• 10-29-2012
    skyfire1202
    :thumbsup: Oh, I didn't notice your signature.
  • 10-29-2012
    skyfire1202
    Is it a new BCD size or can previous model cranks be used and be fitted with XX1 chainrings?
  • 10-29-2012
    Axis II
    Originally Posted by ryguy135 View Post
    IMO, and I know people won't agree, I'd say sub 21 lbs for a 29er HT, sub 19lbs for a 26er HT, sub 24 lbs for a FS 29er, and sub 22 lbs for a FS 26er qualifies if we're talking XC bike.
    This thread could definitely use some 24-26 lb Mojo's or 32 lb DH bikes though.
    Posting these kinds of weights are why this forum is dead, IMHO.
  • 10-29-2012
    TigWorld
    Originally Posted by SamoM View Post
    ...handmade carbon frame...
    Awesome. Tell us more. How did you make the frame?
  • 10-30-2012
    SamoM
    well, actually I didn't make it but someone else did. unfortunately, he was only making them for about 5 years & stopped about 3 years ago. he's a specialist in designing special parts for sailboats here in Slovenia, so this was only his ''part time job'' :)
    a well known female rider Blaza Klemencic won an european title in marathon xc on this frame. it is made of monocoque technology (one piece) and was the only real competition to scale ltd frames a few years back.
    as I've said mostly all components are really low budget, so is this frame, which is used (in the garage by a friend :) ) and was sold at 1400eur new.
  • 11-15-2012
    _Pat_
    Scott scale 20
    Currently sitting at 8.440 Kg
  • 11-16-2012
    Twisted_leader
    3 Attachment(s)
    Azonic Az-7
    Haven't weighed the final product but have kept an accurate record of all the parts. The sum of which comes in at 7767 gms or 17.1 lbs.
    Kind regards... David
  • 11-23-2012
    roaringboy
    Very nice. How are the Podiums holding up?
  • 11-28-2012
    tracerey
    2011 Rocky Mountain Vertex Team RSL
    Frame: 2011 Rocky Mountain Vertex Team RSL (Medium)
    Fork: 2012 Fox Float 100mm.
    Headset: Cane Creek IS42
    Bottom Bracket: Chris King
    Handle Bar: Truvativ Nior World Cup
    Stem: FSA K-Force 90mm.
    Grip: Lizard Skin Lock-On
    Brake: Shimano XTR
    Rotor: Shimano XTR 160mm.
    Crank: Shimano XTR (Triple Crankset)
    Pedal: Shimano XTR Race
    Shifter: Shimano XTR
    Front Derailluer: Shimano XTR (Direct Mount)
    Rear Derailluer: Shimano XTR (Shadow Short Cage)
    Cassette: Shimano XTR (11-32)
    Chain: Shimano XTR
    Saddle: 2012 WTB Siverado
    Seatpost: Truvativ Nior Worl Cup
    Seatclamp: Rocky Mountain
    Wheelset: Mavic Croosmax SLR
    Tires: Maxxis Crossmark 2.1mm Tubeless
    Weight: 22lbs.
  • 11-28-2012
    limba
    and you know some idiot will quote that picture and say "SWEET!"
  • 11-28-2012
    Mountain Cycle Shawn
    So, what you're saying is that you're half an idiot?
  • 11-28-2012
    2fargon
    Originally Posted by Twisted_leader View Post
    Haven't weighed the final product but have kept an accurate record of all the parts. The sum of which comes in at 7767 gms or 17.1 lbs. Not bad for a steel frame.
    This is a steel frame bike? Not trying to be a di@k but I believe the AZ7 is an (extremely light) alloy frame.
  • 11-28-2012
    limba
    Yes, Shawn, that's exactly what I'm saying. Thanks for telling us what kind of cars you drive. We were all curious about that.
  • 11-28-2012
    Oh, you're very welcome bro! Maybe I'll take ou for a spin sometime.
  • 11-28-2012
    limba
    No thanks Bro but keep us updated if you buy anymore cars. Feel free to post Actual Size pictures of them too.
  • 11-28-2012
    Twisted_leader
    My apologies, you are correct. I was told Xtrolite G7 was a steel alloy but it is an aluminium alloy. I have just put on a set of Magura Durin Superlite forks so it now is up to 8500 gms.
    I will try and correct my original statement if i can.
  • 11-28-2012
    Actual size might be a little difficult.
  • 11-30-2012
    roaringboy
    wow...I was really thinking abour buying an Exotic frame
    I thoroughly recommend it. Cost me about £400 and came in under 3lbs:-
  • 11-30-2012
    John Kuhl
    That is a frame. Where is the rest of
    it? We want to see its when its done.
  • 11-30-2012
    roaringboy
    It's on the previous page. Although it's now under 18lbs as I swapped out the captain for a rocket ron. I need to sort some better pics really.
  • 12-01-2012
    Jmoccia
    First ever bike build just about complete. I think
    KICK•N•WING
    8,077g • 17.806lbs
    $3,028.03
    Frame- Sette Serum Elite Full Carbon 17
    1195g - 2.634 lbs
    $447.25 ($1400.00)
    Crank- FSA K-Force Light 386
    10-Speed 175mm
    27/39t
    Q-Factor: 168mm
    BCD: 86mm
    Chainline: 48mm
    739g - 1.629 lbs
    $237.99 ($959.93)
    Pedals- CrankBrothers Eggbeaters 2ti
    SPD bolt pattern
    218g
    $219.99
    BB- MegaExo Ceramic 68mm
    107g - .235 lbs
    $0 (included w/crank)
    Brakes- Ashima PCB
    AiRotor08: 160mm/85g
    Rotor Compatibility: 6-bolt
    Caliper Mount: Post 74mm
    Pad: Sintered
    170g
    308g
    $256.95 ($399.98)
    Fork- Marzocci Corsa 2012
    120mm (80 or 100 w/spacer)
    AIR + NEG. SPRING
    9mm DROP OUT
    32mm ANODIZED ALUMINUM
    ALUMINUM STEER TUBE
    6" PM D-BRAKE
    length 491,5 mm.
    steer tube/offset 44 mm.
    1630 g.
    $425.00
    WheelSet- American classic
    26" tubeless
    26mm wide x 23mm deep
    1486g
    $419.99 ($850.00)
    Bars- SwordFish riser carbon bar/stem
    width- 660mm
    stem- 110mm
    375g
    $179.00
    Grips- 2013 T-ONE H2O
    Locking Ring
    Length : 130mm
    97g
    $15.98
    SeatPost- CrankBrothers Kronolog
    31.6*405mm
    477g
    Remote- 28g
    $299.95
    Seat- Tioga Carbonite
    135g
    $61.00 ($129.99)
    Shifters- SRAM X0 2x9 Speed Trigger
    9 Speed
    Zero Loss travel
    225g
    $144.99 ($275.00)
    Front Derailleur- SRAM X.0 2x10
    Low Clamp
    Top Pull/top swing
    Aluminum upper knuckle
    Carbon fiber outer pulley cage
    Clamp 34.9mm (1-3/8")
    Capacity 15
    Max Ring- 42teeth
    132g
    $67.00
    Rear Derailleur- SRAM X.0
    Medium Cage
    9 speed
    193g
    $179.95 ($250.00)
    Cassette- SRAM PowerGlide 990
    11-34
    305g
    $72.99 ($114.00)
    Chain- New KMC X10SL DLC
    10-Speed
    1/2” X 11/128”
    Links- 116
    Pin length- 5,88 mm
    257g
    $92.85 ($134.95)
    Tires-
  • 12-01-2012
    Jmoccia
    Pic
    Only one pic at a time?
  • 12-01-2012
    Jmoccia
    Another one
    More pics
  • 12-01-2012
    Jmoccia
    One more
    More pics one at a time
  • 12-01-2012
    Jmoccia
    Last one
    Let me know if this bike should be any good when I'm done or did I max my credit card for nothin lol
