Page 9 of 22 FirstFirst ... 567891011121319 ... LastLast
Results 801 to 900 of 2187
  1. #801
    May 2010
    LOL yeah the extra rings help when on road for sure.
    I'm horrible at weighing my stuff because when it arrives in the mail I immediately install and forget to weigh everything. Good thing you weighed it I know Its supposed to weigh 800g w/BB if i'm not mistaking.
    The GXP BB is available in Team and Blackbox configurations also the Team is 40$ where as the ceramic Blackbox GXP costs 170$ LMFAO like ceramic bearings and weight savings are worth that much.
    Good luck with the NOIR let us know how you like your new lightweight part!!!
    -Alex
  2. #802
    Litespeed Pisgah
    I had a carbon bike which didn't look good for long so I went back to bare metal. 10 year old Litespeed frame with a 6 year old Fox, XTR M952 rear derr, Dura Ace with Speen adapter front derr, M960 crankset with Experimental Prototype rings, Marta brakes with Formula rotors, Tune Speedneedle, Egg Beater Ti with Ti spindles, KCNC post, Syntace F99, Easton flat bars, Hope hubs on ZTR Olympics. 9.0 Kg = 19.8 lbs.
  3. #803
    Scale LTD
    Here's mine. 8.0kg as pictured.
    Not super-light, but reliable, high-performance set-up.
    I have an Extralite Scalhead Headset at home that would probably see the build go sub 8.0kg.
    The fork is not light, but does perform brilliantly.
    I hate the Ritchey Stubby and am waiting for the Tune Capy in 38.2mm to be made (apparently another month or so). I just can't bring myself to get rid of ISP, although I would save around 100gm if I cut it off and put in a lightweight seat-post and shim.
    Let me know your suggestions.
    Bottle Cage 20 Lifeline Titanium
    Bottle Cage Bolts 6 Aluminium x 4
    Bottom Bracket N/A
    Brakes 466 Avid Elixir CR Mag (inc. Rear Adaptor)
    Brake Discs 192 Avid G3 Cleansweep F 160mm/R 140mm
    Disc Bolts 15 Titanium Rotor Bolts
    Cable Guides 10
    Cable Ties 5
    Cassette 247 XTR M970 11-34
    Chain 228 KMC X10SL
    Crankset 442 Lightning 'Extralite' MTB 175mm 64/104 (inc. BB)
    Chainrings 78 Extralite Gara 42/28
    Chainring Bolts 6 FSA
    Chainstay Protector 30 Lizard Skins Large
    Derailleur Front 119 Sram XX Top Pull 38.2
    Derailleur Rear 196 Sram X.0 Medium Cage
    Derailleur Hanger 15 Scott
    Fork 1400 Fox F100 RLC Fit
    Starnut 11
    Frame 1137 Scott Scale LTD '09
    Grips/Plugs 13 Titec Pork Rinds (cut) + plugs
    Handlebar 139 Ritchey WCS Carbon Flat 580
    Headset 90 Ritchey WCS Carbon
    Headset Spacer 6 Carbon
    Pedals 179 Crank Brothers 2Ti (Ward Ind. Short Titanium Spindles)
    Protective Film 10 Plastic Armour
    Skewers 45 KCNC MTB
    Seatpost 134 Ritchey WCS Stubby 55mm
    Seatpost Clamp N/A
    Seat 133 Selle Italia SLR Kit Carbonio Flow
    Shifters 203 Sram X.0 Twisters
    Stem 129 Ritchey WCS Carbon 4-Axis
    Tyre Front 464 Schwalbe Rocket Ron Evo 2.25
    Tyre Rear 468 Schwalbe Racing Ralph Evo 2.1
    Tubes/Stans 120 Stans Liquid
    Wheelset 1290 AC Hubs/ZTR Podium MMX/DT Revo 2.0-1.5/Tape/Valves
    Total 8046
    (8.48kg with training wheels - XTR M975 Wheelset/DT Centrelock Adaptors/Conti RK SS 2.2/Lots of Stans!)
    Attached Thumbnails Attached Thumbnails Post your light-weight bikes!-scale-ltd-1.jpg
  4. #804
    Reputation: xcatax's Avatar
    Grats Mike , i like your bike
    Can i ask you something? ......
    whats your weight? ... stem and handlebar are heavyweight thought
    Rron 2.25 forward tire ? strange for a lightbike that could easy be under 7.5kg
  5. #805
    Quote Originally Posted by xcatax
    I weigh 64kg.
    You are right ... some parts are not so light. I built this bike with some new parts and some parts I already had, such as the stem and handlebar, which, as you say, are pretty heavy as things go. I will replace them as they get to their 'use by date'.
    I am not convinced by the RRon either. I had it lying around so thought I would give it a try. Obviously I could lose a bunch of weight by swapping both tyres for something really light, but it is winter where I live, and it is pretty slippery in the forests. And I am seeing if I like the RRon more than my Race Kings (on my training wheels).
    This bike gets ridden and raced a lot in some pretty rough terrain in all weather, so parts have to be strong and relatively durable as well as light.
  6. #806
    Reputation: nino's Avatar
    To some performance comes first and tires are a big factor in giving the best performance especially on a HT. Me too i am using rather heavy Conti RaceKing 2,2" tires rather than having 300-400g less hanging on my scale....but in the end we ride our bikes and that's where the tires are one of the most important factors.
    @mmmaaaiiikkk:
    Congrats - very nice bike!!
    I see the Extralite Gara rings which come with only a 28t inner ring...i'd go with a smaller inner ring which then would allow you to use a smaller 11-32 cassette alongside a shortcaged derailleur. Both would save weight while also giving a thighter spaced drivetrain.
    I also note standard cables...since the Scale has ongoing housings there's some hidden weight in the housings which could be saved next time you change cables.(-30g)
    A DA front derailleur could save massive weight without hurting shifting performance at all.(-50g)
    I see you run the saddle pretty forward so mounting one of those fancy carbon seatpostclamps offered from MCFK or Tune would also be an option...although somewhat pricey (-70g)
  7. #807
    Quote Originally Posted by nino
    @mmmaaaiiikkk:
    Thanks, Nino.
    These are all good suggestions.
    When the Gara wears out I will get normal rings in 27/42 and think about a 11-32 cassette. A 26T small ring is probably a better idea with the 11-32 (pretty hilly where I live!), but would it work ok with 42T big ring? I need the 42T.
    Hoping to get the Tune Capy when they finally make it in 38.2mm.
    A road FD seems like a good idea now that there are some good mounting options for the Scale.
  8. #808
    I got it Mike
    I use my bike 99% dry conditions and i can go somedays with larsen 1,9(380g) + kenda BG 2.0(440g) or 2 Kenda BG depends of the route .
    fix it you have excess front weight , imo
  9. #809
    Quote Originally Posted by mmmaaaiiikkk
    Thanks, Nino.
    26/42 will be fine. No problem at all.
    Why wait for the Tune capy! Tune announced it along with their carbon seatposts YEARS ago but they have never seen the light...there's MCFK offering the special 38,2mm Scale clamp already (79g):
    http://mcfk.de/ISP.html
  10. #810
    I just find the MCFK one a bit ugly! The Tune looks neater and better to me.
    They have already made the other sizes, just not the 38.2mm yet.
    According to the email they sent me (two weeks ago), the 38.2 mm will be available in 4-6 weeks. But they said the same thing a few months ago!
    And its half the price and the same weight.
  11. #811
    Reputation: Robin v Berkel's Avatar
    test setup 1x10 32t+ Sram XX 11-32T with raceking SS 2.2
    7.96kg/ 17.54Lbs
  12. #812
    Cannondale Maros Team
    Reputation: vladxc's Avatar
    Jan 2009
    good looking, how it's with only one ring in the front?
  13. #813
    Quote Originally Posted by Robin v Berkel
    Top gear is 32/11? C'mon - This is getting ridiculous.
  14. #814
    why is that ridiculous ?? its works so why i need bigger then 32T
  15. #815
    No longer a hardtailkid.
    Reputation: hardtailkid's Avatar
    Who makes a 28-42 crankset? That would be ideal for me. Does MIddleburn?
    Quote Originally Posted by anthonys
    Its still just the push of a button away...
    I am no longer a hardtailkid. 2012 Trek Remedy 9!
  16. #816
    "They Call Me Bone'z"
    Reputation: facelessfools's Avatar
    Quote Originally Posted by hardtailkid
    RAH!
  17. #817
    Friggin Awesome
    Too bad that crankset probably cost more than my brakes
  18. #818
    ups and downs
  19. #819
    I'd be willing to spend $120 max. So I'm thinking TruVativ Stylo. Got really a weight weenie, but I want a crank around 850g.
  20. #820
    ill get you a weight for the stylo's...905g complete set... just weighed my set. that will be on ebay today.
    RAH!
  21. #821
    i have got same and my top speed is 52km/h ... why should i need more?
  22. #822
    Cuánto pesa?
    Reputation: Jake Pay's Avatar
    This thread was for lite bikes....Not all this bulls</>hit...
  23. #823
    Dec 2005
    2010 Anthem X 20.9lbs.
  24. #824
    20 years in the woods
    You single-ring folk should come and check some of my local hills,you might reconsider your options...
    xcracer87,nice ride,can you post the build specs?
    Gajas what?
  25. #825
    Quote Originally Posted by Nozes
    Just out of curiosity where do you live, that would make me reconsider?
    I am from Texas (700ft of elevation, completely flat), I have yet to find anything here in Texas that I can't ride with 36t x 11-34.
    Last week I went up to Colorado to race nationals (8800ft of elevation, not flat), I was able to clear everything on both the pro course(3 1/2 laps ~450ft climbing per lap) and the amateur course(1 lap, 1600ft of climbin). Doesn't sound like much, but the start climb, I think not 100% positive, was around a 20% grade.
    So if a junior racer from Texas can pull that off, I would think it would be very possible for someone who lived there to run 1x9. (oh and I did meet another junior who lived in Durango, who ran 1x9 34t x 11-34 on his 29er)
  26. #826
    Reputation: brentos's Avatar
    1x9 Can't be ridden everywhere. Tack on another 2,000' onto the 20% wall at the start of the nationals course and you'll need a lower gear.
    1x9 will work for steep climbs or long climbs, but not climbs that are both. As a matter of fact, it would work locally for me (Utah) if I didn't ride the trails that are normally considered "unridable" and are usually just hiked, but still moutain bike legal. There's a loop out my back door that has about 1600' of climbing between 15% and 20%, then drops down to a slightly downhill road where you have to keep up with traffic for safety's sake (30+ mph). I'd love to go with a single ring setup, but this ride alone keeps me from doing it.
    1x9 (or 10) works on 95% of all the trails ridden by mountain bikers...but some ride that other 5%. So, in summary, you're both right! Nice Anthem.
    And because we're supposed to bo posting bikes....My reasonably light Cannondale 29er...22.1 lb.
    Attached Thumbnails Attached Thumbnails Post your light-weight bikes!-dsc_0113.jpg
  27. #827
    master blaster
    Reputation: veloreality's Avatar
    no carbon here 17lbs 7oz
  28. #828
    This is my Sette Ace, it will soon be getting a new seat/seatpost from mattias which will be all white. It sits at 22lbs and 10oz possibly a bit less with this chain.
    Frame Sette Ace M 2500
    Fork Magura Durin SL 100mm(race+starnut) 1357
    Shock RockShox Monarch 3.3 ?
    Bottle Cage Karbona sc wing 17
    Bolts Al 2
    Headset Cane Creek S8 99
    Top Cap, Bolt & Spacers ?
    Stem Sette Edge 110mm 152
    Handlebar Easton Ec90 111
    Shifter Sram X0 Gripshifters 195
    Grips ESI Racers Edge ?
    Seatpost Merek Carbon 180
    Seat Selle Italia SLR blue 141
    SeatClamp Woodman 12
    Brakes Hayes Stroker Gram F 228
    Hayes Stroker Gram R 246
    Rotors Hope Floating 160mm 92
    Hope Floating 140mm 72
    Crankset Middleburn RS-7 Duo 541
    CrankBolts Ti Self Extracting 22
    Bottom Bracket Crankbrothers Cobalt Ti 180
    Front Derailleur Sram xx 117
    Rear Derailleur Sram x9 + Al wheels & bolts 195
    Chain KMC X9 SL TiN ?
    Cassette Nino's Ti 11-34t 189
    Skewer J&L Flyweight 32
    Wheelset Hope Pro II's, DT Rev's, Sun EQ21 1576
    Front Tire Hutchinson Python 2.0 Airlite ?
    Rear Tire Hutchinson cobra 2.0 Airlite 527
    Peddles Crankbrothers Eggbeater 2Ti 224
    RAH!
  29. #829
    Reputation: sam111's Avatar
    Quote Originally Posted by alivio
    DAMN!
    How light?
    Not sure mate.. i think its around 22lbs.. maybe more
  30. #830
    gone for a bike ride
    Reputation: culturesponge's Avatar
    2010 S-Works Stumpjumper FSR frame build v2
    here's my trailbike, built up from an upgraded warranty replacement frame + fork. not a full-on weenie bike - its built for SoCal trail riding, especially climbing/descending - will save the full-tilt weenie build for next time around perhaps with a hardtail - that's if the weight weenie sickness ever returns....
    had the suspension back from Specialized SLC the other week after a custom S-Tune to make it ride more like a long travel S-Works Epic & have been "field testing" it up in Santa Cruz - really happy with this build & wish i was still up there riding now
    Spec 09.08.2010 (August 9th 2010)
    2010 S-Works Stumpjumper FSR frame (M) (+M4x15 Ti Brain mount bolt +M5x15mm plastic cable guide bolts +3M film plugs over cage holes)
    SL 3k carbon veneer chainstay protector with 3M protective film (custom)
    Specialized/Fox AFR Brain Shock 140mm travel w/ remote Trail Tune inertia valve, rebound adj. & Brain Fade (custom S-Tuned)
    Specialized FutureShock S140TA 115-140mm adjustable travel, rebound adj. & Brain Fade (custom S-Tuned)
    S-Works MTB crankset (+CarbonTi 40/26 X-Double Kit +Enduro zero hybrid ceramic OSBB bearings +Extralite EB1& EB1.1 bolts)
    CB Candy 4Ti pedals (black)
    2010 KMC X10 SL
    SRAM XX DM 39-26 FD (mod) (was 111g now 108g +mod M5 Schmolke carbon bolts)
    08 SRAM X.0 Med RD (+Nobu 3k carbon inner plate +AFCbike pivot bolt +Zen 3k carbon pulleys with hybrid ceramic bearings +Toronto Cycles alloy pulley bolts)
    SRAM X.0 Twistshift (mod) (drilled out to 1.5mm for Power Cordz +machined cable adjusters +M4x16mm plastic bolts)
    Gore Ride-On Professional derailleur housing (black) (+Yumeya end caps +Power Cordz 1.2mm or XTR inners)
    Syntace Duraflite 580x25.4mm bars
    SL 3k carbon veneer bar end plugs (custom)
    Hi Temp 42 foam grips or Poshbike’s black nitrile (in photo’s)
    Cane Creek carbon expander starnut
    Cane Creek headset bearings/races
    Extralite Extrabolt 10 derilium headset spacers 15mm
    CarbonTi 3k carbon headset cap + alloy bolt. (mod) (custom) (no graphics)
    Extralite Ultrastem UL3 25.4x100mm stem (custom) (flipped +Ti bolts +black tape over graphics)
    Formula R1 brakeset nero/nero (custom) (no red! +BK Composites carbon brackets +Motul RBF-660 fluid)
    F. mod Magura QM-12 180mm adaptor when needed (mod) (matte black ceramic was 24g now 14g +TH Ti bolts)
    R. Eliflap carbon+alloy cnc 160mm R. rotor adaptor (custom) (matte black ceramic @9g +TH Ti bolts)
    SwissStop Disc 25 organic pads or Formula sintered
    08 Selle Italia SLR Carbonio Flow (black)
    New Ultimate 30.9x330mm 3k carbon seatpost (mod) (was 135g now 118g +Smudek 3k carbon cradle)
    Smudek UD carbon seatpost clamp 36.9mm (custom)
    Cateye super skinny zipties (black)
    Cateye Strada Wireless (black) (+.3g HP magnet on spoke with silicone blob)
    Wheelset #1 (Training/Trails)
    DT Swiss XR 1450 Race Edition wheelset (custom) (custom graphics +Enduro zero hybrid ceramic bearings +36 star rat)
    SRAM XG-999 12-36t (custom)(+Chris King 12t alloy lockring +FRM 36t matte black ceramic was gold ano) or XTR M970 11-34 (+Extralite EB3.3 lockring +Yumeya Ti 17-20)
    DT Swiss RWS Titan MTB skewers (+Mavic composite end caps)
    CL adaptors (mod) (were 22g now 11g & 15g +DT Swiss lockrings)
    F. rotor Scrub 180mm (black) or Formula SS 180mm floating (black)
    R. rotor Scrub 160mm (black) or Formula SS 160mm (custom) (matte black ceramic)
    Racing Ralph 26x2.25 EVO SnakeSkin or (custom) Conti Mountain King Protection 2.2 (black sidewalls not red)
    Stans 21mm yellow tape (6cm overlap +3M paint protective film on overlap)
    Stans Olympic UST valves (+black Purely Custom alloy valve collars +Mavic rubber valve washers)
    Hutchinson Protect Air (120g)
    Wheelset #2 (Timed Sprints)
    2010 DT Swiss XRC 300 rims (28h) (custom) (black tape over red DT graphics)
    2010 DT Swiss 190 CL hubs (custom)(+36 star rat) (black tape over red DT graphics)
    DT Swiss Aerolite spokes (black)
    DT Swiss Pro Loc nips (black)
    Tune Skyline MTB skewers (black)
    SRAM XG-999 11-32t (+Extralite EB3.3 lockring)
    CL adaptors (mod) (were 22g now10g +Chris King 12t or DT Swiss lockrings)
    Innolite 160mm rotors
    Rocket Ron 26x2.25 EVO or Race King SuperSonic 26x2.2 (depending on season)
    Stans yellow tape (6cm overlap +3M paint protective film on overlap)
    weight with XRC300 wheelset : 9152g or 20.17lb
    Future Upgrades:
    2011 CB Eggbeater 11 Pedals (tuned)
    2011 Rocket Ron 26x2.25 EVO SnakeSkin (or the new tubeless ready version)
    pics of bike build on scales here: http://www.flickr.com/photos/culture...th/4843297889/
    thanks to everyone who supplied components or helped directly with this build
    Adam @ Tree Fort Bikes : http://www.treefortbikes.com/
    Andrea aka eliflap : http://eliflap.blog.aruba.it/
    Andy @ Posh Bikes : http://www.poshbikes.com/
    Autobot 5000 @ Purely Custom : http://www.purelycustom.com/
    Bastien @ Dulight : http://dulight.fr/
    Brian @ Chain Reaction Cycles : http://www.chainreactioncycles.com/
    Chris @ Real World Cycling : http://www.enduroforkseals.com/id232.html
    Chris @ Scrub (100% made in USA!) : http://www.scrubcomponents.com
    Claudio aka clood69 : http://shop.ebay.com/clood69/m.html?...&_trksid=p4340
    David @ DT Swiss : http://www.dtswiss.com
    Davide @ Bikeonline.it : http://www.bikeonline.it/catalog/
    Giovanni @ Light Bikes : http://sales.light-bikes.com/
    Herr Nano @ Nano Bike Parts : http://nano-bike-parts.de
    Jason @ Fairwheel Bikes : http://fairwheelbikes.com/
    Jason & Andy @ Competitive Cyclist : http://www.competitivecyclist.com/
    Jens & Stefan @ Schmolke Carbon : http://www.schmolke-carbon.de/
    Joe @ joechaimui-rothshek-bikeparts : http://stores.ebay.com/joechaimui-rothshek-bikeparts
    LaLa, Mark & Brian @ Incycle San Dimas : http://incycle.com/
    Matthais @ Bike Products : http://www.bike-products.com/
    Martin @ Starbike : http://www.starbike.com/
    Martin @ MCFK : http://www.mcfk.de/
    Mike @ Tekbolt : http://www.tekbolt.com/
    Mike @ Universal Cycles : http://www.universalcycles.com/
    Nobu aka nobu335 : http://shop.ebay.com/nobu335/m.html?...&_trksid=p3686
    Pete @ Stans Notubes : http://www.notubes.com/home.php
    Phillip @ Power Cordz : http://www.powercordz.com/
    Philippe @ JPRB 1 Wheels : http://www.jpracingbike1.com/
    Rich & Vikki @ Wheelbuilder : http://www.wheelbuilder.com/
    Robert @ R2-Bike : http://r2-bike.com/
    Selcuk @ AFC bike : http://www.afcbike.com/tr/
    Shane @ Mucky Nutz : http://www.muckynutz.com/
    Smudek @ Smud-Carbon : http://www.smud-carbon.eu/
    Tom @ Toronto Cycles : http://www.torontocycles.com/
    Tony @ Specialized SLC : www.specialized.com
    best
    vid clip; http://www.flickr.com/photos/culturesponge/4877893733/
    <object type="application/x-shockwave-flash" width="640" height="480" data="http://www.flickr.com/apps/video/stewart.swf?v=71377" classid="clsid27CDB6E-AE6D-11cf-96B8-444553540000"> <param name="flashvars" value="intl_lang=en-us&photo_secret=996612a5cb&photo_id=4877893733&hd_ default=false"></param> <param name="movie" value="http://www.flickr.com/apps/video/stewart.swf?v=71377"></param> <param name="bgcolor" value="#000000"></param> <param name="allowFullScreen" value="true"></param><embed type="application/x-shockwave-flash" src="http://www.flickr.com/apps/video/stewart.swf?v=71377" bgcolor="#000000" allowfullscreen="true" flashvars="intl_lang=en-us&photo_secret=996612a5cb&photo_id=4877893733&hd_ default=false" height="480" width="640"></embed></object>
    <a href="http://www.flickr.com/photos/culturesponge/4843205289/" title="2010 S-Works Stumpjumper FSR custom build V2 - 28.07.10 montage-4 by culturesponge, on Flickr"><img src="http://farm5.static.flickr.com/4087/4843205289_80a599143a_b.jpg" width="1024" height="600" alt="2010 S-Works Stumpjumper FSR custom build V2 - 28.07.10 montage-4" /></a>
    <a href="http://www.flickr.com/photos/culturesponge/4840644939/" title="2010 S-Works Stumpjumper FSR custom build V2 - 28.07.10 #1204 v2 by culturesponge, on Flickr"><img src="http://farm5.static.flickr.com/4111/4840644939_337b56d031_b.jpg" width="1024" height="682" alt="2010 S-Works Stumpjumper FSR custom build V2 - 28.07.10 #1204 v2" /></a>
    <a href="http://www.flickr.com/photos/culturesponge/4840074726/" title="2010 S-Works Stumpjumper FSR custom build V2 - S-Tuned S140TA 115-140mm fork - 28.07.10 #1193 v2 by culturesponge, on Flickr"><img src="http://farm5.static.flickr.com/4148/4840074726_6e315fb4c0_b.jpg" width="640" height="1024" alt="2010 S-Works Stumpjumper FSR custom build V2 - S-Tuned S140TA 115-140mm fork - 28.07.10 #1193 v2" /></a>
    <a href="http://www.flickr.com/photos/culturesponge/4839479614/" title="2010 S-Works Stumpjumper FSR custom build V2 - 2x9 with SRAM XO twist shifters - 28.07.10 #1398 v2 by culturesponge, on Flickr"><img src="http://farm5.static.flickr.com/4152/4839479614_863f711cc7_b.jpg" width="1024" height="683" alt="2010 S-Works Stumpjumper FSR custom build V2 - 2x9 with SRAM XO twist shifters - 28.07.10 #1398 v2" /></a>
    <a href="http://www.flickr.com/photos/culturesponge/4839563934/" title="2010 S-Works Stumpjumper FSR custom build V2 - Gore Ride-On Pro - 28.07.10 #1397 v2 by culturesponge, on Flickr"><img src="http://farm5.static.flickr.com/4148/4839563934_0b7c2941fc_b.jpg" width="1024" height="631" alt="2010 S-Works Stumpjumper FSR custom build V2 - Gore Ride-On Pro - 28.07.10 #1397 v2" /></a>
    <a href="http://www.flickr.com/photos/culturesponge/4839389955/" title="2010 S-Works Stumpjumper FSR custom build V2 - black Cateye Strada wireless odometer - 28.07.10 #1217 v2 by culturesponge, on Flickr"><img src="http://farm5.static.flickr.com/4151/4839389955_ff23852545_b.jpg" width="683" height="1024" alt="2010 S-Works Stumpjumper FSR custom build V2 - black Cateye Strada wireless odometer - 28.07.10 #1217 v2" /></a>
    <a href="http://www.flickr.com/photos/culturesponge/4839219223/" title="2010 S-Works Stumpjumper FSR custom build V2 - Tune Skyline MTB skewers - 28.07.10 #1052 v2 by culturesponge, on Flickr"><img src="http://farm5.static.flickr.com/4149/4839219223_f5aa071a57_b.jpg" width="1024" height="683" alt="2010 S-Works Stumpjumper FSR custom build V2 - Tune Skyline MTB skewers - 28.07.10 #1052 v2" /></a>
    <a href="http://www.flickr.com/photos/culturesponge/4839607410/" title="2010 S-Works Stumpjumper FSR custom build V2 - AFC Bike XO pivot - 28.07.10 #1187 v2 by culturesponge, on Flickr"><img src="http://farm5.static.flickr.com/4110/4839607410_53f3683a33_b.jpg" width="683" height="1024" alt="2010 S-Works Stumpjumper FSR custom build V2 - AFC Bike XO pivot - 28.07.10 #1187 v2" /></a>
    <a href="http://www.flickr.com/photos/culturesponge/4839696842/" title="2010 S-Works Stumpjumper FSR custom build V2 - CarbonTi chainrings - 28.07.10 #1226 v2 by culturesponge, on Flickr"><img src="http://farm5.static.flickr.com/4110/4839696842_6be25a7380_b.jpg" width="683" height="1024" alt="2010 S-Works Stumpjumper FSR custom build V2 - CarbonTi chainrings - 28.07.10 #1226 v2" /></a>
    <a href="http://www.flickr.com/photos/culturesponge/4841666194/" title="2010 S-Works Stumpjumper FSR custom build V2 - 28.07.10 #1010 v2 by culturesponge, on Flickr"><img src="http://farm5.static.flickr.com/4092/4841666194_f914b62d98_b.jpg" width="1024" height="625" alt="2010 S-Works Stumpjumper FSR custom build V2 - 28.07.10 #1010 v2" /></a>
    <a href="http://www.flickr.com/photos/culturesponge/4888380464/" title="day one @ dragonfly cottage - 04.08.10 #1723 v2 by culturesponge, on Flickr"><img src="http://farm5.static.flickr.com/4117/4888380464_886a6a1f71_b.jpg" width="1024" height="684" alt="day one @ dragonfly cottage - 04.08.10 #1723 v2" /></a>
    ....edit to directly link images + vid clip....
  31. #831
    Pretty impressive weight for a 140mm travel trail bike!
  32. #832
    thanks!
    after the original 09 sw stumpy frame went kaput last September it was great to have a second crack at building my idea of the perfect trailbike - so far so good
  33. #833
    double post (sorry) served must be busy - please delete
  34. #834
    Great project,great weight,good looking bike and all,but...580mm flat bar on a 140mm trail bike? Come on...
    Gajas what?
  35. #835
    thanks
    lol! tried 680mm riser bars back in '04 & loathed them
    those 25.4 x 580mm Syntace Duraflite "flat" bars have a 6º rise, when the forks are in 140mm long travel mode it levels up the saddle and the grips - perfect for longer rides
    ...not sure i'd want bars any wider with a SL 25.4 stem - perhaps on the next build with a stiffer 31.8
    pic - montage of the bike with the forks in 140mm travel mode
    <a href="http://www.flickr.com/photos/culturesponge/4843297889/" title="2010 S-Works Stumpjumper FSR custom build V2 - 28.07.10 montage-1 by culturesponge, on Flickr"><img src="http://farm5.static.flickr.com/4131/4843297889_c88521efef_b.jpg" width="1024" height="586" alt="2010 S-Works Stumpjumper FSR custom build V2 - 28.07.10 montage-1" /></a>
    ....edit to directly link image....
  36. #836
    upgraded 2008 Stumpjumper Carbon Pro Euro Version
    here’s mrs culturesponges trailbike, its an upgraded 2008 Stumpjumper Carbon Pro Euro Version, terrific for me she’s a mountain bike riding weight weenie too
    08 Stumpjumper Carbon Pro (S) (Euro model) +M5x17mm plastic cable guide bolts +3M film over bottle cage mounts)
    Specialized Future Shock S120, 120mm travel, carbon 1 1/8 to 1.5" steerer, Trail Tune inertia valve, adjustable Brain Fade & rebound, piggyback one sided air spring & damper (custom tune) (neg spring @ 55)
    Specialized AFR 120mm Shock w/ remote Trail Tune inertia valve, adj rebound and Brain Fade, 7.25x1.75"
    XTR M970 crankset (custom) XTR 44t outer chainring +Rotor Q-Rings 33/23 +KCNC red ano chainring bolts)
    XTR M970 B.B. (+Enduro Zero ceramic bearings)
    CB Candy SL black (custom) (+CB red ano springs instead of blue)
    09 KMC X10 SL TiN
    XTR M970 DMD F. derailleur (mod) (was 118g now 111g +mod Schmolke carbon M4 bolts)
    08 SRAM X.0 med R. derallieur (+Nobu 3k carbon inner cage+ KCNC red ano alloy jockey bolts +SRAM Black Box ceramic pulleys +AFCBike red ano XO pivot bolt)
    08 SRAM XO Twist Shifters (mod+custom) (widened to 1.5mm for PC +SRAM Amy grips +M5x20mm plastic bolts)
    Jagwire Ripcord Pro carbon look derallieur cables (+1.2mm Power Cordz inner cables)
    Syntace F119 stem (31.8x75mm) (mod) (one-off machined stem shim with windows +Ti bolts)
    Syntace Duraflite UD carbon bar (mod) (31.8x560mm)
    Titec pork rinds (mod) (trimmed to 85mm)
    3k carbon veneer end plugs (custom made)
    Cane Creek headset (+3k CC carbon interlok headset spacers)
    CarbonTi 3k carbon top cap +Toronto Cycles red alloy bolt
    2010 Formula R1 rosso carbonio (custom) (red ano with carbon levers +BK Composites carbon mount brackets)
    SwissStop Disc 25 pads with Scrubs or Formula sintered with SS rotors
    F. rotor adaptor Magura QM-6 180mm (+Ti bolts) (modified) (raw alloy) (was 22g now 16g)
    R. rotor adaptor Magura QM-12 160mm (+Ti bolts) (modified) (raw alloy) (was 22g now 14g)
    Terry Butterfly carbon & leather saddle (+Selle Italia SLR Carbonio rails +shell)
    Syntace P6 3k carbon seatpost (30.9 x 300mm) (mod) (+Ti bolts)
    Smudek 36.9 ud carbon seatpost collar (custom made)
    Fluffy Velcro chainstay protector (also on upper rear triangle)
    3m protective film on crank arms
    Cateye superthin zipties
    Wheelset #1 (Local Trails/Sprints)
    09 DT Swiss XRC330 carbon rims (28h)
    09 DT Swiss 190s CL hubs (+DT 36 star rat)
    09 DT Swiss Aerolite spokes (black)
    09 DT Swiss Pro Loc nips (black)
    Tune Skyline MTB skewers (red ano)
    08 SRAM PG990 11-34 Cassette (red ano)
    CL Adaptors (modified) (raw alloy) (machined from 22g to F. 14g R.11g +DT Swiss lockrings)
    F. Rotor Scrub 180mm (black)
    R. Rotor Scrub 160mm (black)
    Schwalbe Rocket Ron EVO 26x 2.25 or Race King SuperSonic 26x2.2 (depending on season)
    DT Swiss UST valves (+red ano Purely Custom SL valve collars)
    Hutchinson Protect Air (60g in each tire)
    Wheelset #2 (Trail Riding)
    Specialized DT Swiss 4.2d rims 28h
    Specialized/DT Swiss Stout & 340s (+36 star rat)
    DT Swiss Competition spokes (black)
    DT Swiss Alloy nips (red ano)
    DT Swiss RWS MTB Thru Bolt skewers (red)
    XTR M970 + FRM 12-36 Cassette (red ano 36t)
    CL Adaptors (Mod) (were 22g now 15g each +DT Swiss lockrings)
    F. rotor Formula floating180mm rotor (black)
    R. rotor Formula 160mm rotor (custom) (matte black ceramic)
    F. tire Conti Mountain King Protection 26x 2.2
    R. tire Schwalbe Racing Ralph EVO SnakeSkin 26x 2.25
    DT Swiss XR UST rim strips
    Hutchinson Protect Air (90g in each tire)
    Weight 24.07.10 with XRC330 wheelset: 10kg (22lb)
    Future Upgrades: Gore Ride-On Professional cable housing (black)
    pics of bikes upgrade components on scales here : http://www.flickr.com/photos/culture...th/4841988416/
    <a href="http://www.flickr.com/photos/culturesponge/4889426352/" title="2008 Stumpjumper Carbon Pro FSR Euro version upgraded - 28.07.10 #1323 montage v2 by culturesponge, on Flickr"><img src="http://farm5.static.flickr.com/4140/4889426352_64d8225d6b_b.jpg" width="1024" height="593" alt="2008 Stumpjumper Carbon Pro FSR Euro version upgraded - 28.07.10 #1323 montage v2" /></a>
    <a href="http://www.flickr.com/photos/culturesponge/4842381248/" title="2008 Stumpjumper Carbon Pro FSR Euro version upgraded - 28.07.10 #1278 v2 by culturesponge, on Flickr"><img src="http://farm5.static.flickr.com/4147/4842381248_82dba78aa8_b.jpg" width="1024" height="625" alt="2008 Stumpjumper Carbon Pro FSR Euro version upgraded - 28.07.10 #1278 v2" /></a>
    <a href="http://www.flickr.com/photos/culturesponge/4841839307/" title="2008 Stumpjumper Carbon Pro FSR Euro version upgraded - 28.07.10 #1283 v2 by culturesponge, on Flickr"><img src="http://farm5.static.flickr.com/4152/4841839307_8cc3c43cc6_b.jpg" width="1024" height="641" alt="2008 Stumpjumper Carbon Pro FSR Euro version upgraded - 28.07.10 #1283 v2" /></a>
    <a href="http://www.flickr.com/photos/culturesponge/4842340280/" title="2008 Stumpjumper Carbon Pro FSR Euro version upgraded - 28.07.10 #1345 v2 by culturesponge, on Flickr"><img src="http://farm5.static.flickr.com/4153/4842340280_c071ed31d9_b.jpg" width="683" height="1024" alt="2008 Stumpjumper Carbon Pro FSR Euro version upgraded - 28.07.10 #1345 v2" /></a>
    <a href="http://www.flickr.com/photos/culturesponge/4841684671/" title="2008 Stumpjumper Carbon Pro FSR Euro version upgraded - 28.07.10 #1343 v2 by culturesponge, on Flickr"><img src="http://farm5.static.flickr.com/4105/4841684671_2f0e8d179a_b.jpg" width="683" height="1024" alt="2008 Stumpjumper Carbon Pro FSR Euro version upgraded - 28.07.10 #1343 v2" /></a>
    <a href="http://www.flickr.com/photos/culturesponge/4842263816/" title="2008 Stumpjumper Carbon Pro FSR Euro version upgraded - 28.07.10 #1341 v2 by culturesponge, on Flickr"><img src="http://farm5.static.flickr.com/4103/4842263816_2a6300c349_b.jpg" width="683" height="1024" alt="2008 Stumpjumper Carbon Pro FSR Euro version upgraded - 28.07.10 #1341 v2" /></a>
    <a href="http://www.flickr.com/photos/culturesponge/4841607791/" title="2008 Stumpjumper Carbon Pro FSR Euro version upgraded - 28.07.10 #1357 v2 by culturesponge, on Flickr"><img src="http://farm5.static.flickr.com/4129/4841607791_daa1b413b8_b.jpg" width="683" height="1024" alt="2008 Stumpjumper Carbon Pro FSR Euro version upgraded - 28.07.10 #1357 v2" /></a>
    <a href="http://www.flickr.com/photos/culturesponge/4841516641/" title="2008 Stumpjumper Carbon Pro FSR Euro version upgraded - Titec Pork Rinds - 28.07.10 #1350 v2 by culturesponge, on Flickr"><img src="http://farm5.static.flickr.com/4105/4841516641_2a6975f80b_b.jpg" width="1024" height="683" alt="2008 Stumpjumper Carbon Pro FSR Euro version upgraded - Titec Pork Rinds - 28.07.10 #1350 v2" /></a>
    <a href="http://www.flickr.com/photos/culturesponge/4841417953/" title="2008 Stumpjumper Carbon Pro FSR Euro version upgraded - 28.07.10 #1358 v2 by culturesponge, on Flickr"><img src="http://farm5.static.flickr.com/4091/4841417953_8caf67834e_b.jpg" width="1024" height="683" alt="2008 Stumpjumper Carbon Pro FSR Euro version upgraded - 28.07.10 #1358 v2" /></a>
    <a href="http://www.flickr.com/photos/culturesponge/4841988416/" title="2008 Stumpjumper Carbon Pro FSR Euro version upgraded - Smudek custom made carbon seatpost clamp - 28.07.10 #1360 v2 by culturesponge, on Flickr"><img src="http://farm5.static.flickr.com/4105/4841988416_2cfe7cec7a_b.jpg" width="683" height="1024" alt="2008 Stumpjumper Carbon Pro FSR Euro version upgraded - Smudek custom made carbon seatpost clamp - 28.07.10 #1360 v2" /></a>
  37. #837
    Dec 2005
    whore.
  38. #838
    Quote Originally Posted by xcracer87
    whore.
    eh?
    care to explain
  39. #839
    The Missing
    Culturespone,
    great looking set of bikes super awesome !
  40. #840
    Reputation: amillmtb's Avatar
    Jun 2005
    Culturesponge,
    I want to one day have a wife like yours.
  41. #841
    Cuánto pesa?
    culturesponge
  42. #842
    thanks, she's one in a billion & the only reason why i don't live in the UK anymore
    we were both up @ 5am to do the photos for this thread & rode our bikes 7 miles (most of it uphill!) with all the extra camera gear to get to the location - sorry if there's zillions of pics it was very hard to edit them down
    best!
    (typo)
  43. #843
    ups and downs
    Quote Originally Posted by culturesponge
    eh?
    care to explain
    At a guess I'd say he's saying that weight weenies is a male only term, and that a female lightweight bike enthusiast would be a weight whore. It doesn't have quite the same ring to it.
  44. #844
    Dec 2005
    I'm referring to your first bike post. A little overboard, you have at least 5 pictures and video of your bike... well done, but you are a bike whore. no problems there.
  45. #845
    agreed. lot's of characters on the internet
    thought it might have been because i'd thanked Schmolke & Mcfk in the link list i'd compiled to make my post more interesting - even though i had to sent both the bars & seatpost back because they were substandard
    let's perhaps use the same definition for both male or female weight weenies in future peeps
  46. #846
    LOL - just skip the post the & keep your rude commrnts to yourself!
    not a whore - just a skint, holiday missing wally at the very end of an endless bike build
  47. #847
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    How I DREAM to have a cycling weight weenie woman.....(sigh)
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
  48. #848
    keep yours eyes peeled, they are out there - but take some finding!
    ... we have some fairly steep climbs here - all it took was a reasonably light wheelset + better gripping & faster rolling tires & she had the weenie sickness as bad as me
    i think her bike build is better than mine. more co-ordinated
  49. #849
    Reputation: mtbnozpikr's Avatar
    They sure do. I just found one so we'll see what happens.
    2012 Intense M9
    2012 Pivot Mach 5.7 Carbon
    2008 Look 595
    2007 Custom Litespeed Sewanee
  50. #850
    Jun 2005
    Where in CA are you?
  51. #851
    Greetings from Mrs. Culturesponge
    Thanks for the compliments everybody
    We are in Santa Monica. Paseo Miramar is a steep but short climb up to Eagle Pass Rd. that we ride from time to time. Having a lighter bike makes the difference between fun and misery. Women prefer long, lean toned legs over weight lifters legs. Trust me...Ever see a weight lifter wearing a skirt? It is also one of the reasons I use Q Rings.
    Congratulations mtbnozpikr (does she know you by this user name)? If not, don't tell her.
    Best of luck!
  52. #852
    Pronghorn SW Race
    In the lightest spec 8284g, for those from behind the big pond 18.26lbs.
    SLIDESHOW
  53. #853
    I like ur bike Chris , good work
  54. #854
    Now that's a show-stopper!
    Very nice Chris,congrats on the great machine!
    Gajas what?
  55. #855
    Small Bump Compliance?
    Wow, that Pronghorn must have near zero small bump compliance. I can see that the Instant Center of that linkage is like meters ahead of the bike. That means that initially the entire linkage will rotate like it were a swingarm of several meters length. Strange design choice.
  56. #856
    Quote Originally Posted by ginsu2k
    I don't see what you are getting at. The linkage (swing link attached to the shock) doesn't have an instant center, it has an actual center of rotation, which is at the pivot point on the top tube. I don't see how tuning the shock rate with that configuration would be any different than with a more traditionally configured rocker.
  57. #857
    21.9 lbs and ready to ride
  58. #858
    Jun 2005
    Finished for now. Recently added the 105 road FD the XX chainrings on the Hollowgrams, and I finally cut and bled the Hope brakes. Next spring I plan on rebuilding the wheels with Revolutions and getting a carbon bar to replace the porker that is on the bike now. After these two changes I think the bike will be about a pound or pound and a half lighter. Currently it's 22.4, for details see the spreadsheet below.
    <a href="http://www.flickr.com/photos/39929703@N05/4918280239/" title="D5000 Shoot by mtbiker321, on Flickr"><img src="http://farm5.static.flickr.com/4096/4918280239_1a8573970e.jpg" width="500" height="332" alt="D5000 Shoot" /></a>
    <a href="http://www.flickr.com/photos/39929703@N05/4918278987/" title="D5000 Shoot by mtbiker321, on Flickr"><img src="http://farm5.static.flickr.com/4141/4918278987_47aa7af70e.jpg" width="500" height="332" alt="D5000 Shoot" /></a>
    <a href="http://www.flickr.com/photos/39929703@N05/4918877848/" title="D5000 Shoot by mtbiker321, on Flickr"><img src="http://farm5.static.flickr.com/4121/4918877848_d2d1eac977.jpg" width="500" height="332" alt="D5000 Shoot" /></a>
    Attached Thumbnails Attached Thumbnails Post your light-weight bikes!-cannondale-29er-weight-8-23-10.png
  59. #859
    Reputation: gm1230126's Avatar
    Quote Originally Posted by veloreality
    anyone else rock thier water bottle in your jersey pocket? being full rigid i lose my bottles often and while racing with people right behind you it can be a pain. ive ridden about 4 times recently with a bottle in my center jersey pocket and im liking it so far. i tried it in my side pocket but it would spin my jersey around so the bottle was by my stomache so that didnt work
    Search Tacx Tao....you'll never have any issues losing bottles with these cages. Grab more surface of the bottle and are both rubber and aluminum for even more grab.
    Needed: 26.8mm XTR seatpost, blue GT/Grundig Jersey.
  60. #860
    Quote Originally Posted by smilinsteve
    A rocker is not a linkage, it is a link!
    Take an engineering Dynamics class and the truth will be revealed!
  61. #861
    I think you are over analyzing it ginsu.
    You said this:
    If you can see where the instant center of rotation for the rear axle is, without seeing the pivot location at the bottom bracket, you are a better man than I.
    Regardless, I say it doesn't matter as far as small bump compliance is concerned.
    Instant center defines the axle path at any given point in the suspension travel, and for a horst link bike it varies throughout the travel. It only defines axle path, which doesn't necesarily have anything to do with compliance.
    As an example, if the axle path at some point in the travel becomes a vertical straight line, then the instant center goes to infinity. That doesn't mean it absorbs bumps any worse than a moment before when the axle was following a curve with a center near the bb.
    It sounds like you are imagining the distance to the instant center to be a moment arm, but it isn't.
  62. #862
    Reputation: dragonq's Avatar
    Nov 2006
    Woo many good bikes you guys have here, so shame to post mine with those crappy parts, not so light, but like its color and speed.
    Attached Thumbnails Attached Thumbnails Post your light-weight bikes!-paduano.jpg
    Daccordi - Attila
    Cinelli - Freedom Rider
    Paduano - Caligola
  63. #863
    Aug 2005
    Quote Originally Posted by 1415chris
    Pronghorn SW Race
    SLIDESHOW
    Very nice bike, but it looks like the speedneedle won't last very long this way.
    You have a setback seatpost and the saddle still all the way back.
    I give you a dozen rides, then the rails of the speedneedle will start to fail.
  64. #864
    Quote Originally Posted by yellowbook
    I beg to differ. I've been riding one SpeedNeedle with pretty much that exact positioning for the last 3 years, and another for about 2 years. Neither one is showing any signs of rail failure. One is the older version without Kevlar wrap on the rails, and the other is the newer version with.
  65. #865
    i rode my speedneedle just like that for 1500+ miles and it was perfect.
    My bikes:
    2009 Santa Cruz Blur XC Carbon, 1x9 "trail monster"
    1996 Bontrager Privateer Comp, 1x9, Hydro V's
  66. #866
    Quote Originally Posted by dragonq
    Nice bike!
    Can you tell me more about the frame and fork?
  67. #867
    This, students, is an example of false modesty.
    That thing looks like it weighs a ton!
  68. #868
    Aug 2005
    Ok, more power to you then.
    I had both the old and the new speedneedle fail on seatposts like this when pushed all the way back.
    Since then I switched to a setback seatpost and a different clamp system.
    That seems to work for me with zero problems.
  69. #869
    Hi all this is my bike. Not exactly light weight at 28.16 but keen to loose some weight.
  70. #870
    Reputation: cadre's Avatar
    Quote Originally Posted by hisbabyf
    It will be helpful for the rest if u were to post the spec down. I'm from SMBF too
    - IMPOSSIBLE IS NOTHING!! -
  71. #871
    Quote Originally Posted by cadre
    Hey hello! i remember your thread with the super light bike!
    Here are the specs, its made for AM so wanna keep the components AM ready
    Frame: Chumba XCL Size S
    Fork: 2010 36 Fox Float RC2 FIT
    Headset: ChrisKing
    Shock: Fox RP23
    Wheelset:ZTR Flow rims/DT revolution spokes/Hadley hubs/Brass Nipples
    Rim Tape: Stan's 5g Tubeless rimtape
    Valve: Stan's Tubeless valves
    Tires: F/Kenda Nevagal 2.35 R/Continental RaceKing 2.2 Supersonic
    Tubes: NIL(Tubeless)
    Rotors: F/ Ashima AiRotor 160mm R/ Ashima AiRotor 140mm
    Brakeset: Avid Elixir CR
    Rear Dee: Sram X0 carbon/Token jockey wheels
    Front Dee: XT M770 E-type
    Shifters: Sram X0 gripshift
    Crankset: XTR M970
    Bottom Bracket: ChrisKing
    Bashring: Salsa
    Pedals: Welgo MG 1
    Chain: XTR CN7701
    Cassette: XT M970
    Bar: Spank Spike 777
    Grips: ODI Long Neck
    Stem: Thomson X4 70mm silver
    Seat Clamp: Hope 38.5
    Seatpost: USE1 Alien Cyclops
    Saddle: WTB Rocket V Team Titanium
    Spacers: Token Carbon
    Rear skewer: Salsa QR
  72. #872
    Reputation: V.P.'s Avatar
    You might loose a pound just by cleaning it
  73. #873
    V.P., LOL, I was thinking the same thing.
    Best, John
  74. #874
    Reputation: kiwimtbr's Avatar
    My Bike
    Hey, Ihave been doing a bit of work on my old GT I-Drive and would like a few opinions on it.Its not superlight like most bikes on this thread but its working for me.
    So i started out with the bike weighing in at 15.66kg, since then i have replaced the wheelset- Notubes ZTR Arch
    Tyres-Hutichson Pythons Probably change to Rocket Rons
    Converted to 1 X 9 and love it
    new seat and seat post
    still want to change cranks to probably SLX 175mm
    Need to change rear der- open to comments on this.
    At the moment it weighs 13.76 kg, and i know it will never be super light but doing this on a budget.
    cheers for reading
    Attached Thumbnails Attached Thumbnails Post your light-weight bikes!-gt-i-drive-copy.jpg
    2010 Yeti ASR 7
  75. #875
    Ghost HTX Lector
    Hi,
    some pictures of my bike:
    Hope you like it. Weight as pictured above is 8.5kg.
    Greetings from Germany!
  76. #876
    Reputation: illini's Avatar
    Dec 2009
    Not sure my Trek deserves to be here amongst all these great bikes. WW bikes are really expensive so i can only do with what i can do on a budget.
    Frame- 2007 Trek Elite 9.9
    Fork- Reba Race
    Brakes- Elixer CR
    Bars- TruVativ Team Carbon
    Shifter- Sram Attack Twist Shifter
    Stem- Ritchey WCS 4 Axis
    Headset- Chris King
    Seat- Selle Flite Gel Flow
    Post- Bontrager X Carbon
    Rear Derailleur- XT M772
    Crank Arms- Bontrager GXP Made by TruVativ (very underrated imo)
    Pedals- Shimano DX ( I know Heavy but they wont break)
    Chainring- Middleburn 32X
    Rims- Bontrager Race Disc
    Tires- Kenda SB8/light weight tubes
    I know there are things like my rims, cranks and post, that i could improve on. The bike is a shade under 23lb. Im happy with the setup until something breaks then i will replace with something better.
    Attached Thumbnails Attached Thumbnails Post your light-weight bikes!-side.jpg
  77. #877
    Reputation: IM31408's Avatar
    Dec 2008
    Quote Originally Posted by mike49
    Hi,
    Really nice looking bike. Looks like a lot of effort was put into getting everything to match. Great bike!
    Brakes stop your bike, breaks stop you from riding
  78. #878
    Nov 2006
    Quote Originally Posted by scuver
    Nice bike!
    The frame is Titanium Paduano Caligola, I am 1.68m I told them to make the downtube slightly thicker to minimize the flex as well as minimize the space of of where top and down tube meeting the headtube (look more handsome but heavier . Fork is Pace (ex DT) RC- 31 C-type also made of Ti but wrapped with carbon.
    Daccordi - Attila
    Paduano - Caligola
  79. #879
    Nov 2006
    The FD is a good found, what seatpost are you using?
    Daccordi - Attila
    Paduano - Caligola
  80. #880
    Reputation: seppk's Avatar
    Wow nice bike! really like the gold motif. Some black cranks like KCNC would really complete it
  81. #881
    Looks like one of these, but i'm not for sure. http://cgi.ebay.com/ws/eBayISAPI.dll...#ht_2175wt_911
  82. #882
    Quote Originally Posted by IM31408
    Thank you!
    Yes, spent some time in finding und putting together matching parts. Still not finished yet
  83. #883
    Quote Originally Posted by seppk
    I'm already looking for a Clavicula. Quite some money to spend, but it will come.
  84. #884
    Doesntplaywellwithmorons!
    Reputation: DeeEight's Avatar
    Instant Center is a stupid name created by Tony Ellsworth for that imaginary point in space where all true virtual pivot point bikes rotate around. You find it by lining up the linkage points of the upper and lower links and projecting a line forwards thru them. Of course where that point in space is will change as the suspension cycles / sags between a loaded and unloaded state. All horst-link 4-bars, all VPP bikes, all DW-Links have an IC/VP point someplace.
    In the case of your lovely carbon frame, the initial point lines up like he said, meters ahead of the frame and roughly at handlebar level. However once you take rider weight sag into account, it looks like the point will be lower down around a height of the fork crown.
  85. #885
    The FD is Shimano LX Gold Edition from 2005. Fits perfect and weighs only 135g.
    The seatpost is a cleaned FSA K-Force Light. Quite heavy though, but looks nice and has a very solid seat clamp.
  86. #886
    Cuánto pesa?
    Attached Thumbnails Attached Thumbnails Post your light-weight bikes!-dsc00047%5B1%5D.jpg
  87. #887
    That Ghost Lector is one of the nicest rides I have seen in a while, and I probably look through 50 pages of "Post Your _____s" threads a day, both on here and Pinkbike.com. Color me stupid for asking, but what rear derailleur is that? It looks like last years XT Shadow, but the cage isn't silver.
  88. #888
    It's a XTR Shadow with carbon cage. I'm still looking for some Yumeya parts for the derailleur.
  89. #889
    Go on Jensonusa.com. They have a craaazy sale on Yumeya stuff. I didn't recognize the derailleur because the edges of the "X" on it look more rounded than XTRs I've seen
    http://www.jensonusa.com/search/?s=y...btnSearch.y=11
  90. #890
    Nov 2006
    didn't know that it look so nice after cleaned
    Daccordi - Attila
    Paduano - Caligola
  91. #891
    just ride
    Good job!
    Not the lightest but not expensive bike either... @ $1,655 w/ sram blackbox ceramic bearings, '05 rockshox sid, etc... 21.2 lbs.
    21 lbs 4 oz. = 21.25lbs
  92. #892
    Reputation: ghughes.hesinc's Avatar
    No front derallier? What, do you shift it by hand?
    Anyway that's very little Lbs. for under 1700 hundred, nice job.
  93. #893
    Changed the cranks and now have a matching fork as well:
    Weight as pictured above is 8.4kg = 18.5lbs. Hope you like it...
  94. #894
    Nov 2008
    Sub 19 pounds.
    Attached Thumbnails Attached Thumbnails Post your light-weight bikes!-s7300047.jpg
  95. #895
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    I only come here for cool bike pics, and I like the Paduano. I might have picked a few colorful parts to set off all the metallic and black parts, though.
    "it IS possible that you are faster or slower than anybody else who is having at least as much if not more or less fun"
  96. #896
    Reputation: markw1970's Avatar
    Oct 2007
    I've posted elsewhere... 20.1 lb
    Highlights:
    SRAM Red rear, Dura Ace front (with Speen), SRAM 900TT levers on Pauls' Thumbies. KCNC bars, grips, stem and seatpost.
  97. #897
    May 2010
    How light is light enough?(Can I post 9.5kg Ht?)
  98. #898
    Reputation: biketuna's Avatar
    go for it
    _______________
    1x10 IS SO FINE on my 21.9 lbs IBIS SL-R
    11-36 XTR in the rear, 36T wide-narrow upfront
  99. #899
    My Volare Tirreno - Sub 10Kg
  100. #900
    10 speed grip shift for shimano? Who makes that?
Members who have read this thread: 339
