Results 1 to 3 of 3
    Reputation: 2times's Avatar
    Race Face Next LP - a little help needed
    I just picked up a set of Next LP arms and they were advertised as 74/110, I have also noticed that there are 58/94 Next LP arms as well. What is the difference? Is one an older configuration maybe an 8 speed model? What is a brief history on these cranks?
    Is there any weight difference between the two?
    Thank you for the help as I am trying to do a ww crankset with these arms.
    ups and downs
    They all date back to the same time, but they were both in the market at the same time, the bigger spider will use bigger rings and will weigh slightly more. The 74/110 BCD is the standard bolt circle and the 58/94 BCD is a compact bolt circle.
    +1
    They were brought to the market at a time when XTR was a 46/34/24, but XT and a few others were 44/32/22. You had the option of the larger spider which was the 46T large ring, or the smaller.
    Not sure what rings the smaller ran, but I'm sure other on the forum will
