Page 42 of 42 FirstFirst ... 323839404142
Results 2,051 to 2,078 of 2078
  1. #2051
    Reputation: chomxxo's Avatar
    Jet 9 RDO size XL w/Lefty
    Haven't seen a light FS 29er posted up in a while so here's mine, 21.40 pounds. Everything is fully race-tested. Awaiting shipment of a carbon steerer that should put me within striking distance of 20.9#
    Niner Jet 9 RDO frame size XL
    Cannondale Lefty MAX Carbon fork, converted to 120mm
    SRAM XX1 grip shift with 36t ring
    Notubes ZTR Valor wheelset, rear rebuilt with stiffer spokes
    Schwalbe Thunder Burt Snakeskin tires, 2.1"
    Formula R1 brakes
    Race Face Next bar 725mm
    KCNC stem with replaced bolts, 90mm
    Enve seatpost, 400mm
    Specialized S-works cranks, 180mm
    Time ATAC XS Titan Carbon pedals
    ESI Racers edge grips
    Selle Italia SLR XC saddle
    King Ti bottle cage
    Project 321 Lefty steerer
    Post your light-weight bikes!-13260099_914361422019546_8114300686071886633_n.jpg
  2. #2052
    Apr 2016
    Feeling a bit self conscious here lol
    Rebuilt my 2006 Haro n weighed it yesterday. Started at 33.5, n 1500 later it's 22.9. I thought I was doin good lol guess I need a better job? Hahaa
  3. #2053
    Jun 2015
    Quote Originally Posted by JHouston View Post
    10 lbs for 1500usd does not sound bad. What were swapped parts?
    Sent from my SM-G930V using Tapatalk
  4. #2054
    Apr 2016
    Quote Originally Posted by Frank Fields View Post
    Thx much! I guess i didnt think it was possible to get lower than 20 pounds and still be strong enough. Havent ridden in years, but everyday i learn ab something new or improved. Feel like i been away too long, must be getting old hahaa...
    So heres my build list... every part has been replaced and bought new, except my frame and seat post clamp.
    Frame 2006 Haro V-Series
    Fork Manitou R7
    Headset Cane Creek 40 Series EC-34
    Drivetrain
    Cranks XT M8000 165 mm / single 32T
    BB XT M800
    Chain XT M8000 HG-701
    Cassette XT M8000 11-40T 11 spd
    Derailleur XT M8000 med cage
    Shifter, cable XT M8000
    Pedals Wellgo C266
    Brake set
    Calipers XT M8000
    Levers XT M8000
    Rotors Ashima AiRotor 180mm / 160mm
    Rotor bolts Clarks red anodized
    Cockpit
    Handelbars Raceface Turbine riser
    Stem Raceface Turbine 70mm stem
    HS riser, cap Raceface
    Grips Raceface Half Nelson
    Seat Raceface Aeffect
    Seatpost Raceface Evolve
    Seatclamp *Oops moment. forgot ab it till assembly lol
    Wheel set
    Rims Stans ZTR Crest
    Hubs BWW Pure D400
    Spokes DT revolution
    QR Halo Porkies
    Tires Michelin Wild Rac'r Liteskin tubeless 26 x 2.25
  5. #2055
    Jun 2015
    Fork Manitou R7
    Drivetrain
    BB XT M800
    Pedals Wellgo C266
    Brake set
    Calipers XT M8000
    Levers XT M8000
    Cockpit
    Wheel set
    Hubs BWW Pure D400
    QR Halo Porkies
    Wheelset price, weight, lead where to buy?
  6. #2056
    Apr 2016
    Stan's ZTR Crest 26 Custom Build
    My set weighs 1500 grams w the D400 conv hubs. Cost me $325 w tape n valve stem installed. Very smooth, fast wheels, but havent quite got my bike totally dialed in, so anxious to see how it is out in the dirt still
  7. #2057
    Specialized
    Reputation: karimian5's Avatar
    Carbon Rigid Singlespeed with 29er fork and disc brakes . Still more work to do - 11.1 lbs !!!
    Attached Thumbnails Attached Thumbnails Post your light-weight bikes!-dscn1198%5B1%5D.jpg
  8. #2058
    Reputation: andrepsz's Avatar
    Jan 2013
    Quote Originally Posted by karimian5 View Post
    Well one brake lever is quite irresponsible. Wishing you the best of luck on your rides!
  9. #2059
    Dec 2008
    And 14 spokes in the rear...
  10. #2060
    Specialized
    Both brakes are modulated . Wheels are solid and spokes highly tensioned . This is a true WW bike btw .
  11. #2061
    Reputation: Joe Handlebar's Avatar
    Apr 2016
    Seb, your insane! (And I mean that in the best way possible!) If you don't know this guy...he makes a lot of the stuff he uses. I've seen some really neat, and some crazy stuff come across his G+ page.
    The member formerly known as Redtires....
  12. #2062
    Mar 2016
    This is insane....
    Sent from my Nexus 5 using Tapatalk
  13. #2063
    Jan 2013
    Well...despite the arguable project, he made it to bikerumor! congrats.
    Readers' Rides: Seb K's heavily modified 11.1 lb / 5.08 kg mountain bike! - Bikerumor
  14. #2064
    Reputation: gks333's Avatar
    Mar 2013
    I give the guy props for doing something "because it can be done". Great job. What distinguishes a MTB from a road or cyclocross bike though? I have seen numerous "rigid MTB's" with crazy low weight, so if I buy a road bike, place beefy tires on it and give it a flat bar handle bar is it a MTB? In the end, to each there own right? MTB is a very loosely used term these days.
    2015 Pivot Mach 4. XX1, Guide ultimate, NOX wheels, Next SL, KS LEV integra dropper. 24.56lbs
  15. #2065
    Quote Originally Posted by gks333 View Post
    Exactly. This bike would not last ten minutes on a trail. Oh you used half the spoke count? What a great idea!
    Yet I post up a 21.4lb race-tested XL FS 29er and get zero comments, lame.
  16. #2066
    Jan 2013
    New question here.
    The true is that we are all whining because of the thread title.
    I bet you this rideable bike below is lighter than ALL the bikes on this thread...and is still meeting the requirements to appear on this neck of the woods.
    interestingly also has a saddle...
    So I decided to create the following:
    Post your light-weight Hardtail MTB 27.5er or 29er with Dropper post!
    Post your light-weight FS MTB 27.5er or 29er with Dropper post!
    Post your light-weight Hardtail MTB, Rigid, 27.5er or 29er single speed!
  17. #2067
    Reputation: RS VR6's Avatar
    Eh...what the heck. I'll post up.
    Weight is 20.5lbs ready to ride (including bottle cage and Garmin mount) Not really weight weenie since I don't think I did anything real creative to really reduce weight. All off the shelf stuff with no exotic Euro boutique parts.
    Only weight I really remember is the weight of the frame at 1111gr. Only reason I remembered it is because it came out to all 1's. The fork is 1400 something grams. Can't recall the exact number.
    I'm #145 before gear.
  18. #2068
    Nice work. I had a JET RDO at 24lb with SIDs and a few other heavier parts (XT cranks Chris King Hubs etc), but the Lefty seems to make a big difference.
    I still managed to win a few races on it - I was surprised how fast it rode for a duelly.
    Lapierre XR29ei, Chris King LB Carbon, XTR 1 X 10
    Planet X Dirty Harry
    Chiner 29er SS
  19. #2069
    Thats light for the forks, I didn't realise Fox were so light. What model are they?
    I guess I may have to post my Chiner up too.
    Quote Originally Posted by RS VR6 View Post
    Chiner 29er SS
  20. #2070
    Life Is Short
    Reputation: fatcat's Avatar
    Mar 2006
    19.5....dang this bike is like a DH bike compared to karimian's 11 pounder...but its a decent weight for a comfort/cx bike
    Attached Thumbnails Attached Thumbnails Post your light-weight bikes!-img_20160612_184706.jpg
    Ride More, Eat More
  21. #2071
    Quote Originally Posted by xcbarny View Post
    Its a "Performance" level Fox. It's got the FIT cartridge, but no Kashima or Trail Adjust.
  22. #2072
    Jan 2011
    8.45kg
    Skickat från min Nexus 6P via Tapatalk
  23. #2073
    Reputation: nunokas's Avatar
    Aug 2014
    New weight with the new fox step cast.
  24. #2074
    Nov 2014
    That KTM is looking sharp. It would be interesting to hear how everyone gets on with the new Fox forks.I haven't ridden anything that comes close to my old Magura Durin...
    The big difference between your picture and *that* one is the bike in your picture has been ridden
    I'm rebuilding my Chiner niner w/ XX1, Sids, dropper which should come in under 8.7kg ready to ride, and will post up when done
  25. #2075
    Scott Scale 610
    A bit of an update on my Scott Scale 610
    Spec:
    Frame: Scott Scale 610 Carbon
    Fork: Rock Shox Sid RCT3
    Headset: Hope
    Wheels: Light Bicycle Carbon with DT Swiss 190 Hubs & MT Zoom Tubeless Valves
    Tyres: Schwalbe Rocket Ron Evo
    Group set: Shimano XTR M9000 Race with Absolute Black Oval 34t
    Pedals: XTR M9000 Race
    Bottom Bracket: Hope
    Seat Post: Smud Carbon 34.9x350
    Seat Clamp: KCNC
    Stem: New Ultimate Evo
    Stem Cap: Absolute Black
    Bars: New Ultimate Evo Carbon
    Grips: Lizzard Skins DSP
    Saddle: Selle San Marco Aspide Carbon FX Protek
    Weight as per image 8.23Kg (18.14 pounds)
  26. #2076
    Aug 2014
    Ok, final weight
  27. #2077
    Storck Rebelion 1.1
    At 20.5 lbs. I would consider this lightweight for a 210 lbs. rider.....and you don't see too many of them
    Attached Thumbnails Attached Thumbnails Post your light-weight bikes!-storck-rebelion-1.1.jpg
  28. #2078
    Aug 2016
    Found a "NOS" 2013 Scott Scale 700RC Nino frame-only that I just completed the full build.
    Weighed in at 18.6lbs (8470g) in the config as you see but without pedals. Very stoked.
