Results 1 to 5 of 5
    Okay, found lightweight A2Z front hubs. Question about 15mm conversion
    Found some A2Z XCF32 front hubs, and I believe they're convertible to 15mm thru axle with Stan's 15mm end caps.
    Anyone confirm this.
    The version is the latest: small flange and tall flange.
    Hi,
    I got a set of A2Z hubs front + rear (XCFi/XCRi) like these here A2Z XCFi + XCRi komplet piast
    The front is definitely convertible to 15mm. I bought mine already converted, the problem is that end caps that came with the hub are not fixed to the hub itself. They fall out each time I remove the axle and take the wheel out.
    Doesntplaywellwithmorons!
    Reputation: DeeEight's Avatar
    That's because the hubs have 15mm bearings and the end caps they come with reduce that to the 9mm ends normally. The conversion involves endcaps which are simply spacers to get the hub centered on a 15QR axle.
    I don't post to generate business for myself or make like I'm better than sliced bread
    ups and downs
    Try some Loctite 609 Bearing Retaining compound on the end caps to keep them in place.
    Quote Originally Posted by bazyl View Post
    Hi,
    XCF-32 with the 15mm axle here: Torontocycles Last Chance and Sale Items
    $50 plus $5 delivery to US.
  1. Replies: 13
    Last Post: 07-26-2014, 11:03 PM
  2. Help in choosing 15mm front hubs
    By iamspartacus in forum Beginner's Corner
    Last Post: 11-22-2012, 09:33 AM
  3. Paid Spam Hope Pro 2 Evo Hubs 15mm front 135 qr Rear Black 32H
    By Adim_X in forum Where are the Best Deals?
    Last Post: 06-29-2012, 12:10 PM
  4. DT240 hubs 15mm thru to QR/9mm conversion ?
    By ozzybmx in forum Wheels and Tires
    Last Post: 05-11-2011, 02:58 AM
  5. Replies: 3
    Last Post: 03-08-2011, 05:11 PM
