Results 1 to 5 of 5
    That's right....
    Reputation: Jersey's Avatar
    Orbea Scape build - 9.4kg/20.73lb
    Orbea Scape 18"
    Bottle Cage Bolts: Nylon (4) 1
    Bottom Bracket: see crankset 0
    Rear Brakes: Formula Oro Puro 160mm 376
    Front Brakes: Formula Oro Puro 160mm 358
    Cables: see shifters 0
    Cassette: Shimano XT 11-32 w/XTR alloy lockring 254
    Chain Guard: Inner tube + tape 17
    Chain: Sram PC990 hollow pin 274
    Crankset: Race Face Deus 175mm 844
    Derlr (Front) Shimano XT w/ Ti cable and clamp bolts 121
    Derlr (Rear) Shimano XTR long cage w/ Ti bolts 234
    Fork: Fox F100RLT 1620
    Frame: Orbea Scape '06 - 18" 1350
    Grips: Ritchey WCS w/ plugs 47
    Handlebar: Easton EC90 Monkeylite SL CNT low-rise 135
    Headset: FSA Orbit ZR 124
    Headset Cap/Bolt: Syntace & Ti bolt 12
    Headset Spacer: FSA carbon 20mm 8
    Pedals: Crank Bros 4ti 170
    Quick Releases: Salsa Suspension flip-offs 93
    Seat Binder: Hope w/ Ti bolt 18
    Seat: Tioga Spyder 144
    Seatpost: Thomson Masterpiece setback w/ Ti bolts 187
    Shifters: Shimano XT w/ Ti clamp bolts 224
    Stem: Syntace F99 105mm w/ Ti bolts 97
    Tire (Front) Kenda Blue Groove stick-E 2.1 616
    Tire (Rear): Kenda Karma DTC 2.0 429
    Tubes: Stans 100
    Wheelset:
    --Rims: Stans Olympic disc 32h w/ rimstrip & valve 792
    --Spokes: DT SuperComps 64pcs 321
    --Nipples: DT alloy (gold ano) 21
    --Front Hub: DT 240s IS disc 147
    --Rear Hub: DT 240s IS disc 268
    Misc Option: grease, loctite, air, zip tie 3
    TOTALS:
    grams: 9405
    pounds: 20.73
    Get your freak on!
    Wow - That build is just awesome and it looks it too!
    Weight Weenie Shop Owner
    Reputation: DIRT BOY's Avatar
    Aug 2002
    Nice looking bike and nice job of specs. Not the lightest HT even with disc, but a nice weight. The fork is a PIG though .
    But at least it's a sweet, stiff fork.
    Like my ride4, that's built to handle some abuse and be durable. Man, If I had you wheels, I be below the 19lb mark and durable....
    Just get some lighter QRs or go bolt-on, get a XTR cassette to save a few extra grams and a Extralire ScalHead. Oh a KMC chain too.
    After that, I would touch a thing. Just minor things that could save a few grams and still keep it durable. Only thing maybe to skip it the Extralite HS as it's not cheap, but you save around 50g.
    Again, NICE job.
    DIRT BOY
    Light-Bikes.com
    The Largest Site Dedicated to Light Weight Bikes and Sales
    Twitter: @lightbikes_com
    Category Winner
    Reputation: teamdicky's Avatar
    That Tioga saddle didn't last too long under my 130 pound butt. I cracked one of the webs and haven't trusted it since.
    I loved it while it lasted.
    WWW.TEAMDICKY.COM
    I get paid 3¢ every time I post on MTBR.
    That's right....
    Quote Originally Posted by teamdicky
    yeah...the one in the picture lasted about 20 rides before i pretzeled one of the rails. granted, i had it back a little too far. anyway tioga did a quick warranty replacement and im still VERY happy with it. the warrantied one i got was 4g heavier though
