Page 65 of 83 FirstFirst ... 15 55 61 62 63 64 65 66 67 68 69 75 ... LastLast
Results 1,601 to 1,625 of 2073
  1. #1601
    Reputation: phlegm's Avatar
    Nice bike - let's see a scale shot.
    You get extra points for lining up your tires nicely.
  2. #1602
    Reputation: tskubi's Avatar
    Mar 2011
    Quote Originally Posted by phlegm View Post
    Nice bike -
    Here we go :
  3. #1603
    SUBLIM8er
    Reputation: Axis II's Avatar
    Quote Originally Posted by AnteXTC View Post
    Attachment 785290
    8.05kg with heavy tubes. Not really a ww ride but still light
    Skickat från min GT-I9100 via Tapatalk 2
    Is that a Dura Ace 9speed RD with a 32t Cassette? If so, how does it work? Also, what kind of chain keeper are you using? I'm building a WW 1 x 9 now and need some ideas.
    Thx!
    Every man has inside himself a parasitic being who is acting not at all to his advantage.
    William S. Burroughs
  4. #1604
    The Storck is pretty awesome...
  5. #1605
    Jan 2011
    Sv: Post your light-weight bikes!
    Quote Originally Posted by Axis II View Post
    Thx!
    Yes it is a dura ace 7800 with xg 999 11-32. I just changed the 11t pulleys to 10t. The chainkeeper are from helium components
    Skickat från min Nexus 7 via Tapatalk 2
  6. #1606
    Mar 2011
    Storck updated :
    Frm blackhole saddle & enve wheels
  7. #1607
    Apr 2013
    Extralite F1
    Some views of my F1 with the Look Fournales and, later, the Noleen I used to bring it down to just under 20. The frame was purchased by Specialized to, and I'm speculating here, check for patent infringement by the linkage. Had a good time slowly building it up bit by bit off eBay and here on MTBR. Thanks to the many who've posted here with tips on wise use of our gram allotment in pursuit of lightweight builds.
    Scott
    Attached Thumbnails Attached Thumbnails Post your light-weight bikes!-f1.jpg
  8. #1608
    Feb 2010
    '07 ellsworth truth
    KCNC s.post/stem
    selle italia SL saddle
    Stylo WC Handle bar
    Float fork
    XO drivetrain
    Noir crank/ E13 34T chianring
    Exustar PM25 pedals
    Hygia Elite brakes
    Crest/Hope/DTSwiss wheels
    2.1 Rocket Ron
    23lbs
  9. #1609
    SUBLIM8er
    Thanks. I have a 7800 DA RD and will consider it in place of the Shadow XTR medium cage now. I like the idea of the shorter cage.
  10. #1610
    LAN
    LAN is offline
    Here is my Scalpel 29er with XX1
    Weight is 9,32kg as pictured with 2,35" tires. In race spec with lighter rotors and 2,1" Racing Ralph just below 9kg
    Attached Thumbnails Attached Thumbnails Post your light-weight bikes!-scalpel-1.jpg
  11. #1611
    Nice bike, and nice photos as well. Seems like the Lefty is key to shedding weight.
    I know very little about it.
    Does anyone have info handy on total weight for a Lefty setup, and any gotchas in the frame, i.e. weird stuff like bearing contact angles if on a non-Cannondale frame?
  12. #1612
    Reputation: andrepsz's Avatar
    Jan 2013
    I recently worked on this bike (20.9lbs - 9.480g) replacing a DT swiss XRC 100 fork to a lefty Carbon XLR 90mm for 29er.
    In this case it was added to the bike 216g since the DT swiss was already pretty light at 1320g (with housing and cable, no remote), my Lefty setup is 1375.5g for the fork only (with remote)+project 321 lefty adapter (161g) - total: 1536.5g.
    My DT swiss was pretty old and not responsive anymore, had to sacrify 216g but I am very happy with the result, super smooth and versatile since I can play with this bike switching from 26er and 29er front wheels. 69er is the current setup... its fun!
    You can go lighter perhaps with a lefty PBR or DLR, I thing the lightest lefty is the Speed Carbon at 1159g...but I'm not a lefty expert, thats just from my research before choosing this current Lefty for my bike.
  13. #1613
    Scott Scale 40 2010
    Hi, this is my bike which was built in 2010 and aimed at breaking the 10kg barrier. It was 9.4kg then, but I managed to shed ~380g recently in an effort to hit the 9kg mark. Will be sub 9kg soon once my cranks are changed
    Bottle Cage: Carbon eBay - 18.5g
    Brakes: AEST V-Brakes - 216g
    Cassette: Shimano XT 11-32 - 261g
    Chain (107 Links): KMC X10SL - 236g
    Crank w BB: Aerozine X12 (Double) - 702g
    F Dee: Shimano CX-70 with Carbon Clamp - 93.6g
    Fork: RST First Platinum - 1615g
    Frame: Scott Scale 40 2010 - 1606g
    Grips: KCNC Eva Foam - 15.2g
    Handlebar: KCNC SC Bone - 120g
    Headset: Ritchey - 120g
    Innertubes: Geax tubes - 280g
    Pedals: Xpedo - 206g
    R Dee: Shimano XTR M970 - 186g
    Saddle: WTB Devo (Titanium) - 213g
    Seat Clamp: KCNC SC10 - 19.6g
    Seatpost: KCNC Ti Pro Lite - 165g
    Shifters w Levers: Shimano XT Dual Control M770 (V-Brakes) - 527g
    Skewers: KCNC - 47g
    Spacers: Carbon - 14g
    Stem: KCNC Flyride (90mm) - 113g
    Tires: Maxxis Maxxlite 310 - 624g
    Wheelset: Novatec A141SB - 118g/F062SB-AA - 289g, Wheelsmith DB14 spokes, ZTR 355 - 1571g
    Others: 52g
    Total: 9020.9g
  14. #1614
    Reputation: VanillaEps's Avatar
    Aug 2010
    Spec SJ Carbon Comp HT
    Fox 32 Float FIT RLC 100
    Niner carbon bar
    SRAM X9 shifters and RD
    Avid Elixir CR's
    PRO Tharsis grips
    Niner RDO seat post
    Selle Italia Max Flite
    Sun Ringle Black Flag Pros
    S-Works Renegades
    MRP Bling Ring
    e.thirteen chain guide
    XX cassette
    XTR pedals
    I'm looking to get XX or XX1 crankset and that should get it under 22 lbs.
  15. #1615
    Reputation: roaringboy's Avatar
    Exotic Carbon - built by my own fair hands - 16.65lbs by my reckoning:
    Really want a new crankset but funds won't allow at the moment. Decided on a Raceface Next SL and will keep my Uberbikes 36t middle ring.
    Next up is a lighter set of Egg Beaters and these will be relegated back to my winter singlespeed. Been desperately trying to find some 4ti's but no luck as of yet. May just plump for some more 1's and replace the spindles with ti.
    Also going to go back to foam grips - i hate these ESI's with a passion - they hurt my hands and offer little to no grip in the wet. And they're an absolute c**t to get on and off (but certainly don't "throttle", which is their only redeeming feature for me).
  16. #1616
    Nice bike, and nice component choices!
    I'm always curious to see if the spreadsheet weight matches an actual scale-based total of the bike - there always seems to be some extra grammage in there somehow.
    Re the grips, I hear you on the ESIs. When they get chewed up enough, I simply cut them off. In terms of comfort (and to match your bar), you could try these ergo ones from Ritchey for about the same weight as the ESIs:
    Mountain Bike Grips - Ritchey Mountain Bicycle Grips
  17. #1617
    Re: Post your light-weight bikes!
    Thanks. I've always wondered that too. How much does grease weigh???
    I've had the ritchey wcs foam grips and had bonty x's before these. Liked both of those. Switched to the rigid fork and heard the esi's had good vibration damping so thought I'd give them a go.
    Sent from my XT890 using Tapatalk 2
  18. #1618
    Feb 2010
    117g for the chain is amazingly low. My kmc x10sl cut short for 1x9 use weighs 220g.
  19. #1619
    Yup! There's not much chance that that chain actually weighs 117g.
  20. #1620
    Agreed, unless you are only using 10 links.
  21. #1621
    Quote Originally Posted by TigWorld View Post
    Quote Originally Posted by BlownCivic View Post
    D'oh! Typo Well spotted chaps
  22. #1622
    Reputation: Motomatt's Avatar
    Niner RDO XX1 With Wheels I built 16.29 Lbs , 7390 Gr
    MotoMatt » Blog Archive » Niner RDO With Wheels I built 16.29 Lbs , 7390 Gr
    Weight as pictured ready to ride (pedals, cages, garmin, mount, 16.29 Lbs , 7390 Gr
    Frame : Niner RDO Small
    Fork : Niner RDO
    Bell : Titanium
    Goupo : X11 (Shifter,Crank bb30,Deraileur,Cassette,& Chain)
    Seat post : Woodman
    Seat post Collar: Woodman
    Saddle : Selle Italia Carbon SLR Ti Rails
    Pedals: Bee Bop
    Handle bar: Truvativ Noir T30 carbon flat bar, (31.8) 5d-600mm
    Brakes : Hope Mono Mini Pro
    Rotors : Scrubb/Stans , waiting for my Sicc's to get back
    Grips : ESI grips MTB Racers Edge silicone
    Headset: FSA
    Bottom Brackett : Hawk PF
    Rims : Crest
    Spoke : Sapin CX Ray Blalded
    Nipples : Alloy
    Tires : Rocket Ron Tubless
    Rear Skewer : Token
    Computer : Garmin 500
    Computer Mount : Sram
    Cage : Forte
    Stem : Torelli Heavy 30deg , Could not find a lite 1
    Stem Cap : KCNC
    Cables : AICAN Bungarus
  23. #1623
    SUBLIM8er
    Carver Carbon 1 x 9, 29er- 16.1 lbs
  24. #1624
    Y'know Axis you can us a Dura-Ace short cage with a 11-34 cassette, you just screw in the B-screw the whole way, or use a longer B-screw. Also, don't drop as many chains with a shorter cage due to higher spring tension. You'll get it below 16lbs because you can shorten the chain as well as the dropped weight from the derailleur.
  25. #1625
    SUBLIM8er
    Post your light-weight bikes!-shadow.jpgPost your light-weight bikes!-untitled.jpg
    Quote Originally Posted by ginsu2k View Post
    I thought the same on the weight of the DA RD but was surprised to discover this. And this is with some tuning of the jockey pully wheels (10t) and clamp screw. It shifts fantastically now with the Shadow and no dropped chains with the Helium chain keeper but the saved weight on the chain is tempting.
