Bickle's Avatar
    My tires usually wear out before the sealant dries but the one time it did I just picked out the chunks and left the rest. The tire has already lost more weight from wear than the dried sealant adds.
    I got some bad ideas in my head.
    Mr. Buck E. Fikes
    Reputation: Oh My Sack!'s Avatar
    Just thought I'd mention, the newer Slime tubeless sealant is soapy water soluble. It's really nice if you're redoing a tape job or really just anytime you might need to dismount a tire from the rim. A brush, some Dawn soap in a bucket of water, and a couple minutes of quick scrubbing, and it's completely gone. Stuff works well for sealing, too.
    Quote Originally Posted by Oh My Sack! View Post
    If you're talking about the Slime Pro Sealant, it works better than the crappy regular one, but it's still mediocre compared to Orange Seal or Stan's.
    Mr. Buck E. Fikes
    Stan's doesn't even compare. It shouldn't even be mentioned in comparison to Orangeseal. I've been beta testing the new Slime for a year now. I think it is a revision of Pro, not sure how they are putting it on the market. I halted use of Orangeseal just to do this trial as the opportunity came up. Not because Orangeseal is crappy, it's not, but the new Slime has more favorable properties, IMO and one of those is ease of clean up.
  1. Removing dried sealant...?
    By OldschoolReloaded in forum Fat bikes
    Last Post: 07-30-2015, 11:42 PM
  2. Replies: 12
    Last Post: 11-15-2013, 12:24 PM
  3. Removing Stan's sealant inside rim..
    By db9 in forum Wheels and Tires
    Last Post: 01-10-2013, 06:20 AM
  4. Removing Tire old sealant?
    By murd in forum Wheels and Tires
    Last Post: 11-09-2011, 03:27 PM
  5. Anyway to fix hardened tires?
    By chikai in forum Wheels and Tires
    Last Post: 05-08-2011, 02:53 PM
Members who have read this thread: 7
