Results 1 to 21 of 21
Thread: PG990 cassette
    Reputation: Tiffster's Avatar
    PG990 cassette
    Hi,
    Does anyone know what the weight of the PG990 upper block is? You have 5 cogs fixed to the alloy carrier - just this bit on its own. Im thinking this combined with 4 Titanium lower cogs would work out around the same weight as XTR?
    Nov 2007
    11-32 is 209.6g
    A Shimano XT is lighter at 191.3g
    Reputation: nino's Avatar
    Titanium cogs...
    Quote Originally Posted by Tiffster
    Hi,
    i don't have the detailed PG990 weight but here's such a tuning performed on the actual 11-32 XTR cassette:
    XTR Cassette 11-32: 223g
    XTR - 5 lower cogs (steel)+aluminium spacers+lockring: 89g
    Titanium - 5 lower cogs+plastic spacers+lockring: 50g
    tuned XTR Cassette with lower cogs out of titanium: 189g
    just for comparison rasons: Full-Titanium 11-32 Cassette: 167g
    so on the XTR the difference of those 5 lowest cogs is 34g. Just take note that on this example the 11t titanium cog and plastic spacers are already worth 9g. So with regular aluminium spacers and a standard steel 11t the savings would only be 25g. So do the math with the numbers provided by petercarm: 209g + ca.40g for 4 titanium cogs+plastic spacers+lockring= ca. 250g. with standard aluminium spacers and steel 11t we might look at 260g....heavy!!
    I had another thought, on the 990 they use the solid alloy spider, i bet you could get a drill and put a few holes in it...
    Not entirely sure if i can be bothered though. I saw those Red Titanium cassette's elsewhere but i didn't know you could get them in 11-32 i thought it was 11.34 only. So that's certainly interresting as it's Red and exceptionally light.
    *** Now i don't want to get into arguments and have people winging*** But what's that cassette like? I know Recon made a MK2 cassette that shifted better as the first ones weren't great.
    drilling holes...
    forget about drilling holes! this saves almost nothing and will look bad unless you are a skilled mechanic with appropriate tools.just to give poeple an idea i always like to compare with let's say 1cm of aluminium a-head spacers.those weigh about 6g if i'm right so you get an idea of how many holes you will have to drill to save as much weight...
    Titanium cassette: correct - that's the 2nd generation and also got used by Sauser to win the worlds.
    That's true i suppose. It would need to be some BIG holes lol.
    Nino do you have any more pics of that Red casette?
    not here...
    yes i do but not in here as this doesn't belong in this thread!
    Ok.
    Apr 2005
    Quote Originally Posted by nino
    sauser just commented in the latest MBA where his bike is profiled that the cassette
    doesn't shift that well but it is light.
    I think Sausser has the Mk1 cassette's. They now have mk2 's which i belive are a bit better.
    Apr 2005
    he gave the name of the cassette as "leiktech" or something to that effect, i don't have
    the article here with me.
    Quote Originally Posted by peabody
    sorry - but a Pro like him won't spec a cassette if it won't shift good enough!!
    Apr 2005
    lets face it, we all know it isnt going to shift like a shimano. I think that is more or less
    what he is saying. he didn't say it wont shift.
    Go faster!
    Reputation: sergio_pt's Avatar
    were do you get the titanium cogs to tune the cassete?
    can I get them separately?
    well...
    let's face it: a sponsored rider like him CAN'T/WON'T tell you that a product from another source than his sponsors is doing as good or better...
    again: he wouldn't use a cassette that would have bad shifting - no way !
    Aren't the ramps though just the Shimano Hyperglide technology??
    Apr 2005
    he doesnt have a drivetrain sponsor, uses what he wants. mixes sram with shimano.
    i have seen him with sram cassettes and shimano, uses 1 of each on derailleurs,
    picks his own chain, uses sram shifters. again he didn't say it didn't shift, just not
    as good as others........which i can believe. you can reverse engineer a shimano cassette
    all you want, but it will never be exact because you don't know the starting point and the
    tolerances. plus the chain and cassette aren't designed together to mesh together.
    oh boy...
    anyway - i am still proud that he choose the titanium cassette over Shimano and SRAM for such an important event. it can't be that bad then
    Legend
    Maybe his real cassette bent in a bad fall during practice and all he could get was the Ti one that someone was taking off because it shifted like arse.
    Just saying, sometimes compromises have to be made when the race is in 5 minutes.
    Reputation: Hand/of/Midas's Avatar
    Quote Originally Posted by ettore
    no, first off ive never seen a cassette bend, second christoph sauser is a huge WW,he even has his personal frames custom made without clearcoat over the carbon to save grams.
    he has two bikes(at least) he has a training bike with pretty standard high end parts, and a race only bike that has alot of very expensive light parts, like the recon cassette, ax lightness post, and so on.
    Legend
    Really? You've never seen a bent cassette ? It's pretty rare, admittedly, but it happens. Anyhow, it was just a hypothesis, no need to get your underwear in a bunch.
