Results 1 to 2 of 2
    rear wheel strength: 32h cassette hub vs 28h SS hub
    It is my understanding that a dished wheel built around a cassette hub will not be as strong as a symmetrical wheel built around a SS specific hub. I am assuming identical rims, spokes, and spoke count. So, given identical rims and spokes, would a wheel built around a 28h symmetrical SS hub be stronger, weaker, or the same strength as a wheel built around a 32h cassette hub?
    If the 28h SS build is the same strength or stronger then I would save ~28g and a whole $5 by going with fewer spokes.
    Would love to hear from any experienced wheel builders out there.
    Rock and/or Roll
    Reputation: turbogrover's Avatar
    Dec 2005
    It won't be stronger than a 32 spoke dished wheel. It'll be a tiny bit stronger than a 28 spoke dished wheel.
    The biggest strength difference will come from the rim itself. New lightweight carbon rims are so much stronger and stiffer than lightweight alloy rims, you can use fewer spokes and still retain some decent wheel strength.
  1. 150/12mm rear wheel, cassette compability and axle?
    By haymitch in forum Wheels and Tires
    Last Post: 08-16-2012, 09:14 AM
  2. Wheel strength question - can you make up stiffness with hub?
    By jayoutside in forum 29er Components
    Last Post: 05-22-2012, 01:37 PM
  3. Possible Rear Wheel Problem? Cassette Moving.
    By jonshonda in forum Beginner's Corner
    Last Post: 04-28-2011, 11:40 AM
  4. wheel strength: function of rims or spokes?
    By benoksanen in forum Wheels and Tires
    Last Post: 02-07-2011, 09:31 AM
  5. Rear hub width = wheel strength?
    By bubba13 in forum 29er Bikes
    Last Post: 02-05-2011, 12:52 PM
