Results 1 to 19 of 19
    Reputation: nino's Avatar
    original Crossmax rim weight???
    has anyone the weight of the original, NON UST Crossmax wheelsets rims?
    they are from ca. '98 and had a very box-shaped rim. front 26 hole, rear 28 holes and ceramic coating.
    thanks
    Max
    Max is offline
    Velodramatic
    Reputation: Max's Avatar
    hehe, i've seen them on ebay too my best friend wants them. i weighed an old crossmax rim and it was pretty heavy: ~460g from what i can remember. the complete front wheel weighed around 685g.
    note that no tubeless kit will fit cuz the rim bed is so oddly shaped
    and i suppose you could get some rims directly from mavic
    Skinny guys fight 'til they're burger
    650g...
    Quote Originally Posted by Max
    i remember the wheels weights since i had them back then:
    650+850g.
    no , i haven't seen those rims on Ebay. i just have the opportunity to get these rims from Mavic direct and i thought i remebered someone posting the weights. i thought it was about 380-400g?
    here's the link
    Quote Originally Posted by nino
    650+850g.
    i just had a look at Ebay and found that auction you mentioned:
    http://cgi.ebay.de/ws/eBayISAPI.dll?...122088850&rd=1
    but i could get them cheaper...
    Recovering couch patato
    Reputation: Cloxxki's Avatar
    I have a set, bought in march '97. 1480 for the set, 650/830 or 630/850, can't remember. Wrecked the rear hub, gave up on it. Front still rides.
    The LBS got a replacement in once, it was 420g. When the wheels hit the market first, rumor said the rims were 370g each. As they were 26/28g with pretty normal spokes, and the Hubs being as flimsy looking as they are to me, not really a surprise that most of the weight was in the rims.
    Klok - XC - Skate - Ski
    nightriding is fun !
    Reputation: Big Bad Wolf's Avatar
    M40101 is the part #
    thanks
    Well, since I ripped a nipple out of it (again) on the rear wheel , I might be able to give you the exact weight if I get a new rim..they are very light (thats why spoke tension is crucial and even then every now and again I break one)
    And they do weigh 650/850 complete (without QR)
    pics HERE
    Titanium or Bust !
    Reputation: schnapmaster's Avatar
    Strong and light (for ceramic)
    I have two sets of these wheels. I guess the weight comes from the hubs and to a lesser degree the massive rimstrips, because the rims I have weighed came in around 410 grams. That's the same weight as Mavic 517 ceramics that I have weighed. About the same weight but the Crossmax is definitely a stronger design since it is wider and has the double eyelet spoke holes. They seem to work very well with a DIY latex sealant setup.
    I have had one crack at the spokeholes, I guess due to too much tension.
    They aren't cheap, even from Mavic on a prodeal I think I paid around $75 for one!
    Max
    Max is offline
    Velodramatic
    i dont think the Xmax are more reliable than the 517s. a friend of mine has had his Xmax rims replaced a couple of times, until he finally bought 517s (or 618, dunno exactly).
    since the old Xmax rims are double-eyelet, i thought it might be impossible to get them sealed. even with eclipse, i still have some fluid underneath the rimstrip on my 717 disc rims. and those dont have double-eyelets....
    Maybe not more reliable...
    I guess Max has a point. I have heard of many people having to replace these rims as I did, from fractures at the spoke holes. The double eyelets create a stronger wheel, though, as long as the tension on the spokes is not too much.
    I have had great luck with tubeless so far. One layer of strapping tape and two layers of electrical tape, side by side and slightly overlapped. The pythons I mounted with this rim job and homemade latex have held air for months.
    Reputation: XC Mike's Avatar
    Sep 2004
    I ran Stan's with my crossmax for about 1 year with no problem. As for the weight I just got a CK disc wheelset built up and my 32 hole with Mavic 717 disc rims are 2 oz more then the CrossMax front and rear. The one's I have are from 1999 Keep your eye's on e-bay you might see mine soon!!!!!
    New Xmax rims cost 100€ from Mavic.
    I have these wheels since 1999 and ripped two nipples in July 2002 and now again one nipple . It always happens in the rear wheel, this time on the non-drive side which is radially spoked. The two times I ripped the nipples was after very muddy rides, where a lot of force went through the wheels. The tension was correct , I had them respoked in july 2002 and did not have to retension them since then.
    They are my favorite set due to their light weight . The rimwall is very thin .
    I had no troubles with the hubs except the occasional change of bearings.
    Titanium or Bust !
    thanks guys!!
    thanks
    i thought they were lighter . as it seems they aren't. too bad. i'm still looking for a light ceramic rims with 28 holes. as it seems Bontrager might be an option but i will have to weigh some samples. usually the weight varies big time on Bonty rims.
    Max
    Max is offline
    Velodramatic
    nino, i heard rumors that DT swiss can coat rims with a ceramic surface. at least their own ones. why not just buy some notubes/AMC rims and get them coated? in mid-january i will fly to zürich and then take the train to the DT swiss works. maybe they can give me more detailed information
    Varying weight I see not as a chance to get the lightest possible, but as a warning that quality is very inconsistent.
    The XMAX double eyelits seem like a waste of weight, if they're still pulled through the rim. same goes for Open Pro's really, I have pulled those through as well. Odd that it hardly ever happens to me with single eyelits, even on light rims.
    Max
    Max is offline
    Velodramatic
    Nino, check this out: that might help us create our own ceramic cuperlight rims: http://www.a-m.de/deutsch/literatur/ke0892.htm
    Max
    Max is offline
    Velodramatic
    .... we only gotta find some aluminiumoxide or titaniumoxide :-/
    FPC
    FPC is offline
    [QUOTE=XC Mike]I ran Stan's with my crossmax for about 1 year with no problem.
    Did you use the standard size Stan's rim strip 21.5 - 24.5 mm? What did you use to cover the spoke holes - the rubber band that came withthe crossmax or some different tape? Any other thoughts on this set up? I was thinking of converting my '00 xmax to stan's. Thanks
    Sep 2004
    [QUOTE=FPC]
    Quote Originally Posted by XC Mike
    Yes the standard size and I removed Mavic rim tape and used Stan's tape in kit.
    411 grams for a 28 hole model; I just purchased one from a classified here. I would upload a picture but I cannot find my compact flash card reader.
    This rim is slightly wider than a 517 and the spoke bed surface has a rough black finish, not at all like the cd coating available on the 517.
  1. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  2. weight of crossmax rim?
    By yiucycle in forum Wheels and Tires
    Last Post: 11-29-2004, 04:17 PM
  3. Azonic Outlaw, rim compatible + weight?
    By Lucky13 in forum Downhill - Freeride
    Last Post: 11-25-2004, 08:04 AM
  4. CrossMAX SL or Disc rim weight?
    By LowRent1 in forum Wheels and Tires
    Last Post: 03-31-2004, 01:29 PM
  5. The Official Weight Weenies F.A.Q
    By Trevor! in forum Weight Weenies
    Last Post: 02-25-2004, 01:31 PM
